Home » Eclipse Projects » Remote Application Platform (RAP) » RAP application with XWT(NoClassDefFoundError on XWTLoader due to org.eclipse.swt.widgets.Caret class)
RAP application with XWT [message #846236] Sun, 15 April 2012 18:43 Go to next message
Hi all,
I am trying to use XWT on a RAP Application but even though bug 298589 makes you think it is possible and already integrated into main XWT codeline XWTLoader makes reference to Caret class on SWT which in turn is unavailable on RWT.
Am I missing something?
I've created an application based on RAP E-Mail sample and changed the View to use XWT...
Manifest.MF is as follows:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Teste_rap
Bundle-SymbolicName: teste_rap; singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: teste_rap.Activator
Require-Bundle: org.eclipse.rap.ui,
 org.eclipse.rap.jface.databinding;bundle-version="1.5.0",
 org.eclipse.core.databinding;bundle-version="1.4.1",
 org.eclipse.rap.rwt.osgi;bundle-version="1.5.0"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Import-Package: javax.servlet;version="2.4.0",
 javax.servlet.http;version="2.4.0"
Bundle-ClassPath: .,
 org.pushingpixels.trident_1.2.0.v20100204-1500.jar,
 org.eclipse.e4.xwt_0.9.1.SNAPSHOT.jar,
 org.eclipse.e4.xwt.forms_0.9.1.SNAPSHOT.jar
and when the application is launched the following stacktrace is thrown:
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Caret
	at org.eclipse.e4.xwt.XWTLoader.initialize(XWTLoader.java:1318)
	at org.eclipse.e4.xwt.XWTLoader.<init>(XWTLoader.java:179)
	at org.eclipse.e4.xwt.XWTLoaderManager.<clinit>(XWTLoaderManager.java:19)
	at org.eclipse.e4.xwt.XWT.setLoadingContext(XWT.java:679)
	at teste_rap.View.createPartControl(View.java:28)
	at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:599)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:318)
	at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:542)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
	at org.eclipse.rap.internal.design.example.stacks.ViewStackPresentation.selectPart(ViewStackPresentation.java:1024)
	at org.eclipse.rap.ui.interactiondesign.internal.ConfigurableStackProxy.selectPart(ConfigurableStackProxy.java:425)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1262)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1215)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1614)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:659)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:585)
	at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:573)
	at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:269)
	at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:980)
	at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2627)
	at org.eclipse.ui.internal.WorkbenchWindow$26.run(WorkbenchWindow.java:3077)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
	at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3058)
	at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:763)
	at org.eclipse.ui.internal.Workbench$18.runWithException(Workbench.java:1267)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:229)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:1061)
	at org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExceptions(StartupThreading.java:55)
	at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Workbench.java:1263)
	at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Workbench.java:2062)
	at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbench.java:1993)
	at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWindow(WorkbenchConfigurer.java:188)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:790)
	at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1641)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1636)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2655)
	at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
	at teste_rap.Application.start(Application.java:18)
	at org.eclipse.rap.ui.internal.application.EntryPointApplicationWrapper.createUI(EntryPointApplicationWrapper.java:38)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:177)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:289)
	at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:101)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Caret
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 56 more
2012-04-15 19:31:59.349:WARN:oejs.ServletHandler:ERROR:  Error for /mail;jsessionid=1trgfox25yop81fleechcz4c5v
java.lang.Error: Unable to load View.xwt
	at teste_rap.View.createPartControl(View.java:33)
Caused by:
Caused by:
What am I doing wrong?
best regards,
Rafael
Re: RAP application with XWT [message #846693 is a reply to message #846236] Mon, 16 April 2012 04:19 Go to previous message
Rafael,
I haven't tried XWT on RAP myself, but from reading the bug and its
status it appears to have worked once.
I'd suggest to re-open bug 298589 with the information you provided here.
Rüdiger
On 16.04.2012 00:43, Rafael Ribeiro wrote:
> Hi all,
> Am I missing something? I've created an application based on RAP E-Mail
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 56 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Caret
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> best regards,
> Rafael
Rüdiger Herrmann
http://codeaffine.com
Previous Topic:Text widget, key event and caret position
Next Topic:Simple non-UI object example
Current Time: Sun Jul 20 07:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.03067 seconds
