Home » Eclipse Projects » Remote Application Platform (RAP) » PDE incubator: patch proposal
PDE incubator: patch proposal [message #851101] Fri, 20 April 2012 12:48 Go to next message
Hello RAP team,
For some reasons, It was useful for me to have plugin-spy in my RAP application.
Also I prefered the way PDE is bundled in RCP (2 bundles 1 for error log, other for plugin-registry and plugin-spy), because it could be useful to add Error log without Plugin registry and plugin-spy, so I decided to port last version of PDE runtime.
If it makes sense for you I can create a bug to share this work.
If you want to have a look, you will find the 2 bundles attached here.
(It contains also fix and improvements described in 347957)
Arnaud
  • Attachment: pde.zip
    (Size: 410.15KB, Downloaded 206 times)
[Updated on: Sat, 21 April 2012 02:11] by Moderator
Re: PDE incubator [message #852983 is a reply to message #851101] Sun, 22 April 2012 11:01 Go to previous messageGo to next message
Hi Arnaud,
thanks for sharing your work! I don't think that bugzilla is a good
place to store it because it's hard to find the code there, and in case
of updates or improvements, we'd end up with a lot of attachments.
The best place to share code is a public repository. Why don't you
create one at github? This would allow others to update, extend and
comment on your code. If you like, we could also link to it from the RAP
project page.
If you'd like to contribute it to Eclipse, and continue to maintain the
code there, it may also become a part of the Eclipse incubator. But a
github repository would be a good start.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: PDE incubator [message #853679 is a reply to message #852983] Mon, 23 April 2012 04:24 Go to previous messageGo to next message
I have created a github repo :
git://github.com/amergey/pde-rap-port.git
If you think there are interests for this, I'd like to contribute it to eclipse and of course I can continue to maintain the code.
Arnaud
Re: PDE incubator [message #854816 is a reply to message #853679] Tue, 24 April 2012 04:58 Go to previous messageGo to next message
Hi Arnaud,
Great, thanks. The RAP Incubator project is going to switch to git in
the next weeks. After this, we should think about bringing your port
into the incubator. Are you already an Eclipse committer?
Regards, Ralf
Ralf Sternberg
Re: PDE incubator [message #854875 is a reply to message #854816] Tue, 24 April 2012 06:13 Go to previous message
Hi Ralf,
I am not an eclipse committer.
Arnaud
Previous Topic:Integrating Eclipse Problems View in RAP application?
Next Topic:Configuration parameters
Current Time: Sat Jul 19 16:15:39 EDT 2025
Powered by FUDForum. Page generated in 0.07879 seconds
