Home » Language IDEs » C / C++ IDE (CDT) » Program terminated without execution(C++ Programming in Eclipse)
Program terminated without execution [message #848721] Wed, 18 April 2012 10:12 Go to next message
Hy!
I have a problem with a C++ project made in Eclipse for C++.
When I want to run the project it displays the next message:
<terminated>program.exe[C/C++ Application] program.exe
on the top of the Console window.
I have to mention that I am using 'gsl' library, which
I included in Libraries and Library Path, but when I want to
run the executable, it displays the error:
"The program can't start because libgsl.dll is missing
from your computer. Try reinstalling the program to fix this problem."
Does anyone had the same error? If so, how did you solved?
Thanks!
Adrian
Re: Program terminated without execution [message #849615 is a reply to message #848721] Thu, 19 April 2012 05:51 Go to previous messageGo to next message
Adrian Adrian89 wrote on Wed, 18 April 2012 16:12
Hy!
Thanks!
Adrian
Copy libgsl.dll into the folder with your executable.
Re: Program terminated without execution [message #849682 is a reply to message #849615] Thu, 19 April 2012 07:16 Go to previous messageGo to next message
Thanks for your reply.
I succeded to run the executable. I included the library's path in the Windows Path.
But the first problem still persists, I can't run the project. It is the same error: program terminated...
Re: Program terminated without execution [message #849689 is a reply to message #849682] Thu, 19 April 2012 07:21 Go to previous message
Adrian Adrian89 wrote on Thu, 19 April 2012 13:16
Did you restart Eclipse after changing the environment variable?
Previous Topic:Debug-Output of e.g. Qt-Types
Next Topic:ambiguous unresolved functions
Current Time: Sat Jul 19 11:25:56 EDT 2025
Powered by FUDForum. Page generated in 0.05905 seconds
