D&D in TextEditor [message #867364] |
Tue, 01 May 2012 04:53  |
Is TextEditor supposed to support D&D without further customization?
I do get the following error:
!ENTRY org.eclipse.ui 4 0 2012-05-01 10:33:50.865
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl$1.dragLeave(EditorSiteDragAndDropServiceImpl.java:107)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:70)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.dnd.DropTarget.Drop(DropTarget.java:403)
at org.eclipse.swt.dnd.DropTarget$3.method6(DropTarget.java:258)
at org.eclipse.swt.internal.ole.win32.COMObject.callback6(COMObject.java:119)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:363)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:289)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java:172)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at it.condarelli.writer.Writer.start(Writer.java:42)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I also traced the call to initializeDragAndDrop(getSourceViewer());, but
Platform.getAdapterManager().loadAdapter(this, "org.eclipse.ui.texteditor.ITextEditorDropTargetListener");
returns null.
It seems to install correctly installTextDragAndDrop(viewer).
but it doesn't work because in the DropTargetEvent data, dataTypes and currentDataType are all null.
Get ApprporiateListener() tries to return secondaryListener, but that is also null.
What do I miss?
TiA
Mauro
Re: D&D in TextEditor [message #868991 is a reply to message #867364] |
Wed, 02 May 2012 16:24  |
> !STACK 0
I seem to have hit the same misbehavior described in:
http://www.eclipse.org/forums/index.php/m/333816/3c7da5f6adf4288d241ba57a13d72a3d/#msg_333816
The workaround described there works for me.
Can someone suggest a "more proper" fix?
That one involves ignoring "restrictions" in the lib.
I was not able to find an associated bug; should I open one?
Mauro
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> returns null.
> What do I miss?
> TiA
> Mauro
FUDForum. Page generated in 0.02713 seconds
