Home » Language IDEs » C / C++ IDE (CDT) » Terminate running process
icon5.gif  Terminate running process [message #551388] Fri, 06 August 2010 04:55 Go to next message
I use CDT for C development, and run into the following:
To gracefully stop an application, I use a signal handler to intercept SIGINT. Running the application from a command line works as expected. When ctrl-c is used to stop it, the signal handler is invoked.
But when I run the same application from Eclipse, how can I send the SIGINT? The terminate button apparently sends a SIGKILL (which cannot be intercepted). How can I change this behaviour?
TiA,
Alexander
Re: Terminate running process [message #551487 is a reply to message #551388] Fri, 06 August 2010 11:27 Go to previous messageGo to next message
The eclipse suspend button may do what you want.
If not, then you can always sent a kill -2 to the process from the command line.
Marc
Alexander wrote on Fri, 06 August 2010 04:55
TiA,
Alexander
Re: Terminate running process [message #854756 is a reply to message #551487] Tue, 24 April 2012 04:07 Go to previous messageGo to next message
hm.
thx your answer.
but i still wonder how can i intercept terminate signal by using PDE programing?
i just want to make a PDE-Program which do somthing instead of terminating programe.
in short, when i click "terminate button" which is located upper-side of console view,
the PDE-Program do some work that i want to do .
[Updated on: Tue, 24 April 2012 04:14] by Moderator
Re: Terminate running process [message #855079 is a reply to message #854756] Tue, 24 April 2012 09:56 Go to previous message
I think you would have to extend CDT to change the behavior of the terminate button.
Marc
Previous Topic:How to debug forked processes
Next Topic:Include works, namespace could not be resolved
Current Time: Sun Jul 20 18:27:59 EDT 2025
Powered by FUDForum. Page generated in 0.03678 seconds
