Home » Eclipse Projects » Remote Application Platform (RAP) » Manipulate Composite/View dynamically(Refreshing/Redrawing the UI by force)
Manipulate Composite/View dynamically [message #845027] Sat, 14 April 2012 13:03 Go to next message
Im stuck to a problem I couldn't find a solution for. Following scenario:
I have a viewpart or composite that is created when the application is started. Everything works fine but now I want to add a new gui item (e.g. labels or other composites) to the view/composite when the user clicks on a button.
How can I achieve this goal? Everything I tried didn't work. I could just see something *new* when I refreshed the application by pressing f5 in the browser. I guess RAP renders the ui once when it's initialized. Is there a workaround for? It is possible to force RAP to refresh/redraw the ui?
Hope you can help me Smile
Sincerely
Superhans
Re: Manipulate Composite/View dynamically [message #846695 is a reply to message #845027] Mon, 16 April 2012 05:09 Go to previous messageGo to next message
Hi Superhans,
Widgets that are added in direct response to a user interaction are
rendered immediately. But without re-layouting they will not become
visible. Try to call layout() on the widget's parent after adding.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Manipulate Composite/View dynamically [message #848799 is a reply to message #846695] Wed, 18 April 2012 11:32 Go to previous message
hi,
thanks it worked!
Previous Topic:oeju.UrlEncoded:maxFormKeys limit exceeded keys>1000
Next Topic:Strange behavior with CLabel and his client area
Current Time: Sun Jul 20 12:36:53 EDT 2025
Powered by FUDForum. Page generated in 0.03369 seconds
