Home » Archived » BIRT » Changing aggregate expression of chart series based on report parameter
Changing aggregate expression of chart series based on report parameter [message #869442] Thu, 03 May 2012 08:08 Go to next message
I have trouble finding the right handles to change the aggregate expression of some line series based on a report paramter. Especially because content assist doesn't pop up.
index.php/fa/9291/0/
In my beforefactory event handler, I was able to change the grouping of the x-axis with:
var mychart = this.getReportElement("mainChart");
mychart.getCategory().getGrouping().setGroupUnit(reportContext.getParameterValue("grouping"));
However, don't want to change the category axis, but the y axis. I'm unable to get to the right object to call setAggregateExpression. According to the API I should get to the SeriesGrouping object.
  • Attachment: naamloos.JPG
    (Size: 180.76KB, Downloaded 1161 times)
Re: Changing aggregate expression of chart series based on report parameter [message #869679 is a reply to message #869442] Thu, 03 May 2012 13:07 Go to previous messageGo to next message
It should be doable in the beforeFactory like:
importPackage(Packages.org.eclipse.birt.chart.model.data.impl);
//Chart must be named
cht =
reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("MyChart");
mychart = cht.getReportItem().getProperty( "chart.instance" );
var xAxis = mychart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var xSerieDef = xAxis.getSeriesDefinitions().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var yq = ySerieDef.getGrouping();
var yg = yq.setAggregateExpression(params["ChartAggregate"].value);
See attached example
Jason
Re: Changing aggregate expression of chart series based on report parameter [message #869786 is a reply to message #869679] Fri, 04 May 2012 06:04 Go to previous messageGo to next message
Hey Jason,
Again, thanks for your help! However, this doesn't work for me. Running it in debug mode I found out that yq becomes null since the ySeriesDef has no grouping. I started exploring in the variables view while in debug mode, and I found the variable I'd like to change. But I have no idea how to reach it.
Starting at ySeriesDef, the last defined variable before yq:
ySeriesDef -> series -> data -> [0] -> dataDefinition -> data -> [0] -> grouping
There is the aggregate expression i'd like to modify.
I've also included my report design, however, it uses a database, so I'm not sure whether this would be useful.
Re: Changing aggregate expression of chart series based on report parameter [message #869875 is a reply to message #869786] Fri, 04 May 2012 11:28 Go to previous messageGo to next message
Ruben
Have a look at the attached image. Tell me which one are you trying to
change.
Jason
On 5/4/2012 6:04 AM, Ruben Durk wrote:
> Hey Jason,
Re: Changing aggregate expression of chart series based on report parameter [message #870444 is a reply to message #869875] Tue, 08 May 2012 05:30 Go to previous messageGo to next message
Hey Jason,
The seriesgrouping on the Y series definition
Re: Changing aggregate expression of chart series based on report parameter [message #870580 is a reply to message #870444] Tue, 08 May 2012 16:14 Go to previous message
Ruben
Take a look at :
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1508-change-aggregate-function-on-chart-series/
Jason
On 5/8/2012 5:30 AM, Ruben Durk wrote:
> Hey Jason,
Previous Topic:Floating Text around Pictures
Next Topic:Sorting in Cross tab is not working
Current Time: Sun Jul 20 14:22:38 EDT 2025
Powered by FUDForum. Page generated in 0.10469 seconds
