Home » Language IDEs » C / C++ IDE (CDT) » [SOLVED]Single source file no longer has syntax highlighting, code traversal features.
[SOLVED]Single source file no longer has syntax highlighting, code traversal features. [message #848813] Wed, 18 April 2012 11:47 Go to next message
I am running Eclipse Indigo on Centos 5.7 working on a pretty large scale c++ Project. One of my central source files stopped getting any syntax highlighting. I also can no longer right click on an object and see the decleration, and it no longer highlights other occurrences of functions,objects etc... in the file. The file is fairly large (about 8300 lines) and the comments get highlighted, but nothing else
it is in the included resources of the project. I have done the standard close and reopen. reboot the pc etc.
I have to work through this file quite a bit so not having the eclipse features slows me down a bit.
[Updated on: Wed, 18 April 2012 12:26] by Moderator
Re: Single source file no longer has syntax highlighting, code traversal features. [message #848844 is a reply to message #848813] Wed, 18 April 2012 12:24 Go to previous messageGo to next message
It seems like this isn't limited to one source file, I'm having this issue with any file >8000 lines of code
Re: Single source file no longer has syntax highlighting, code traversal features. [message #848845 is a reply to message #848844] Wed, 18 April 2012 12:26 Go to previous message
Aaaand the problem was scalability was turned on. My mistake.
Previous Topic:java
Next Topic:Download the org.eclipse.cdt.ui.tests project
Current Time: Sun Jul 20 18:46:02 EDT 2025
Powered by FUDForum. Page generated in 0.24270 seconds
