Home » Archived » M2M (model-to-model transformation) » Does transformation rules order matter?
Does transformation rules order matter? [message #84490] |
Fri, 13 June 2008 07:58  |
Originally posted by: jorge.manrubia.gmail.com
We have a transformation file wich works properly when rules present a
certain order in the ATL file (primitive transformation first, complex
transformation last).
After reading the ATL execution semantics of the manual I think that this
is not the expected result (that order shouldn't matter), so we might be
using the language in the wrong way.
So, do we pay attention to the order of transformation rules?
Thank you
Re: [ATL] Re: Does transformation rules order matter? [message #84524 is a reply to message #84514] |
Fri, 13 June 2008 09:29   |
Jorge Manrubia a écrit :
> Yes, that's exactly the case. We have a complex rule making use of
> elements that should be created by more simple rules. Indeed they are
> created, but are not linked with the elements created by the complex
> rule. If we put the complex rule first, it seems that primitive
> transformation target elements don't exist when it's executed, while
> they are properly created later. If we put the complex rule the last
> one, it works as expected.
> We are not using "resolveTemp()". I expect that normal ATL resolve
> behaviour would resolve assigned elements (invoking the corresponding
> SOURCE to TARGET rule first) when a SOURCE element is in the right part
> of a binding.
> We are very new with this engine (althought we already love it) so our
> assumptions might be totally wrong.
> Thank you very much for your help
> Rene Ladan wrote:
>> The order of the transformation rules should indeed be indifferent
>> Every functional transformation language (XSLT/ATL/...) works this way.
>> Could there some dependency between them (e.g. that the complex rule
>> references a resulting element from the simpler rules, either direct
>> or through thisModule.resolveTemp()) ?
>> Rene
As Rene said, the order of rules should be indifferent.
However, in some cases and it doesn't depend on the complexity of the
rule, you have to specify a logic order. Take a look at the example below:
rule EEnum2Enumeration extends EClassifier2Classifier {
from
ec : Ecore!EEnum
to
c : UML!Enumeration (
ownedLiteral<- ec.eLiterals
rule EDataType2DataType extends EClassifier2Classifier {
from
ec : Ecore!EDataType
to
c : UML!DataType (
As you know EEnum is a subtype of EDataType in the Ecore metametamodel,
so if you put the rule for EDataType first, you will get a strange behavior.
You need to put rules for subtypes first.
If you are not satisfy with this, you can open a bug via Eclipse Bugzilla.
Brahim.
Re: [ATL] Re: Does transformation rules order matter? [message #84534 is a reply to message #84524] |
Fri, 13 June 2008 09:59   |
Originally posted by: r.c.ladan.tue.nl
>> Hi,
>> part of a binding.
>>> Rene
> from
> ec : Ecore!EEnum
> to
> from
> to
> c : UML!DataType (
> behavior.
No, that is what oclIsTypeOf() is for.
from
ec : Ecore!EEnum(ec.oclIsKindOf(EEnum))
to
from
ec : Ecore!EDataType(ec.oclIsKindOf(EDataType))
to
c : UML!DataType (
Alternatively, the oclIsKindOf() function checks if an element is of a certain
tpye or one of its subtypes.
Not needed.
Rene
Re: [ATL] Re: Does transformation rules order matter? [message #84542 is a reply to message #84534] |
Fri, 13 June 2008 10:19   |
>>> Hi,
>>> part of a binding.
>>> our assumptions might be totally wrong.
>>>> Rene
>> Hi,
>> below:
>> from
>> ec : Ecore!EEnum to
>> ownedLiteral<- ec.eLiterals )
>> from
>> ec : Ecore!EDataType to
>> c : UML!DataType (
>> metametamodel, so if you put the rule for EDataType first, you will
> from
> to
> from
> to
> c : UML!DataType (
> certain
>> Bugzilla.
> Not needed.
> Rene
Yes Rene, you're right. but I'm talking about how the order could
influence the transformation execution, not how we can resolve this.
Brahim.
Re: [ATL] Re: Does transformation rules order matter? [message #84554 is a reply to message #84542] |
Sat, 14 June 2008 06:27  |
We are already filtering by correct types in the rules.
So, what I'm going to do next week is to prepare a very simple sample, in
order to post real code here that reproduces our problem.
Thank you very much for your answers.
Current Time: Sat Jul 19 19:07:02 EDT 2025
Powered by FUDForum. Page generated in 0.13551 seconds
