Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Compare - Diffing EMF UML2 XMI
EMF Compare - Diffing EMF UML2 XMI [message #86682] Mon, 18 June 2007 08:23 Go to next message
Originally posted by: user.domain.invalid
Dear All,
We get sent business requirements etc as XMI files produced by a recent
version on Rational.
We need to be able to tell exactly what has changed when we get sent a
new XMI file vs the one we already have/are working from.
Looking at them, they appear to be the std EMF UML2 XMI.
Is there any tutorial or example as to how one would go about using the
EMF Compare tool to diff the 2 XMI files?
Adam
Re: EMF Compare - Diffing EMF UML2 XMI [message #86696 is a reply to message #86682] Mon, 18 June 2007 09:27 Go to previous messageGo to next message
Dear All,
I'm also interested in available API and current state of Compare.
Latest build has dependencies on Eclipse 3.2.2 and EMF 2.2.2. Are there plans
to build Compare against Eclipse 3.3?
Also I can't find where sources hosted in Eclipse CVS.
Best Regards,
Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #86707 is a reply to message #86682] Mon, 18 June 2007 09:44 Go to previous messageGo to next message
AdamF wrote:
> Dear All,
> Adam
BTW with Eclipse 3.2.2 & the most recent update manager version I get
the following errors when I do a "compare as model" I get a
NullPointerException followed by a Unhandled event loop exception (see
below).
Is the latest version being built against eclipse 3.3. in preparation
for Europa?
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at
org.eclipse.emf.compare.ui.legacy.editor.ModelCompareEditorI nput.getCompareResult(ModelCompareEditorInput.java:479)
at
org.eclipse.compare.internal.CompareUIPlugin.compareResultOK (CompareUIPlugin.java:490)
at
org.eclipse.compare.internal.CompareUIPlugin.openCompareEdit or(CompareUIPlugin.java:435)
at
org.eclipse.compare.CompareUI.openCompareEditorOnPage(Compar eUI.java:134)
at org.eclipse.compare.CompareUI.openCompareEditor(CompareUI.ja va:120)
at
org.eclipse.emf.compare.ui.legacy.actions.CompareWithEachOth erAction$1.run(CompareWithEachOtherAction.java:49)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 20 more
TIA
Adam
Re: EMF Compare - Diffing EMF UML2 XMI [message #86720 is a reply to message #86696] Mon, 18 June 2007 10:08 Go to previous messageGo to next message
Originally posted by: lucas.bigeardel.anyware-tech.com
Sergey Boiko a écrit :
> Dear All,
Sergei,
Code source is available on CVS :
dev.eclipse.org:/cvsroot/modeling/org.eclipse.emf/org.eclips e.emf.compare/*
Cedric Brun is the lead for this project, I CCed him.
regards,
> Best Regards,
> Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #86770 is a reply to message #86720] Tue, 19 June 2007 06:20 Go to previous messageGo to next message
Right now compare is being cleaned up, in the gui as in the comparison
engines and API. The lowest build dependencies are Eclipse 3.2.2 and EMF
2.2.2 but it should build on Eclipse 3.3 too.
The API is not frozen yet, more especially concerning the merge support.
I'll provide tutorials as soon as the API is considered as frozen.
Concerning the XMI file, if EMF is able to load them, then we should be able
to compare them, if not its a bug. Do not hesitate to report it. I would
recommend to use the latest integration build (which will be done today),
it will fix some bugs.
In the latest builds the usage is quite simple. when one click on "Compare
with each other" the emf comparison is launched if the file is a "Model"
content-type (you can configure that in the preferences). The "Compare as
models" action disapeared and emf compare may now be called using SVN/CVS
or the history view too.
cheers,
Cédric
>> Dear All,
>> plans to build Compare against Eclipse 3.3?
> Sergei,
> regards,
>> Best Regards,
>> Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #86772 is a reply to message #86770] Tue, 19 June 2007 08:28 Go to previous message
Cédric Brun wrote:
Excellent
Which is the relevant update site?
http://download.eclipse.org/modeling/emft/updates/site-inter im.xml
Is the compare tool being aimed to get into the Europa release?
> cheers,
Very nice.
I am downloading 3.3 now.
Adam
> Cédric
>>> Dear All,
>> Sergei,
>> regards,
>>> Best Regards,
>>> Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #607007 is a reply to message #86682] Mon, 18 June 2007 09:27 Go to previous message
Dear All,
Best Regards,
Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #607008 is a reply to message #86682] Mon, 18 June 2007 09:44 Go to previous message
AdamF wrote:
> Dear All,
> Adam
below).
for Europa?
at
at
at
at
at
at
at
at
at
at
at
at
at
... 20 more
TIA
Adam
Re: EMF Compare - Diffing EMF UML2 XMI [message #607009 is a reply to message #86696] Mon, 18 June 2007 10:08 Go to previous message
> Dear All,
Sergei,
regards,
> Best Regards,
> Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #607015 is a reply to message #86720] Tue, 19 June 2007 06:20 Go to previous message
cheers,
Cédric
>> Dear All,
> Sergei,
> regards,
>> Best Regards,
>> Sergey.
Re: EMF Compare - Diffing EMF UML2 XMI [message #607016 is a reply to message #86770] Tue, 19 June 2007 08:28 Go to previous message
Cédric Brun wrote:
Excellent
> cheers,
Very nice.
Adam
> Cédric
>>> Dear All,
>> Sergei,
>> regards,
>>> Best Regards,
>>> Sergey.
Previous Topic:[Teneo] Create table fails in Integration Build I200704230019
Next Topic:[teneo/jpox] Question of design of metadata
Current Time: Sat Jul 19 19:04:12 EDT 2025
Powered by FUDForum. Page generated in 0.05843 seconds
