Home » Modeling » EMF » Workspace Resource with EMF Objects
Workspace Resource with EMF Objects [message #841709] Wed, 11 April 2012 12:47 Go to next message
I have the following problem. I want to add emf objects, that I created to my viewer. I use the common navigator framework. So I create my own project in the CNF in this form:
1 TProject
11 Folder 1
111 element1
112 element2
12 Folder 2
Project, folder and files are really resources on my file system. Now I need sometimes like that after the elements:
11 Folder 1
111 element1
1111 EMF Object Instance1
1112 EMF object Instance2
112 element2
I created the EMF Model and generated the model and edit plugins. I created navigator content with one trigger: the workspace root.
1) How can I tell to my contentprovider, that at element1, It must add EMF objects, that I created?, or I need to add a new navigator content for the same contentprovider?.
2) How can I tell to my navigator, that it must use the xyzItemProvider to display at element1 position EMF Objects?
Note that in my project 1 file corresponds to one EMF objects, that means I created the EMF Objects programmatically, when I get the file in the project.
Boris S.
[Updated on: Wed, 11 April 2012 12:48] by Moderator
Re: Workspace Resource with EMF Objects [message #845610 is a reply to message #841709] Sun, 15 April 2012 04:10 Go to previous messageGo to next message
I'm not familiar with how to integrate with CNF. Maybe someone else has
experience with that.
On 11/04/2012 6:47 PM, arthurembo Simo wrote:
> -> TProject
> -> Folder 1
> -> element1
> -> element2
> -> Folder 2
> -> Folder 1
> -> element1
> -> EMF Object Instance1
> -> EMF object Instance2
> -> element2
> in the project.
> Thanks
> Boris S.
Re: Workspace Resource with EMF Objects [message #845953 is a reply to message #841709] Sun, 15 April 2012 11:42 Go to previous messageGo to next message
Hi, Boris,
I think that GMF-generated editors can integrate EMF resource contents
into the Common Navigator. You might check, there. At any rate, I'm
fairly certain that the MDT Papyrus project can serve an example.
HTH,
Christian
On 2012-04-11 16:47:38 +0000, arthurembo Simo said:
> -> TProject
> -> Folder 1
> -> element1
> -> element2
> -> Folder 2
> -> Folder 1
> -> element1
> -> element2
> in the project.
> Thanks
> Boris S.
Re: Workspace Resource with EMF Objects [message #851000 is a reply to message #845953] Fri, 20 April 2012 10:44 Go to previous message
I found how to do it. The content provider of my Common navigator must extend the class AdapterFactoryContentProvider instead to implement the ItreeContentProvider, because the class AdapterFactoryContentProvider implements already the ItreeContentProvider Interface and it knows how to handle the generated EMF Itemproviders. So I can mix workspace resources files or folders with emf instances in my content providers with the getchildren() methods. Very Happy
Thanks!
Previous Topic:[SOLVED] CDO saving eDate as TIMESTAMP in MySQL
Next Topic:eFactory does not create the right boolean
Current Time: Sat Jul 19 12:24:39 EDT 2025
Powered by FUDForum. Page generated in 0.57163 seconds
