Home » Language IDEs » Java Development Tools (JDT) » Eclipse Classic vs Eclipse Java
Eclipse Classic vs Eclipse Java [message #858029] Thu, 26 April 2012 21:14 Go to next message
Hi guys,
watching www.eclipse.org/downloads/compare.php I have to comment that Eclipse Classic 3.7.2 (174MB) is greater than Eclipse IDE for Java Developer (128 MB) whether Eclipse Classic relate to less packages than Eclipse Java.
Can someone explain the reason? I assume its because of source code packaged in Eclipse Classic but i have not been able to find that code yet. can someone help? Smile
[Updated on: Fri, 27 April 2012 22:47] by Moderator
Re: Eclipse Classiv vs Eclipse Java [message #858212 is a reply to message #858029] Thu, 26 April 2012 23:31 Go to previous messageGo to next message
Look at *source* jars in the plugins folder.
Re: Eclipse Classiv vs Eclipse Java [message #859354 is a reply to message #858212] Fri, 27 April 2012 11:41 Go to previous messageGo to next message
Oh ok, thanks and how can i use the code jars?
Re: Eclipse Classiv vs Eclipse Java [message #865194 is a reply to message #859354] Mon, 30 April 2012 05:24 Go to previous messageGo to next message
If you are doing plugin development, you should be able to look at the Eclipse platform source and step through them while debugging..
Re: Eclipse Classiv vs Eclipse Java [message #865317 is a reply to message #865194] Mon, 30 April 2012 06:40 Go to previous messageGo to next message
Satyam Kandula wrote on Mon, 30 April 2012 05:24
ok great, thank you very much Smile
does the classic eclipse contain sources for all plugins. I miss import org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor for example Smile
[Updated on: Mon, 30 April 2012 06:41] by Moderator
Re: Eclipse Classiv vs Eclipse Java [message #867569 is a reply to message #865317] Tue, 01 May 2012 07:10 Go to previous messageGo to next message
[quote title=Rudolf Schmidt wrote on Mon, 30 April 2012 12:40]Satyam Kandula wrote on Mon, 30 April 2012 05:24
I can tell for sure for every single plug-in but the JDT sources are complete (incl. the class you mention). Does your project have a dependency on org.eclipse.jdt.ui?
best,
Stephan
Re: Eclipse Classiv vs Eclipse Java [message #867826 is a reply to message #867569] Tue, 01 May 2012 09:56 Go to previous messageGo to next message
[quote title=Stephan Herrmann wrote on Tue, 01 May 2012 07:10]Rudolf Schmidt wrote on Mon, 30 April 2012 12:40
best,
Stephan
yea, you could say it. my project is to fix the bug discribed in http(s)://bugs.eclipse.org/bugs/show_bug.cgi that exists since 2004. its time to fix it Smile
the class containing this bug references to org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor and i cant resolve it.
could you be so kind to help me? I have added all known plugins (from the plugin view) to the java search and checked out the master branch from git://git.eclipse.org/gitroot/jdt/eclipse.jdt.ui.git
Re: Eclipse Classiv vs Eclipse Java [message #868032 is a reply to message #867826] Tue, 01 May 2012 11:59 Go to previous messageGo to next message
I can tell for sure for every single plug-in...
For completeness: I meant to say "I can't ..."
Rudolf Schmidt wrote on Tue, 01 May 2012 15:56
Somehow the bug number got lost ...
I don't exactly see what you mean by adding plugins to the java search, but the key question is: have you specified the dependency on org.eclipse.jdt.ui in your own Plug-in project (in MANIFEST.MF)? Or are you making changes inside the org.eclipse.jdt.ui project? Where exactly do you see the error?
BTW, when speaking of a failure to resolve RenameFieldProcessor this is not a matter of having source code in Eclipse Classic, even less so if you work from a source project from git.
Stephan
Re: Eclipse Classiv vs Eclipse Java [message #868300 is a reply to message #868032] Tue, 01 May 2012 14:50 Go to previous messageGo to next message
stupid message: "You cannot use links until you have posted more than 25 messages."
so you have to spam until 25 posts to post more spam *g*
I'm really sorry. the resolving problem occurs in the file RenamePrivateFieldTests and not in the file RenameFieldProcessor. its the line number 35: "import org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor;" with the error message: "The import org.eclipse.jdt.internal.corext.refactoring.rename.RenameFieldProcessor cannot be resolved"
Re: Eclipse Classiv vs Eclipse Java [message #868387 is a reply to message #868300] Tue, 01 May 2012 17:43 Go to previous messageGo to next message
Rudolf Schmidt wrote on Tue, 01 May 2012 20:50
So, your org.eclipse.jdt.ui.tests.refactoring project cannot "see" your org.eclipse.jdt.ui. Maybe you need to check the versions in your MANIFEST.MF's. Aren't there any error markers on the manifest?
Stephan
Re: Eclipse Classiv vs Eclipse Java [message #868396 is a reply to message #868387] Tue, 01 May 2012 18:11 Go to previous messageGo to next message
Stephan Herrmann wrote on Tue, 01 May 2012 17:43
Stephan
Hey Stephan,
indeed, there are some errors. The MANIFEST.MF containing RenamePrivateFieldTests cants resolve the package "org.eclipse.test.performance"
thats the content of the manifest file:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %Plugin.name
Bundle-SymbolicName: org.eclipse.jdt.ui.tests.refactoring; singleton:=true
Bundle-Version: 3.8.0.qualifier
Bundle-ClassPath: refactoringtests.jar
Bundle-Activator: org.eclipse.jdt.ui.tests.refactoring.infra.RefactoringTestPlugin
Bundle-ActivationPolicy: lazy
Bundle-Vendor: %Plugin.providerName
Bundle-Localization: plugin
Export-Package:
 org.eclipse.jdt.ui.tests.refactoring;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.actions;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.all;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.ccp;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.changes;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.extensions;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.infra;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.nls;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.reorg;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.type;x-internal:=true,
 org.eclipse.jdt.ui.tests.refactoring.typeconstraints;x-internal:=true
Require-Bundle:
 org.eclipse.core.filebuffers,
 org.eclipse.core.filesystem,
 org.eclipse.core.resources,
 org.eclipse.core.runtime,
 org.eclipse.jdt.core,
 org.eclipse.jdt.core.manipulation,
 org.eclipse.jdt.ui;bundle-version="[3.8.0,4.0.0)",
 org.eclipse.jdt.ui.tests,
 org.eclipse.jface.text,
 org.eclipse.ltk.core.refactoring,
 org.eclipse.ltk.ui.refactoring,
 org.eclipse.team.core,
 org.eclipse.test.performance,
 org.eclipse.ui,
 org.eclipse.ui.ide,
 org.eclipse.ui.workbench.texteditor,
 org.junit;bundle-version="4.8.2"
Bundle-RequiredExecutionEnvironment: J2SE-1.5
and at line 36 "org.eclipse.test.performance" there is a error symbol. hovering over it displays "Bundle 'org.eclipse.test.performance' cannot be resolved"
the manifest from RenameFieldProcessor contains 3 errors.
its content is
Bundle-Name: %pluginName
Bundle-SymbolicName: org.eclipse.jdt.ui; singleton:=true
Bundle-Activator: org.eclipse.jdt.internal.ui.JavaPlugin
Bundle-Vendor: %providerName
Export-Package: org.eclipse.jdt.internal.corext;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.corext.buildpath;x-internal:=true,
 org.eclipse.jdt.internal.corext.callhierarchy;x-internal:=true,
 org.eclipse.jdt.internal.corext.codemanipulation;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.corext.codemanipulation.tostringgeneration;x-internal:=true,
 org.eclipse.jdt.internal.corext.dom;x-internal:=true,
 org.eclipse.jdt.internal.corext.dom.fragments;x-internal:=true,
 org.eclipse.jdt.internal.corext.fix;x-internal:=true,
 org.eclipse.jdt.internal.corext.javadoc;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.base;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.binary;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.changes;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.code;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.code.flow;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.delegates;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.generics;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.nls;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.nls.changes;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.participants;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.rename;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.reorg;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.scripting;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.sef;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.structure;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.structure.constraints;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.surround;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.tagging;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.typeconstraints;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.typeconstraints.types;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.typeconstraints.typesets;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.typeconstraints2;x-internal:=true,
 org.eclipse.jdt.internal.corext.refactoring.util;x-internal:=true,
 org.eclipse.jdt.internal.corext.template.java;x-internal:=true,
 org.eclipse.jdt.internal.corext.util;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.ui;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.actions;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.ui.browsing;x-internal:=true,
 org.eclipse.jdt.internal.ui.callhierarchy;x-internal:=true,
 org.eclipse.jdt.internal.ui.commands;x-internal:=true,
 org.eclipse.jdt.internal.ui.compare;x-internal:=true,
 org.eclipse.jdt.internal.ui.dialogs;x-friends:="org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.dnd;x-internal:=true,
 org.eclipse.jdt.internal.ui.filters;x-internal:=true,
 org.eclipse.jdt.internal.ui.fix;x-internal:=true,
 org.eclipse.jdt.internal.ui.infoviews;x-internal:=true,
 org.eclipse.jdt.internal.ui.jarimport;x-internal:=true,
 org.eclipse.jdt.internal.ui.jarpackager;x-internal:=true,
 org.eclipse.jdt.internal.ui.jarpackagerfat;x-internal:=true,
 org.eclipse.jdt.internal.ui.javadocexport;x-internal:=true,
 org.eclipse.jdt.internal.ui.javaeditor;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.ui.javaeditor.breadcrumb;x-internal:=true,
 org.eclipse.jdt.internal.ui.javaeditor.saveparticipant;x-internal:=true,
 org.eclipse.jdt.internal.ui.javaeditor.selectionactions;x-internal:=true,
 org.eclipse.jdt.internal.ui.model;x-internal:=true,
 org.eclipse.jdt.internal.ui.navigator;x-internal:=true,
 org.eclipse.jdt.internal.ui.packageview;x-internal:=true,
 org.eclipse.jdt.internal.ui.preferences;x-friends:="org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.preferences.cleanup;x-internal:=true,
 org.eclipse.jdt.internal.ui.preferences.formatter;x-internal:=true,
 org.eclipse.jdt.internal.ui.propertiesfileeditor;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.actions;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.binary;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.code;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.contentassist;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.ui.refactoring.nls;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.nls.search;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.reorg;x-internal:=true,
 org.eclipse.jdt.internal.ui.refactoring.sef;x-internal:=true,
 org.eclipse.jdt.internal.ui.search;x-internal:=true,
 org.eclipse.jdt.internal.ui.text;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.correction;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.correction.proposals;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.folding;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.java;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.java.hover;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.javadoc;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.spelling;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.spelling.engine;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.template.contentassist;x-internal:=true,
 org.eclipse.jdt.internal.ui.text.template.preferences;x-internal:=true,
 org.eclipse.jdt.internal.ui.typehierarchy;x-internal:=true,
 org.eclipse.jdt.internal.ui.util;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.viewsupport;x-friends:="org.eclipse.jdt.junit",
 org.eclipse.jdt.internal.ui.wizards;x-friends:="org.eclipse.jdt.junit,org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.wizards.buildpaths;x-internal:=true,
 org.eclipse.jdt.internal.ui.wizards.buildpaths.newsourcepage;x-internal:=true,
 org.eclipse.jdt.internal.ui.wizards.dialogfields;x-friends:="org.eclipse.jdt.apt.ui",
 org.eclipse.jdt.internal.ui.workingsets;x-internal:=true,
 org.eclipse.jdt.ui,
 org.eclipse.jdt.ui.actions,
 org.eclipse.jdt.ui.cleanup,
 org.eclipse.jdt.ui.dialogs,
 org.eclipse.jdt.ui.jarpackager,
 org.eclipse.jdt.ui.refactoring,
 org.eclipse.jdt.ui.search,
 org.eclipse.jdt.ui.text,
 org.eclipse.jdt.ui.text.folding,
 org.eclipse.jdt.ui.text.java,
 org.eclipse.jdt.ui.text.java.correction,
 org.eclipse.jdt.ui.text.java.hover,
 org.eclipse.jdt.ui.wizards
Require-Bundle:
 org.eclipse.help;bundle-version="[3.4.0,4.0.0)",
 org.eclipse.core.expressions;bundle-version="[3.4.100,4.0.0)",
 org.eclipse.core.filesystem;bundle-version="[1.2.0,2.0.0)",
 org.eclipse.core.resources;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.core.variables;bundle-version="[3.2.200,4.0.0)",
 org.eclipse.jdt.core;bundle-version="[3.8.0,4.0.0)",
 org.eclipse.search;bundle-version="[3.7.0,4.0.0)",
 org.eclipse.debug.core;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.debug.ui;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.jdt.launching;bundle-version="[3.6.100,4.0.0)",
 org.eclipse.compare;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.team.ui;bundle-version="[3.4.100,4.0.0)",
 org.eclipse.team.core;bundle-version="[3.4.100,4.0.0)",
 org.eclipse.jface.text;bundle-version="[3.8.0,4.0.0)",
 org.eclipse.ui;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.ui.console;bundle-version="[3.4.0,4.0.0)",
 org.eclipse.ui.workbench.texteditor;bundle-version="[3.8.0,4.0.0)",
 org.eclipse.ui.ide;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.ui.views;bundle-version="[3.3.100,4.0.0)",
 org.eclipse.ui.editors;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.core.runtime;bundle-version="[3.7.0,4.0.0)",
 org.eclipse.ltk.core.refactoring;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.ltk.ui.refactoring;bundle-version="[3.5.0,4.0.0)",
 org.eclipse.ui.forms;bundle-version="[3.4.0,4.0.0)",
 org.eclipse.ui.navigator;bundle-version="[3.3.200,4.0.0)",
 org.eclipse.ui.navigator.resources;bundle-version="[3.4.0,4.0.0)",
 org.eclipse.jdt.core.manipulation;bundle-version="[1.4.0,2.0.0)",
 com.ibm.icu;bundle-version="4.4.2"
Import-Package: org.eclipse.jdt.core,
 org.eclipse.jdt.core.dom,
 org.eclipse.jdt.core.search,
 org.eclipse.text.edits
the error messages are:
Unsatisfied version constraint: 'org.eclipse.jdt.core: [3.8.0,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.jdt.launching: [3.6.100,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.jface.text: [3.8.0,4.0.0)'
Unsatisfied version constraint: 'org.eclipse.ui.workbench.texteditor: [3.8.0,4.0.0)'
dunno how to solve the problem.
Re: Eclipse Classiv vs Eclipse Java [message #868572 is a reply to message #868396] Wed, 02 May 2012 04:38 Go to previous messageGo to next message
As mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=64698
please follow the instructions on
http://wiki.eclipse.org/JDT_UI/How_to_Contribute. Essentially as you
already realized you need more projects in your workspace to satisfy
dependencies on test projects.
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Re: Eclipse Classiv vs Eclipse Java [message #870504 is a reply to message #868572] Tue, 08 May 2012 09:18 Go to previous messageGo to next message
Ok,
as you can see in bugs.eclipse.org/bugs/show_bug.cgi?id=64698#c12 i checked the projects out.
but i have still the same problem.
no developer answer in the mailing list of jdt
Re: Eclipse Classiv vs Eclipse Java [message #870514 is a reply to message #870504] Tue, 08 May 2012 09:52 Go to previous messageGo to next message
I assume after 'cloning' the git repositories, you also 'imported' the
projects from these repositories into your workspace?
PS: Such questions are best asked on the newsgroup, I for one do not
feel like answering them on the mailing list as that just adds clutter
to everyone's inbox.
Deepak Azad
Re: Eclipse Classiv vs Eclipse Java [message #870551 is a reply to message #870514] Tue, 08 May 2012 12:21 Go to previous messageGo to next message
yea of course i imported them in my buildpath.
could you be so kind, to say where the newsgroup relates on jdt issues is located for asking questions to jdk?
Re: Eclipse Classiv vs Eclipse Java [message #870613 is a reply to message #870551] Tue, 08 May 2012 22:20 Go to previous messageGo to next message
.... and the original error did not go away? i.e. MANIFEST.MF containing
RenamePrivateFieldTests still cannot resolve the package
Do you also have a 1.5 JDK installed ?
newsgroup and the forum are the same thing, i.e. this place :-)
Deepak Azad
Re: Eclipse Classiv vs Eclipse Java [message #873130 is a reply to message #870613] Thu, 17 May 2012 10:51 Go to previous message
Yea, i do not have jdk 1.5 installed. and yes, RenamePrivateFieldTests can still not resolve org.eclipse.test.performance.
edit:
i found the solution with the help of paulweb515. i had to checkout from R3_maintance7 branche instead of master or something else.
[Updated on: Thu, 17 May 2012 12:52] by Moderator
Previous Topic:How to figure our an ITypeRoot comes from Java Standard Library?
Next Topic:eclipse project type
Current Time: Sun Jul 20 17:43:49 EDT 2025
Powered by FUDForum. Page generated in 0.05588 seconds
