Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT performance on drawing text (compare with Swing, sample code provided)
SWT performance on drawing text (compare with Swing, sample code provided) [message #846702] Mon, 16 April 2012 06:03 Go to next message
All,
A classic question but it really surprise me for the difference in numbers.
Attached simple tests in Swing and SWT, drawing text with random fonts
1000 times.
SWT (gc.advance off)
~80ms for every 1000 text drawn
SWT (gc.advance on)
~200ms for every 1000 text drawn
Swing (with Anti-aliasing hints on)
~30ms for every 1000 text drawn
Config:
Win7
Java 1.6_25
SWT org.eclipse.swt.win32.win32.x86_3.7.1.v3738a.jar
Thanks for you all.
import java.io.IOException;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Drawable;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class SWTTest {
public static void main(String[] args) throws IOException {
Display display = new Display ();
Shell shell = new Shell(display);
shell.setBounds(0, 0, 500, 500);
shell.open();
drawshit(shell);
while (!shell.isDisposed ()) {
if (display.readAndDispatch ())
drawshit(shell);
else
display.sleep ();
display.dispose ();
//AWT
AWTTest test = new AWTTest();
System.in.read();
private static void drawshit(Shell shell) {
if(!shell.isDisposed())
GC gc = new GC(shell);
Rectangle bounds = shell.getBounds();
long start = System.nanoTime();
for(int i=0;i<1000;i++)
//try various different things here, e.g. drawing lines, rectangles, cacheing fonts etc.
Font font = new Font(gc.getDevice(), new FontData("Tahoma", (int) (Math.random()*30), SWT.NORMAL));
gc.setFont(font);
gc.drawText("Hello World", (int) (Math.random()*400), (int)(Math.random()*400));
font.dispose();
long stop = System.nanoTime();
gc.dispose();
System.out.println("SWT time: " + (stop-start)/1000000 + " ms" );
import java.awt.Color;
import java.awt.Font;
import java.awt.Frame;
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.Label;
import java.awt.RenderingHints;
import java.awt.event.MouseEvent;
import java.awt.event.MouseListener;
import java.awt.event.WindowEvent;
import java.awt.event.WindowListener;
public class AWTTest extends Frame implements MouseListener, WindowListener {
new AWTTest();
public AWTTest() {
Label hello = new Label("Hello World");
add(hello, "Center");
setSize(500,500);
setVisible(true);
addMouseListener(this);
addWindowListener(this);
public void paint(Graphics g) {
super.paint(g);
Graphics2D g2d = (Graphics2D) g;
//SWT Default font:
//[1|Tahoma|8.25|0|WINDOWS|1|-11|0|0|0|400|0|0|0|1|0|0|0|0|Tahoma]
g2d.setBackground(Color.GRAY);
g2d.clearRect(0, 0, 500, 500);
g2d.setRenderingHint(RenderingHints.KEY_TEXT_ANTIALIASING, RenderingHints.VALUE_TEXT_ANTIALIAS_ON);
g2d.setFont(new Font("Tahoma", Font.PLAIN, (int) (Math.random()*30)));
g2d.drawString("Hello World", (int) (Math.random()*400), (int)(Math.random()*400));
System.out.println("AWT time: " + (stop-start)/1000000 + " ms" );
public void mouseEntered(MouseEvent e) {
public void mouseClicked(MouseEvent e) {
this.paintAll(getGraphics());
public void mouseExited(MouseEvent e) {
public void mousePressed(MouseEvent e) {
public void mouseReleased(MouseEvent e) {
public void windowActivated(WindowEvent e) {
public void windowClosed(WindowEvent e) {
public void windowClosing(WindowEvent e) {
System.exit(0);
public void windowDeactivated(WindowEvent e) {
// TODO Auto-generated method stub
public void windowDeiconified(WindowEvent e) {
public void windowIconified(WindowEvent e) {
public void windowOpened(WindowEvent e) {
  • Attachment: SWTTest.java
    (Size: 1.53KB, Downloaded 254 times)
  • Attachment: AWTTest.java
    (Size: 2.40KB, Downloaded 198 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #846740 is a reply to message #846702] Mon, 16 April 2012 10:33 Go to previous messageGo to next message
Probably most of the cost is creating the fonts. You'd never create
fonts and then not dispose them in this way for SWT. You're run out of
handles with that approach.
On 16/04/2012 12:03 PM, Leung Wang Hei wrote:
> All,
> numbers.
> 1000 times.
> SWT (gc.advance on)
> Config:
> Win7
> Java 1.6_25
> Thanks for you all.
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847216 is a reply to message #846740] Tue, 17 April 2012 01:18 Go to previous messageGo to next message
i changed the SWT code to proper useage of the fonts (create fonts before doing the test and disposing it afterwards.
results here are:
SWT time: 74 ms
AWT time: 137 ms
AWT time: 75 ms
note that i have a crappy old "Pentium D" cpu Wink
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847507 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
Like you said, I moved font creation/disposal out of the drawing loop.
I am able to lower the SWT time from 80ms to 60ms (25%-)
but still AWT gives me less than 30ms.
What am I missing here?
Ludwig, should your middle "AWT time: 137 ms" be "SWT time: 137 ms" ?
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
> note that i have a crappy old "Pentium D" cpu ;)
package SWT.vs.J2D;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
private static Font font;
Display display = new Display();
shell.open();
font = new Font(display, new FontData("Tahoma", (int) (Math.random() * 30), SWT.NORMAL));
shell.addPaintListener(new PaintListener() {
public void paintControl(PaintEvent e) {
drawshit(e.gc);
// drawshit(shell);
while (!shell.isDisposed()) {
if (display.readAndDispatch()) {
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
// private static void drawshit(Shell shell) {
private static void drawshit(GC gc) {
// if (!shell.isDisposed()) {
// GC gc = new GC(shell);
// Rectangle bounds = shell.getBounds();
for (int i = 0; i < 1000; i++) {
// try various different things here, e.g. drawing lines, rectangles, cacheing fonts etc.
gc.setFont(font);
gc.drawText("Hello World", (int) (Math.random() * 400), (int) (Math.random() * 400));
// gc.dispose();
System.out.println("SWT time: " + (stop - start) / 1000000 + " ms");
    (Size: 1.73KB, Downloaded 209 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847511 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 191 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847515 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 211 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847520 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 281 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847525 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 215 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847529 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 232 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847533 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 200 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847537 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 233 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847541 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847548 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 196 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847553 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847560 is a reply to message #847216] Tue, 17 April 2012 07:29 Go to previous messageGo to next message
> results here are:
> SWT time: 74 ms
> AWT time: 137 ms
> AWT time: 75 ms
package SWT.vs.J2D;
shell.open();
drawshit(e.gc);
// drawshit(shell);
// drawshit(shell);
else {
display.sleep();
font.dispose();
display.dispose();
// AWT
System.in.read();
gc.setFont(font);
// gc.dispose();
    (Size: 1.73KB, Downloaded 260 times)
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #847561 is a reply to message #846740] Tue, 17 April 2012 07:34 Go to previous messageGo to next message
I think font is disposed right after drawing the text.
You are right, normally font and colour should be cached. However, for
this particular text drawing test, the time difference is really
disappointing.
even with Ludwig's change, the SWT test is still 2 times slower than
AWT, at least apparently.
I got a sense that something is missing. Else there is no point for
anybody using SWT. What's missing?
>> All,
>> numbers.
>> 1000 times.
>> SWT (gc.advance on)
>> Config:
>> Win7
>> Java 1.6_25
>> Thanks for you all.
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #848196 is a reply to message #847507] Tue, 17 April 2012 22:31 Go to previous messageGo to next message
Some suggested ClearType in Win7 added extra penalty. Sadly, turning
that off gives no obvious improvement (still ~60ms for SWT)
I understand SWT is based on a very different design with AWT and my
measuring is properly not valid on non-Window OS.
Even so, does it imply there is some unavoidable slowness when using SWT
on Win?
In another word, what would be a "more fair" testing code for SWT and AWT?
Greatly appreciated for any advice. This problem really frustrated me.
On 4/17/2012 7:29 PM, Leung Wang Hei wrote:
> Like you said, I moved font creation/disposal out of the drawing loop. I
>> results here are:
>> SWT time: 74 ms
>> AWT time: 137 ms
>> AWT time: 75 ms
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #848356 is a reply to message #848196] Wed, 18 April 2012 02:33 Go to previous messageGo to next message
i cant reproduce your 'swt is slower'
SWT time: 74 ms
AWT time: 137 ms
AWT time: 75 ms
says swt is about the same speed as AWT... if its done right with the font management.
you cant compare your testing results with mine as your computer seems (way) faster than mine
what i did was creating a cache for 1000 fonts, generate the fonts. (app init)
then render the swt
then dispose the fonts again (when app terminates)
nope, there seems one swt test and two awt tests from your example (at least thats what i got on output)
so average AWT time was 106ms
swt time was 74ms
-- for 1000 drawings
NOTE: i only edited the SWT code...
[Updated on: Wed, 18 April 2012 02:34] by Moderator
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #848397 is a reply to message #848196] Wed, 18 April 2012 03:24 Go to previous messageGo to next message
SWT uses native widgets, whereas swing/awt draws everything on their
own, the thing here is that even if SWT-Drawing is not as fast as
AWT-drawing this doesn't really hurt SWT-UIs because most of the UI is
anways made up of native controls.
Tom
Am 18.04.12 04:31, schrieb Leung Wang Hei:
> on Win?
>>> results here are:
>>> SWT time: 74 ms
>>> AWT time: 137 ms
>>> AWT time: 75 ms
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #849556 is a reply to message #848397] Thu, 19 April 2012 04:51 Go to previous messageGo to next message
You are right Tom. The problem is we are heavily using canvas (KTable
in precise), which goes back to the plain drawing function of SWT.
> Tom
>> on Win?
>>>> results here are:
>>>> SWT time: 74 ms
>>>> AWT time: 137 ms
>>>> AWT time: 75 ms
Re: SWT performance on drawing text (compare with Swing, sample code provided) [message #849572 is a reply to message #849556] Thu, 19 April 2012 05:06 Go to previous message
we are using NatTable because (in my test) it gave me better performance than any other table we tested.
did you check NatTable?
Previous Topic:SWT Canvas randomly expanding composite
Next Topic:Embedding QT widgets in SWT
Current Time: Sat Jul 19 17:29:07 EDT 2025
Powered by FUDForum. Page generated in 0.06830 seconds
