Home » Language IDEs » Java Development Tools (JDT) » JUNIT Testing(Necessarity of the constructor)
JUNIT Testing [message #837819] Fri, 06 April 2012 02:11 Go to next message
Normally, a class, which extends the "TestCase" class has to contain a constructor, which takes a String. The String then has to contain the names of the test-methods in your "TestCase"-class, which you want Junit to execute. But in eclipse you either:
1. Don't use any constructor, but it nevertheless works fine and all test-methods are executed.
or
2. Use a constructor, which takes a String. But you don't have to instantiate the test-class and it nevertheless works, even though you don't pass any String, you just push the "execute" button and it all magically works..
Can someone explain that, please?
Best regards
Re: JUNIT Testing [message #869807 is a reply to message #837819] Fri, 04 May 2012 07:22 Go to previous message
On 06.04.2012 08:11, Jeffson Jeffson wrote:
> or
> magically works..
JUnit uses reflection to collect all public methods that start with
"test" and then executes them.
Dani
> Best regards
Previous Topic:options java appearance "show categories"
Next Topic:Problem with Eclipse Helios
Current Time: Sat Jul 19 13:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.30011 seconds
