Home » Archived » BIRT » Rotated axis labels in Windows(Axis labels just showing garbage when rotated)
Rotated axis labels in Windows [message #855041] Tue, 24 April 2012 09:28 Go to next message
Hi there,
I came accross a strange problem. I'm developing an RCP application, which draws a bar chart using the BIRT chartengine. But when I try to rotate the xAxis Labels by 45 degree it displays just garbage under Windows. I've attached two screenshots. Both screenshot use the same data and same birt version.
I just added
xAxis.getLabel().getCaption().getFont().setRotation(45);
to rotate the label.
The same code works fine under linux and macosx. Anyone got any suggestions what I'm doing wrong?
Jens
index.php/fa/8063/0/
index.php/fa/8064/0/
Re: Rotated axis labels in Windows [message #855187 is a reply to message #855041] Tue, 24 April 2012 11:37 Go to previous messageGo to next message
Is this the same issue?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273975
BTW what output format are you using for the chart?
Jason
On 4/24/2012 9:28 AM, Jens öcke wrote:
> Hi there,
> I just added
> Regards
> Jens
Re: Rotated axis labels in Windows [message #855970 is a reply to message #855187] Wed, 25 April 2012 04:49 Go to previous messageGo to next message
I don't think it is the same issue.
I'm rendering direkt to a swt canvas.
Jens
Re: Rotated axis labels in Windows [message #856392 is a reply to message #855970] Wed, 25 April 2012 12:09 Go to previous messageGo to next message
Do you have a sample app that I could run that shows the issue?
Jason
> Jens
Re: Rotated axis labels in Windows [message #856607 is a reply to message #856392] Wed, 25 April 2012 16:42 Go to previous messageGo to next message
I've attached a simple App. It opens a simple Shell and displays a chart. Running on MacOS the bottom Labels are shown. Running on Windows (tested as standalone app, not run from inside eclipse) the bottom labels are just garbage.
Jens
Jason Weathersby wrote on Wed, 25 April 2012 12:09
Jason
> Jens
  • Attachment: TestSrc.zip
    (Size: 61.97KB, Downloaded 282 times)
Re: Rotated axis labels in Windows [message #857637 is a reply to message #856607] Thu, 26 April 2012 14:27 Go to previous messageGo to next message
Can you try adding the font name like:
xAxis.getLabel().getCaption().getFont().setName("Arial");
Jason
On 4/25/2012 4:43 PM, Jens Köcke wrote:
> Jens
>> Jason
>>> Jens
Re: Rotated axis labels in Windows [message #857688 is a reply to message #857637] Thu, 26 April 2012 15:24 Go to previous messageGo to next message
Jason Weathersby wrote on Thu, 26 April 2012 14:27
Thanks! It worked. Is it expected behavior? Did I miss something in the docs?
Jens
Re: Rotated axis labels in Windows [message #857692 is a reply to message #857688] Thu, 26 April 2012 15:29 Go to previous messageGo to next message
No I think this may be a bug with fonts. It would be good if you could
put a bugzilla entry in and put the resolution as well.
Jason
On 4/26/2012 3:24 PM, Jens Köcke wrote:
> docs?
> Regards,
> Jens
Re: Rotated axis labels in Windows [message #857710 is a reply to message #857692] Thu, 26 April 2012 15:50 Go to previous message
Hi Jason,
Jason Weathersby wrote on Thu, 26 April 2012 15:29
I filed the Bug 377825 - Rotated Axis labels get garbled on windows.
Unfortunately I can't post a link. Wink
Jens
Previous Topic:"cant re-generate content for MultiLineItem" exception with Dynamic Text elements
Next Topic:Birt and long integer types in my Data Set
Current Time: Sat Jul 19 22:45:31 EDT 2025
Powered by FUDForum. Page generated in 0.05175 seconds
