Home » Modeling » GMF (Graphical Modeling Framework) » Read Only Resource Modification Prompt
Read Only Resource Modification Prompt [message #85307] Wed, 13 December 2006 16:17 Go to next message
Originally posted by: john.campaner.s1.com
Hi All,
Apologies if this has been already raised...not sure if its a bug or not (in
any case, its a very minor issue).
In cases when I have diagram or model resource files set to be read only, I
get a popup asking if I'd like to make the files read/write when I make
modifications (a good thing).
However, the popup only appears if the modifications are being made to the
main resource being edited. If additional read only resources are brought
into the editor's editing domain (e.g. through using Create Shortcut),
modifications to model objects in those resources are not recorded. No
prompt appears to make those resources read/write. Instead, GMF seems to
"quietly" ignore the inability to write to these resources if they happen to
be read only.
Ideally, we'd like to see a prompt similar to what you see when you modify
the main resource. Has this already been raised and should a bug be filed?
Re: Read Only Resource Modification Prompt [message #85369 is a reply to message #85307] Thu, 14 December 2006 05:59 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Submit a bug please (((
John Campaner wrote:
> Hi All,
> be read only.
Re: Read Only Resource Modification Prompt [message #85644 is a reply to message #85307] Thu, 14 December 2006 13:51 Go to previous messageGo to next message
Hello John,
Are you working on GMF from 2.0 stream? It looks like this problem should
be fixed as a part of generated DocumentProvider refactoring included into
2.0M3 ( http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#Aut omatic_diagram_editor_refresh)
Alex Shatalin
Re: Read Only Resource Modification Prompt [message #85748 is a reply to message #85644] Fri, 15 December 2006 10:17 Go to previous message
No...still on 1.0 but planning an upgrade in early January. I will hold off
on submitting a bug until after I try the upgrade.
John
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e6e3d08c8edd068078f48@news.eclipse.org...
> Hello John,
> 2.0M3
> Alex Shatalin
Previous Topic:customizing domain entity creation
Next Topic:Question about sharing diagrams
Current Time: Sat Jul 19 15:12:03 EDT 2025
Powered by FUDForum. Page generated in 0.05834 seconds
