Home » Modeling » TMF (Xtext) » how to unit test of generator(how to unit test of generator)
how to unit test of generator [message #840721] Tue, 10 April 2012 08:47 Go to next message
I am writing unit tests for my DSL. There is no problem with testing of scopes & validator, there is documentation for this on the XText webpage.
There is one more thing, which I would like to test: code generator... I have not found any how-to in this field.
My generator is written according to http://www.eclipse.org/Xtext/documentation/2_1_0/040-first-code-generator.php .
Is there any simple way to test generator output?
Thank you,
Michal
Re: how to unit test of generator [message #840754 is a reply to message #840721] Tue, 10 April 2012 09:30 Go to previous messageGo to next message
Simply call it with a test resource and a InMemoryFileSystemAccess
doesn't work?
Re: how to unit test of generator [message #840787 is a reply to message #840754] Tue, 10 April 2012 10:09 Go to previous messageGo to next message
Michal,
I'm using Xtend to test the generator because the syntax is much more simple.
In principle you can simply @Inject the generator and call
InMemoryFileSystemAccess fsa = new InMemoryFileSystemAccess();
generator.doGenerate( resource, fsa );
I've written a GeneratorHelper that works along the same lines as the ParseHelper.
Christian, I'm willing to contribute this code because it makes testing very simple:
	@Test
	def void testMissingID() {
		parser.input('''
			options {
				inline: true
			base-language de {}
		.expectError( "ERROR:Missing option 'id' (test.i18n line : 1)" )
	@Test
	def void testLocalizedFormatter() {
		val model = parser.input(
			options {
				inline: true
			formatter-definitions {
				yyyymmdd: DateFormatter( yyyymmdd )
			base-language en {
				yyyymmdd: "yyyy-MM-dd"
			''').uri( "test/Formatters.i18n" ).parse()
		"DateFormatter".assertEquals( model.formatterDefinitions.get( 0 ).type )
	@Test
	def void testSimpleInput() {
		val model = generator.parse(
			options {
				/** id comment */
				inline: true
			base-language en {
				/** Test for comments */
				comment: "This message has a comment"
			''', URI::createURI( "test/SimpleInput.i18n" ) )
		generator.generate( model )
		generator.assertEquals( "PROPERTIEStest/SimpleInput.properties",
"# Generated from platform:/resource/com.avanon.eclipse.i18n_dsl.demo/src/main/resources/test/SimpleInput.i18n
test.SimpleInput.comment=This message has a comment
Is there a chance to get that into Xtext?
Re: how to unit test of generator [message #840794 is a reply to message #840787] Tue, 10 April 2012 10:13 Go to previous messageGo to next message
Simply file an enhancement request with the code attached
Re: how to unit test of generator [message #841375 is a reply to message #840794] Wed, 11 April 2012 04:17 Go to previous messageGo to next message
Thank you gentlemen,
InMemoryFileSystemAccess class was the information, which I missed before...
Hopefully, I will be able to manage now.
Michal
Re: how to unit test of generator [message #847635 is a reply to message #840754] Tue, 17 April 2012 09:59 Go to previous messageGo to next message
I have tried following:
@Inject MyDslGenerator generator
@Inject Provider<XtextResourceSet> resourceSetProvider
val resource = resourceSetProvider.get.createResource(URI::createFileURI("xyz.mydsl"))
generator.doGenerate(resource,fsa)
When I debug the test, my doGenerate method is called. Problem is, that resource.getAllContents() is empty and therefore nothing is generated.
When I try to do this in my runtime of Eclipse (with copy of the same file), resource.getAllContents() is not empty and generator works.
What am I doing wrong?
Thank you & Best regards,
Michal
Re: how to unit test of generator [message #847680 is a reply to message #847635] Tue, 17 April 2012 10:47 Go to previous messageGo to next message
please Post a complete test file
Re: how to unit test of generator [message #847687 is a reply to message #847635] Tue, 17 April 2012 11:00 Go to previous messageGo to next message
Btw you never call resource.load
Re: how to unit test of generator [message #847688 is a reply to message #847680] Tue, 17 April 2012 11:03 Go to previous messageGo to next message
My test file is as follows:
@RunWith(typeof(XtextRunner))
@InjectWith(typeof(MyDslInjectorProvider))
class GeneratorTest {
	@Inject
	ParseHelper<MyDslFramework> parser
	@Inject
	@Inject
	@Test
	def testX(){
		val resource =resourceSetProvider.get.createResource(URI::createFileURI("xyz.mydsl"))
(I understand, that I do not test anything there. I need to get something generated first...)
Thank you,
Michal
Re: how to unit test of generator [message #847697 is a reply to message #847688] Tue, 17 April 2012 11:09 Go to previous messageGo to next message
http://wiki.eclipse.org/Xtext/FAQ#How_do_I_load_my_model_in_a_standalone_Java_application.C2.A0.3F
Re: how to unit test of generator [message #847809 is a reply to message #847697] Tue, 17 April 2012 13:18 Go to previous messageGo to next message
Thank you Christian, now my tests are working...
Michal
Re: how to unit test of generator [message #870536 is a reply to message #847809] Tue, 08 May 2012 11:08 Go to previous messageGo to next message
Hello Michal,
can you share our complete, working Text.xtend file? (also with imports please) i have some fundamental problems with my generator unit test.
best regards
Re: how to unit test of generator [message #870571 is a reply to message #870536] Tue, 08 May 2012 15:15 Go to previous messageGo to next message
you question inspired me to this blog post: http://christiandietrich.wordpress.com/2012/05/08/unittesting-xtend-generators/
~Christian
Re: how to unit test of generator [message #1790233 is a reply to message #870571] Thu, 07 June 2018 06:14 Go to previous messageGo to next message
Hi Christian
The above link is out of date.
Do you have a working link to that blog post?
Re: how to unit test of generator [message #1790246 is a reply to message #1790233] Thu, 07 June 2018 07:17 Go to previous message
https://dietrich-it.de/xtext/generator/tests/2012/05/08/unittesting-xtend-generators.html
Previous Topic:LanguageServer with Apache HTTP Client, endless wait on read
Next Topic:Scoping on an external EMF Model
Current Time: Sat Jul 19 20:15:52 EDT 2025
Powered by FUDForum. Page generated in 0.49046 seconds
