Control positions are wrong ? [message #845695] |
Sun, 15 April 2012 06:11  |
If i create a shell and a control on position (0,0) the control is over the shell bar.
Eclispe 4.2 with RAP 1.5M6
Display display = new Display ();
Shell shell = new Shell(display);
shell.setSize(600,300);
Text t = new Text(shell, SWT.BORDER);
t.setBounds( 0, 0, 200,50 );
t.setText("sample");
t.setBackground( display.getSystemColor(SWT.COLOR_RED) );
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Control positions are wrong ? [message #845796 is a reply to message #845695] |
Sun, 15 April 2012 08:33   |
Nicola,
SWT/RWT has the concept of a client area. The client area of a Composite
is a rectangle that describes the area within which other controls may
be placed. Use getClinentArea() to position controls inside a composite.
For example:
Rectangle clientArea = parent.getClientArea();
control.setBounds( clientArea.x, clientArea.y, 200,50 );
However, the recommended way to position widgets in SWT is to use layouts.
HTH
Rüdiger
> the shell bar.
> shell.open ();
> display.dispose ();
Rüdiger Herrmann
http://codeaffine.com
Re: Control positions are wrong ? [message #846694 is a reply to message #845835] |
Mon, 16 April 2012 04:54   |
On 15.04.2012 15:17, Nicola Zanaga wrote:
> thanks for the quick reply.
> I know the client area, but in SWT Shell doesn't consider the shell BAR
> and position (0,0) will not draw in the shell bar.
This is only true for certain platforms and widgets.
From the "SWT book", chapter 4.2 [1]:
"Very often, the location of the client area within the control is (0,
0), but this is not always the case."
> For compability, I think RAP should must do the same
Regarding the client area, RAP is 100 percent compatible with SWT.
Rüdiger Herrmann
[1] http://books.google.de/books/about/SWT.html?id=Z9RQAAAAMAAJ&redir_esc=y
FUDForum. Page generated in 0.03694 seconds
