Home » Eclipse Projects » WindowBuilder » ExpressionConverter null - assertionException
ExpressionConverter null - assertionException [message #860896] Sat, 28 April 2012 05:02 Go to next message
Hi, we have this customizer and some of it's properties are in array form like boolean and int.
now when we try to modify and then click the OK button of the customizer, it throws an assertionException because the expressionConverter was null. I looked into the ExpressionConverter and it seems there is none for arrays, except for StringArrays.
Is there anyway to get around this? WB checks if the converter is null after checking if the property has been changed.
Hope this is clear somehow. Thanks
Re: ExpressionConverter null - assertionException [message #861492 is a reply to message #860896] Sat, 28 April 2012 11:46 Go to previous messageGo to next message
I've added now expression converters for boolean[] and int[].
If you are in hurry, you could create your own plugin which will contribute them.
		<converter type="boolean[]"
			class="org.eclipse.wb.internal.core.model.property.converter.BooleanArrayConverter"/>
		<converter type="int[]"
			class="org.eclipse.wb.internal.core.model.property.converter.IntegerArrayConverter"/>
Re: ExpressionConverter null - assertionException [message #863383 is a reply to message #861492] Sun, 29 April 2012 08:25 Go to previous messageGo to next message
Thank you for this, i will post an update on monday. but again thank you
Re: ExpressionConverter null - assertionException [message #864543 is a reply to message #863383] Sun, 29 April 2012 22:00 Go to previous messageGo to next message
hi, we will incorporate these ourselves but can we ask if these will be included in a future release?
thank you
Re: ExpressionConverter null - assertionException [message #864544 is a reply to message #864543] Sun, 29 April 2012 22:02 Go to previous messageGo to next message
Yes, these changes are in trunk.
So, eventually they will go in a release.
Re: ExpressionConverter null - assertionException [message #864672 is a reply to message #864544] Sun, 29 April 2012 23:31 Go to previous messageGo to next message
if an array contains a swing based component (like a jcombo), will that be an issue?
Thanks again for the prompt reply
Re: ExpressionConverter null - assertionException [message #865219 is a reply to message #864672] Mon, 30 April 2012 05:42 Go to previous messageGo to next message
Hi, just a followup question, is there a tentative or a target date for the next release?
thanks
Re: ExpressionConverter null - assertionException [message #865871 is a reply to message #864672] Mon, 30 April 2012 12:11 Go to previous message
Conrad de Vera wrote on Sun, 29 April 2012 23:31
Added expression converters are specifically for boolean[] and int[] types.
Previous Topic:Customizer window size
Next Topic:WindowBuilder Issue
Current Time: Sat Jul 19 08:36:32 EDT 2025
Powered by FUDForum. Page generated in 0.08204 seconds
