Change display name of unit tests in JUnit Eclipse plugin [message #869403] |
Thu, 03 May 2012 06:53  |
Is it possible for an Eclipse plugin to change the display name of unit tests run by the default Eclipse JUnit plugin?
Some background: I'm trying to create a plugin which will display unit test names (in the JUnit view in Eclipse) a bit different from the actual method name. If the actual test method name is "anEmptyCollectionHasSizeZero" I want it to be displayed in the Eclipse JUnit view as "An empty collection has size zero".
I've managed to display the test method names in the way described above as a separate view in a plugin, but would as I said like to get this feature integrated in the normal JUnit view. I tried to see if I could find a related extension point, but could not find anything. Is it possible to do this?
Also, is there a plugin which already does this, or similar?
FUDForum. Page generated in 0.24164 seconds
