Madness with compound primary key [message #855833] |
Wed, 25 April 2012 02:22  |
here is what I ultimately try to do:
table_1
int column_a is PK
table_2
int column_a is PK as well as FK to table_1.column_a
int column_b is PK
table_3
int column_b is PK as well as FK to table_1.column_a
int column_c is PK
As I could not get it to work, I started with a very small example of compound primary key. Below is the class I have written for this.
import javax.persistence.Basic;
import javax.persistence.Embeddable;
import javax.persistence.EmbeddedId;
import javax.persistence.Entity;
@Entity
public class DTest {
@Embeddable
public class PK {
@Basic private long First;
@Basic private long Second;
public PK() {}
public PK(long F, long S) {
First = F;
Second = S;
public boolean equals(Object O) { return false; }
public int hashCode() { return 0; }
@EmbeddedId private PK m_PK;
private long m_Third;
public DTest() {}
public DTest(long F, long S, long T) {
m_PK = new PK(F, S);
m_Third = T;
However, when I compile and run the example, I get the following error message from EL:
Quote:Exception [EclipseLink-30005] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.PersistenceUnitLoadingException
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: sun.misc.Launcher$AppClassLoader@1284903
Internal Exception: javax.persistence.PersistenceException: Exception [EclipseLink-28018] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.EntityManagerSetupException
Exception Description: Predeployment of PersistenceUnit [test] failed.
Internal Exception: Exception [EclipseLink-7298] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.ValidationException
Exception Description: The mapping [this$0] from the embedded ID class [class DTest$PK] is an invalid mapping for this class. An embeddable class that is used with an embedded ID specification (attribute [m_PK] from the source [class DTest]) can only contain basic mappings. Either remove the non basic mapping or change the embedded ID specification on the source to be embedded.
Thus, I took another attempt using @IdClass with the example below:
import javax.persistence.Id;
import javax.persistence.IdClass;
@Entity
@IdClass(DTest.PK.class)
public class PK {
public PK() {}
First = F;
Second = S;
@Id private long First;
@Id private long Second;
public DTest() {}
First = F;
Second = S;
m_Third = T;
When compile and run this class, I get the following error message:
Internal Exception: Exception [EclipseLink-7150] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Invalid composite primary key specification. The names of the primary key fields or properties in the primary key class [DTest$PK] and those of the entity bean class [class DTest] must correspond and their types must be the same. Also, ensure that you have specified ID elements for the corresponding attributes in XML and/or an @Id on the corresponding fields or properties of the entity class.
I am a little bit puzzled what could be wrong. According to numerous tutorials on the Web, both above classes shall work. But maybe I made some mistake I do not see. Any advice is greatly appreciated.
Cheers
Bjoern
Re: Madness with compound primary key [message #857403 is a reply to message #855833] |
Thu, 26 April 2012 10:00  |
I've never seen an inner class used as a primary key class - have you tried seperating it out into its own class?
That, and I do not see how this will work. The class shown seems to be for table 2 and will need to reference the first table which it does not do.
If using JPA 2.0, Something like:
@Entity
@IdClass(Table2_PK.class)
public class Table2 {
@ID
@OneToOneMapping
@JoinColumn(name="COLUMN_A")
private Table1 t1Reference;
@ID
@Column(name="COLUMN_B")
private long second;
public class Table2_PK.class {
private long t1Reference; //type must match the pk defined in Table1
FUDForum. Page generated in 0.03464 seconds
