Home » Eclipse Projects » EclipseLink » Setting batch size in EclipseLink 1.1.4
Setting batch size in EclipseLink 1.1.4 [message #854206] Mon, 23 April 2012 15:21 Go to next message
Hi!
I'm working on a project where a number of objects are fetched by creating a query like so:
public List<Regenh> getById(String[] idArray) {
    ReadAllQuery query = new ReadAllQuery(Regenh.class);
    ExpressionBuilder builder = query.getExpressionBuilder();
    Expression expression = builder.get("id").in(idArray);
    query.setSelectionCriteria(expression);
    return (List<Regenh>) entityManager.getActiveSession().executeQuery(query);
The user is allowed to enter 1000 ids in the array, but the default number of parameters that EclipseLink allows in a query using "in" is 256. In EclipseLink 2.1 there's a method called setBatchFetchSize() to tweak this value, but I'm stuck using 1.1.4.
At least I assume that's why I only get 256 objects in my reply, though the full 1000 ids are logged...
21:11:08,728 INFO  [STDOUT] 2012-04-23 21:11:08,728 DEBUG [EL Fine]: Connection(1284726)--SELECT ID, OTYP, STATUS, UUID, AJOURFR, AJOURIR, AVIR, SERVUT FROM SETFR.T01ABC_REGENH WHERE ((ID IN (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)) AND (OTYP <> ?))
	bind => [010000010, 010000026, 010000031, 010000032, 010000037, 010000039, 010000041, 010000065, 010000083, 010000085, 010000101, 010000111, 010000114, 010205776, 010000127, 010000130, 010000141, 010000144, 010000149, 010000159, 010000161, 010000168, 010000175, 010000187, 010000189, 010000197, 010000212, 010000216, 010000230, 010000245, 010000261, 010000265, 010000278, 010000300, 010000303, 010000305, 010000319, 010000328, 010000333, 010000346, 010000355, 010000364, 010000365, 010000368, 010000371, 010000405, 010000411, 010000416, 010000419, 010000421, 010000424, 010000427, 010000437, 010000438, 010000443, 010000469, 010000472, 010000473, 010000474, 010000507, 010000511, 010000516, 010000525, 010000532, 010000533, 010000557, 010000577, 010000581, 010000599, 010000608, 010000617, 010000621, 010000624, 010000631, 010000640, 010000646, 010000651, 010000661, 010000669, 010000670, 010000679, 010000680, 010000681, 010000686, 010000688, 010000715, 010000716, 010000717, 010249195, 010000744, 010000747, 010000759, 010000762, 010000763, 010000780, 010000782, 010000789, 010000791, 010000795, 010000798, 010000799, 010000802, 010000803, 010000817, 010000828, 010000830, 010000833, 010000848, 010000849, 010000859, 010000874, 010000878, 010000881, 010000891, 010000893, 010000921, 010000925, 010000941, 010000947, 010000958, 010000975, 010000992, 010000993, 010001001, 010000006, 010000011, 010000012, 010000023, 010000028, 010000035, 010000038, 010000040, 010000050, 010000051, 010000053, 010000077, 010000091, 010000095, 010000097, 010000098, 010000106, 010000115, 010000126, 010000132, 010000135, 010000136, 010000139, 010000140, 010000154, 010000169, 010000195, 010000204, 010000219, 010000222, 010000225, 010000239, 010000240, 010000252, 010000302, 010342522, 010000332, 010000334, 010000340, 010000342, 010000349, 010000362, 010000367, 010000369, 010000375, 010000377, 010000378, 010000394, 010000399, 010000413, 010000418, 010000430, 010000440, 010000442, 010000455, 010000466, 010000475, 010000477, 010000484, 010000485, 010000488, 010000491, 010000494, 010000495, 010000500, 010000517, 010000522, 010000534, 010000543, 010000550, 010000558, 010000564, 010000568, 010000576, 010000580, 010000602, 010000605, 010000607, 010000620, 010000642, 010000663, 010000664, 010000668, 010000674, 010000683, 010000690, 010000692, 010000702, 010000727, 010000730, 010000736, 010000738, 010000742, 010000743, 010000756, 010000761, 010000764, 010000770, 010000774, 010000783, 010000785, 010000787, 010000788, 010000801, 010000813, 010000821, 010000831, 010000835, 010000839, 010000842, 010000853, 010000860, 010000867, 010000884, 010000898, 010000910, 010000917, 010000924, 010378830, 010426065, 010000946, 010000949, 010000966, 010000976, 010000978, 010000988, 010000991, 010000994, 010000998, 010000016, 010000019, 010000030, 010000042, 010000048, 010000049, 010000062, 010000068, 010000078, 010000081, 010000090, 010000108, 010000112, 010000116, 010000131, 010000134, 010000153, 010000160, 010000162, 010000164, 010000172, 010000185, 010000193, 010000205, 010000206, 010000211, 010000224, 010000232, 010000260, 010000269, 010000276, 010000282, 010000299, 010000304, 010000326, 010000327, 010000341, 010000347, 010000356, 010000360, 010000361, 010000380, 010000381, 010000384, 010000403, 010000428, 010000436, 010000441, 010000446, 010000448, 010000452, 010000459, 010000460, 010000462, 010000463, 010000489, 010000503, 010000506, 010000513, 010000518, 010000523, 010000526, 010000530, 010000537, 010000544, 010000548, 010000562, 010000571, 010000572, 010000583, 010000586, 010000595, 010000606, 010000614, 010000615, 010000622, 010000623, 010000625, 010000629, 010000639, 010000654, 010000689, 010000693, 010000695, 010000705, 010000726, 010000754, 010000755, 010000768, 010000776, 010000777, 010000778, 010000786, 010000796, 010000804, 010000806, 010000807, 010000819, 010000832, 010000834, 010000836, 010000843, 010000846, 010000847, 010000854, 010000857, 010000875, 010000879, 010000880, 010000887, 010000904, 010000912, 010000919, 010000930, 010415647, 010000940, 010000944, 010000964, 010000968, 010000971, 010000989, 010000020, 010000021, 010000022, 010000029, 010000034, 010000043, 010000054, 010000060, 010000063, 010000064, 010000070, 010000076, 010000080, 010000082, 010000086, 010000105, 010000107, 010000109, 010000113, 010000117, 010000129, 010000137, 010000146, 010000150, 010000155, 010000157, 010000166, 010000167, 010000171, 010000174, 010000177, 010000181, 010000190, 010000194, 010000196, 010000202, 010000207, 010000210, 010000218, 010000223, 010000231, 010000237, 010000246, 010000250, 010000253, 010000258, 010000267, 010000279, 010000289, 010000290, 010000293, 010000318, 010000323, 010000324, 010000335, 010000348, 010000350, 010000353, 010000354, 010000363, 010000382, 010000391, 010000398, 010000400, 010000404, 010000406, 010000417, 010000420,
21:11:08,728 INFO  [STDOUT] 010000426, 010000431, 010000439, 010000445, 010000447, 010000454, 010000461, 010000480, 010000483, 010000499, 010000501, 010000502, 010000504, 010000514, 010000524, 010000540, 010000541, 010000546, 010000551, 010000565, 010000578, 010000582, 010000588, 010000603, 010000635, 010000650, 010000657, 010000694, 010000703, 010000707, 010000710, 010000712, 010000760, 010000781, 010000810, 010000814, 010000815, 010000824, 010000827, 010000841, 010000845, 010000862, 010000864, 010000865, 010000872, 010000873, 010000877, 010000889, 010000890, 010000894, 010000901, 010000905, 010000906, 010000916, 010000928, 010233887, 010129601, 010000957, 010000962, 010000970, 010000987, 010000995, 010000999, 010001000, 010000001, 010000002, 010000004, 010000005, 010000007, 010000014, 010000017, 010000024, 010000046, 010000067, 010000071, 010000092, 010000094, 010000096, 010000099, 010000102, 010000104, 010000110, 010000123, 010000128, 010000133, 010000142, 010000145, 010000152, 010000165, 010000176, 010000180, 010000191, 010000199, 010000203, 010000208, 010000228, 010000234, 010000238, 010000248, 010000257, 010000264, 010000271, 010000272, 010000275, 010000283, 010000286, 010000288, 010000301, 010000306, 010000307, 010000311, 010000315, 010000320, 010513071, 010000351, 010000352, 010000366, 010000373, 010000383, 010000393, 010000401, 010000409, 010000410, 010000412, 010000414, 010000415, 010000450, 010000451, 010000453, 010000467, 010000468, 010000470, 010000481, 010000496, 010000512, 010000515, 010000519, 010000521, 010000535, 010000539, 010000560, 010000563, 010000574, 010000575, 010000592, 010000597, 010000601, 010000604, 010000612, 010000626, 010000630, 010000632, 010000634, 010000638, 010000641, 010000644, 010000652, 010000665, 010000675, 010000676, 010000697, 010000714, 010000720, 010000722, 010000735, 010000757, 010000765, 010000766, 010000772, 010000779, 010000784, 010000818, 010000822, 010000826, 010000852, 010000856, 010000866, 010000883, 010000886, 010000892, 010000897, 010000909, 010000918, 010000926, 010000927, 010129907, 010184634, 010000960, 010000985, 010000986, 010000009, 010000036, 010000045, 010000052, 010000056, 010000061, 010000069, 010000073, 010000075, 010000084, 010000093, 010000103, 010000118, 010000122, 010000125, 010000138, 010000170, 010000178, 010000182, 010000184, 010000186, 010000213, 010000215, 010000217, 010000226, 010000233, 010000235, 010000241, 010000243, 010000244, 010000247, 010000249, 010000256, 010000266, 010000268, 010000273, 010000277, 010000285, 010000287, 010000292, 010000296, 010000297, 010000308, 010000309, 010000316, 010000325, 010000331, 010000343, 010000386, 010000389, 010000390, 010000392, 010000396, 010000408, 010000478, 010000479, 010000482, 010000492, 010000497, 010000498, 010000509, 010000529, 010000545, 010000552, 010000555, 010000566, 010000567, 010000569, 010000611, 010000613, 010000627, 010000628, 010000633, 010000647, 010000649, 010000671, 010000672, 010000687, 010000699, 010000708, 010000713, 010000719, 010000723, 010000739, 010000740, 010000741, 010000749, 010000751, 010000753, 010000773, 010000792, 010000794, 010000797, 010000805, 010000808, 010000812, 010000820, 010000825, 010000829, 010000838, 010000840, 010000858, 010000861, 010000870, 010000876, 010000888, 010000895, 010000900, 010000902, 010000911, 010000923, 010000929, 010000948, 010000951, 010000952, 010000956, 010000959, 010000965, 010000967, 010000979, 010000984, 010000990, 010000013, 010000018, 010000027, 010000033, 010000044, 010000047, 010000055, 010000072, 010000074, 010000079, 010000087, 010000088, 010000121, 010000148, 010000151, 010000156, 010000158, 010000173, 010000179, 010000188, 010000201, 010000214, 010000220, 010000221, 010000227, 010000229, 010000236, 010000242, 010000254, 010000255, 010000259, 010000274, 010000280, 010000291, 010000298, 010000310, 010000312, 010000313, 010000314, 010000321, 010000322, 010000336, 010000337, 010000338, 010000358, 010000372, 010000374, 010000376, 010000387, 010000388, 010000395, 010000402, 010000407, 010000425, 010000432, 010000435, 010000444, 010000456, 010000457, 010000464, 010000487, 010000490, 010000505, 010000508, 010000520, 010000527, 010000538, 010000542, 010000547, 010000554, 010000570, 010000579, 010000590, 010000593, 010000594, 010000600, 010000618, 010000645, 010000662, 010000666, 010000667, 010000691, 010000696, 010000698, 010000700, 010000704, 010000718, 010000721, 010000725, 010000734, 010000737, 010000745, 010000748, 010000750, 010000758, 010000793, 010000809, 010000811, 010000844, 010000851, 010000855, 010000863, 010000869, 010000896, 010000899, 010000903, 010000914, 010000915, 010244376, 010000942, 010000943, 010000950, 010000961, 010000969, 010000974, 010000980, 010000982, 010000983, 010000997, 010000003, 010000008, 010000015, 010000025, 010000057, 010000058, 010000059, 010000066, 010000089, 010000100, 010000119, 010000124, 010000143, 010000147, 010000163, 010000183, 010000192, 010000198, 010000200, 010000209, 010000251, 010000262, 010000263, 010000270, 010000281, 010000284, 010000294, 010000295, 010000329, 010000330, 010000339, 010131964, 010000357, 010000359, 010000370, 010000379, 010000385, 010000397, 010000422, 010000423, 010000429, 010000433, 010000434, 010000449, 010000458, 010000465, 010000471, 010000476, 010000486, 010000493, 010000510, 010000528, 010000531, 010000536, 010000549, 010000553, 010000556, 010000559, 010000561, 010000573, 010000584, 010000585, 010000587, 010000589, 010000591, 010000596, 010000598, 010000609, 010000610, 010000616, 010000619, 010000636, 010000637, 010000643, 010000648, 010000653, 010000655, 010000656, 010000658, 010000659, 010000660, 010000673, 010000677, 010000678, 010000682, 010000684, 010000685, 010000701, 010000706, 010000709, 010000711, 010000724, 010000728, 010000729, 010279363, 010000733, 010000746, 010000752, 010000767, 010000769, 010000771, 010000775, 010000790, 010000800, 010000816, 010000823, 010000837, 010000850, 010000868, 010000871, 010000882, 010000885, 010000907, 010000908, 010000913, 010000920, 010000922, 010421388, 010000945, 010000953, 010000954, 010000955, 010000963, 010000972, 010000973, 010000977, 010000981, 01C] at ?.?(?:?)
Please help!
Re: Setting batch size in EclipseLink 1.1.4 [message #854834 is a reply to message #854206] Tue, 24 April 2012 05:15 Go to previous messageGo to next message
I did a trial without using EclipseLink and I got the same result. This seems to be an issue with the Oracle JDBC driver, specifically prepared statements.
Re: Setting batch size in EclipseLink 1.1.4 [message #857386 is a reply to message #854206] Thu, 26 April 2012 09:48 Go to previous message
This is a database limitation. You need to reduce the size and execute multiple queries.
Previous Topic:jpa primary key violation when persisting many-to-many columns
Next Topic:Madness with compound primary key
Current Time: Sat Jul 19 15:42:50 EDT 2025
Powered by FUDForum. Page generated in 0.07659 seconds
