Home » Eclipse Projects » GEF » Design question
Design question [message #86819] Fri, 11 July 2003 14:48 Go to next message
Originally posted by: rahul.dhar.intel.com
I'm trying to design my application so my figure cannot access my my model
or editparts. However, my figure has to get some of its parameters from
the information stored in my model. Is there a way to provide this
information without having to pass in my model as a parameter?
Unfortunately, enumerating each parameter would make the code a pain to
read/maintain.
-Rahul
Re: Design question [message #86831 is a reply to message #86819] Fri, 11 July 2003 15:34 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.intershop.com
"Rahul Dhar" <rahul.dhar@intel.com> wrote in message
news:ben0q3$c50$1@eclipse.org...
The suggested way is to overwrite EditPart#refreshVisuals. This is the right
place where you should configure your figure according to the model. But you
have to call this method every time changes are made inside the model (e.g.
by a command).
> read/maintain.
Well, although model elements should never be passed to figures it might be
possible to let them implement an interface (something like
IMyFigureConfiguration) and have a method in your figure
MyFigure#initializeFrom(IMyFigureConfiguration config). This is probably
better than doing a hundret times
MyFigure#setFigureProperty(MyModel#getModelProperty()).
Cu, Gunnar
Re: Design question [message #86902 is a reply to message #86831] Fri, 11 July 2003 17:07 Go to previous messageGo to next message
Gunnar Wagenknecht wrote:
> by a command).
This seems to make the most sense. When is refreshVisuals called? Do I
have to set listeners to trigger it? Is there any documentation detailing
this stuff? I'm rather lost at the moment?
-Rahul
Re: Design question [message #86917 is a reply to message #86902] Fri, 11 July 2003 17:13 Go to previous messageGo to next message
news:ben8uc$lhe$1@eclipse.org...
It is called the first time by GEF. All other times it has be called by you.
The regular way is the following:
your EditPart listens to the model for changes
if your EditPart receives a change event from the model it checks, wheather
the changed property might cause an updated to the figure
if yes, call #refreshVisuals
Cu, Gunnar
Re: Design question [message #86932 is a reply to message #86917] Fri, 11 July 2003 17:23 Go to previous messageGo to next message
So, what's the order of calls when an EditPart is created?
is it
Constructor
createFigure (if available)
refreshVisuals
or am I completely off base?
-Rahul
Re: Design question [message #86946 is a reply to message #86932] Fri, 11 July 2003 18:05 Go to previous message
news:ben9tc$md6$1@eclipse.org...
> Constructor
mostly called by your EditPartFactory
> refreshVisuals
createFigure is called the first time someone called getFigure, so it is
save for you to call getFigure inside refeshVisuals
Cu, Gunnar
Previous Topic:programmatically opening GraphicalEditor
Next Topic:tracking tool activate in palette-less applications
Current Time: Sat Jul 19 05:02:21 EDT 2025
Powered by FUDForum. Page generated in 0.54366 seconds
