Can't get php perspective to show up in windows (pdt 2.0) [message #85464] |
Wed, 03 December 2008 22:33  |
Originally posted by: alan.hartlessbydesign.com
I've tried downloading the all-in-one and tried downloading the Eclipse
JREE version and installing pdt via the update manager. But I cannot
get pdt to show up as a perspective. All my other plugins do, but not
pdt. I've tried restarting with -clean and still no good. (Linux
version works fine). Any ideas?
I'm using JRE 6.
Thanks!
Alan
Re: Can't get php perspective to show up in windows (pdt 2.0) [message #85715 is a reply to message #85550] |
Fri, 05 December 2008 14:38  |
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
http://wiki.eclipse.org/IRC_FAQ#How_do_I_start_Eclipse.3F
Alan Hartless wrote:
> Okay I found the problem. It is set in the path variable to load
> C:\Oracle\product\10.1.0\Client_1\bin;C:\Oracle\product\10.1 .0\Client_1\jre\1.4.2\bin\client;
> Eclipse is loading the VM 1.4.2 even though I tell it in the eclipse.ini
> file to load jre5/6. (It is loading both). If I removed the above from
> the path, PDT works. However, it is required for necessary applications
> to run. Is there a way to tell eclipse to ignore that VM?
> Thanks!
> Alan
> Alon Peled wrote:
>> Hi Alan,
>> We require Sun Java2 5.0 (see on the downloads page). We haven't
>> tested it
>> on JRE 6, so this might be the cause.
>> Please try using another JRE.
>> Alon
>> On 4/12/08 5:33 AM, in article gh7iun$rog$1@build.eclipse.org, "Alan
>>> I'm using JRE 6.
>>> Thanks!
>>> Alan
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
FUDForum. Page generated in 0.03614 seconds
