Home » Archived » BIRT » Parse data into second Data Set
Parse data into second Data Set [message #868753] Wed, 02 May 2012 09:48 Go to next message
Hi, I'm new to BIRT and am using 3.7.1.
I have an SQL Stored Procedure Data Set pulling data from Oracle.
The procedure's output (now) returns one row per entity. One of the columns is a bunch of joined detail data that my report needs to split into multiple detail rows per entity.
The field is named CODING and the data comes back in the format:
Type1~~ID1~~Name1~~~~~;~Type1~~ID2~~Name2~~0~~0~;~Type2~~ID3~~Name3~~100~~25083
I plan to parse on ~~ and ~;~ into a per-row detail table of:
Type || ID || Name || Percent || Dollars
Type1 | ID1 | Name1 | |
Type1 | ID2 | Name2 | 0 | 0
Type2 | ID3 | Name3 | 100 | 25083
First, I'm looking for feedback on the right approach. I have seen the example of nesting the Order Details table in the main Orders row. That looks like what I want, so I'm trying to figure out how to get from a parsed collection local variable (in javascript or java) into a new data set. Or perhaps I should handle it differently.
Your thoughts?
Also, in which (data set?) event would you write the function to deal with each master row of data. I'm guessing I wouldn't iterate over all of the master rows at once.
(Reqs - I want to only hit the database once per report - the procedure takes a while, and the grouped data returned doesn't lend itself to further queries for details. As the output includes CLOBs, I only want one row per entity, so have already adjusted my SQL to mash the many-to-one detail data together to allow one returned row per entity.)
(First post, so I apologize if I'm not following preferred conventions.)
Michael
Re: Parse data into second Data Set [message #869010 is a reply to message #868753] Wed, 02 May 2012 17:09 Go to previous messageGo to next message
The solution was to add a scripted data set, sending the long data string as a parameter "codingparam".
Data Set's open:
i=0;
coding = inputParams["codingparam"];
arrCoding = coding.split("~;~");
Data Set's fetch:
if(i>=arrCoding.length){
return false;
codingRow=arrCoding[i];
arrCodingRow=codingRow.split("~~");
row["CODE_TYPE"] = arrCodingRow[0];
row["CODE_ID"] = arrCodingRow[1];
row["CODE_NAME"] = arrCodingRow[2];
if(arrCodingRow.length>3){
row["PERCENT_RELEVANCE"] = arrCodingRow[3];
row["PERCENT_DOLLARS"] = arrCodingRow[4];
++i;
return true;
Re: Parse data into second Data Set [message #869672 is a reply to message #868753] Thu, 03 May 2012 12:02 Go to previous messageGo to next message
Michael,
You could have an outer table tied to the stored proc and and an inner
table that is a scripted data set. The scripted data set could take the
outer table row value as an input parameter that you could then parse.
I am not certain how fast this would be though.
I created a simple example with your data and attached it.
Jason
> Your thoughts?
> Michael
Re: Parse data into second Data Set [message #869674 is a reply to message #869010] Thu, 03 May 2012 12:32 Go to previous message
Sorry I did not see this.
Jason
> Data Set's open:
> i=0;
> Data Set's fetch:
> return false;
> ++i;
> return true;
Previous Topic:bar chart with literal array for Category (x) series?
Next Topic:Report Parameter values size
Current Time: Sun Jul 20 17:52:59 EDT 2025
Powered by FUDForum. Page generated in 0.05332 seconds
