Home » Modeling » M2T (model-to-text transformation) » [Galileo, XPAND] Loop using the expression FOREACH
[Galileo, XPAND] Loop using the expression FOREACH [message #869314] Thu, 03 May 2012 04:09 Go to next message
Hi everyone,
I have a little problem for doing my work. To be clear, I have 3 arguments "FramePort, Length and SlotID" with 121 elements each.
The different argument are in different part of my file. So I would like to create a loop from 0 to 121.
Now, when I'm using my loop FOREACH, i have the right argument "SlotID" but for my two others arguments, I have the all collection for each iteration.
«LET this.topLevelPackages.......framePort AS FramePort-»
«LET this.topLevelPackages.......frameLength AS Length-»
«FOREACH  topLevelPackages........slotId AS SlotID ITERATOR SlotIDCounter-»
Slot ID : «SlotID»
Length  : «Length»
FramePort	: «FramePort»
«ENDFOREACH-»
«ENDLET»
«ENDLET»
Thanks you in advance,
[Updated on: Thu, 03 May 2012 04:16] by Moderator
Re: [Galileo, XPAND] Loop using the expression FOREACH [message #869625 is a reply to message #869314] Thu, 03 May 2012 14:11 Go to previous messageGo to next message
since you dotted out a lot i do not really get your problem.
what about
«FOREACH topLevelPackages……..parent AS parent ITERATOR SlotIDCounter-»
Slot ID : «parent .SlotID»
Length : «parent .Length»
FramePort : «parent .FramePort»
«ENDFOREACH-»
if your structure is different it would be nice of you share a complete
reproducable example
~Christian
Re: [Galileo, XPAND] Loop using the expression FOREACH [message #869753 is a reply to message #869625] Fri, 04 May 2012 04:12 Go to previous messageGo to next message
Sorry you're right, but indeed my structure is different, like this :
«LET this.topLevelPackages.arPackage.elements.get(2).ecuInstance.connectors.flexRayCommunicationConnector.ecuCommPortInstances.framePort AS FramePort-»
«LET this.topLevelPackages.arPackage.elements.get(5).frame.frameLength AS Length-»
«FOREACH  topLevelPackages.arPackage.elements.get(1).flexrayCluster.physicalChannels.flexrayPhysicalChannel.frameTriggeringss.flexrayFrameTriggering.absolutelyScheduledTimings.absolutelyScheduledTiming.slotId AS SlotID ITERATOR SlotIDCounter-»
Slot ID : «SlotID»
Length  : «Length»
«ENDFOREACH-»
«ENDLET»
«ENDLET»
Re: [Galileo, XPAND] Loop using the expression FOREACH [message #869917 is a reply to message #869753] Fri, 04 May 2012 15:42 Go to previous message
Still the question: at which points in your metamodel are the 1..* relationships?
Previous Topic:[acceleo] unable to load JAR-packaged EMTLs on unix
Next Topic:[Acceleo] Test for an undefined enumeration in OCL
Current Time: Sat Jul 19 15:37:41 EDT 2025
Powered by FUDForum. Page generated in 0.05100 seconds
