Home » Language IDEs » C / C++ IDE (CDT) » Errors when attempting to build C++ project
icon9.gif  Errors when attempting to build C++ project [message #844012] Fri, 13 April 2012 11:47 Go to next message
When building a project for the first time since launching Eclipse, it builds successfully.
However, when trying to build the next time, I get:
Errors occurred during the build.
Errors running builder 'CDT Builder' on project '<PROJECT NAME>'.
java.lang.IllegalArgumentException
Where <PROJECT NAME> is as it sounds.
As a workaround, I find that right clicking on the .cpp source file in project manager, Properties > C/C++ Build and clicking 'apply defaults', and then retrying the build will work. But you need to keep repeating this process every time you wish to build.
I am running Eclipse Indigo under Ubuntu Oneiric 11.10.
Anyone know if this is just a bug, or how it can be corrected?
Any help would be much appreciated.
Re: Errors when attempting to build C++ project [message #852545 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Can you post the full call stack of the exception? It should be in the Error log. Which version of CDT are you using? There is a bug in 8.0.2 when you try to build a second time a project that contains special characters, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=377295
Re: Errors when attempting to build C++ project [message #852546 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852553 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852554 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852558 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852559 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852563 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852564 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852568 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852569 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852575 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852576 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852582 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852583 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852590 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852591 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852598 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852599 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852606 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852607 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852614 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #852615 is a reply to message #844012] Sun, 22 April 2012 00:57 Go to previous messageGo to next message
Re: Errors when attempting to build C++ project [message #866479 is a reply to message #852545] Mon, 30 April 2012 18:42 Go to previous messageGo to next message
I am having this same problem and it is extremely frustrating, what exactly do I need to post?
regards,
Chris
Re: Errors when attempting to build C++ project [message #866550 is a reply to message #866479] Mon, 30 April 2012 19:33 Go to previous messageGo to next message
Chris Conrad wrote on Mon, 30 April 2012 18:42
Check the error log for errors and paste the errors here. To open the Error log, click on Window -> Show view -> Error log (it might be in Others...)
Re: Errors when attempting to build C++ project [message #869093 is a reply to message #844012] Wed, 02 May 2012 20:04 Go to previous messageGo to next message
I have the same problem.
Log
at java.net.URI.create(Unknown Source)
at java.net.URI.resolve(Unknown Source)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.getArtifactTimeStamp(AdditionalInput.java:376)
at org.eclipse.cdt.managedbuilder.internal.core.AdditionalInput.needsRebuild(AdditionalInput.java:337)
at org.eclipse.cdt.managedbuilder.internal.core.InputType.needsRebuild(InputType.java:1619)
at org.eclipse.cdt.managedbuilder.internal.core.Tool.needsRebuild(Tool.java:3307)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.needsRebuild(ToolChain.java:2068)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.saveRebuildState(ToolChain.java:2101)
at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.setRebuildState(ToolChain.java:2085)
at org.eclipse.cdt.managedbuilder.internal.core.FolderInfo.setRebuildState(FolderInfo.java:355)
at org.eclipse.cdt.managedbuilder.internal.core.Configuration.setRebuildState(Configuration.java:1726)
at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:760)
at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:504)
at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:450)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513)
at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:432)
at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:305)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.net.URISyntaxException: Illegal character in path at index 6: Prueba 8.exe
at java.net.URI$Parser.fail(Unknown Source)
at java.net.URI$Parser.checkChars(Unknown Source)
at java.net.URI$Parser.parseHierarchical(Unknown Source)
at java.net.URI$Parser.parse(Unknown Source)
at java.net.URI.<init>(Unknown Source)
... 28 more
Re: Errors when attempting to build C++ project [message #869172 is a reply to message #869093] Wed, 02 May 2012 23:06 Go to previous message
Diego Castillo wrote on Wed, 02 May 2012 20:04
Log
This is indeed bug 377295, it's fixed in the next version (8.1).
You can get a nighly build of 8.1.0 with this update site:
http://download.eclipse.org/tools/cdt/builds/juno/nightly
You will need Eclipse 3.8 or 4.2 to install CDT 8.1.
Previous Topic:Indexer problem with typedef for iterator and std::vector::insert
Next Topic:[Windows] application running on external cmd.exe command prompt
Current Time: Sat Jul 19 10:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.09493 seconds
