Parse OCL Constraints - Model Instance of an UML Profile [message #845236] |
Sat, 14 April 2012 18:21  |
I have an UML Profile named as "AbcdUML" (only for example) and i have the metamodel in EMF/Ecore.
i.e. AbcdUML.ecore (metamodel)
i.e. myModelInstance.abcduml (model instance)
Now i have an OCl document with constraints against this model instance (not the metamodel).
i.e. MyConstraints.ocl
I need of these OCL constraints to make a transformation to another language.
How can I parse this constraints against this specific model instance(*.abcduml) since the API only provide a binding to Ecore and UML models? I need to parse before to obtain the constraints, right?
Putting it simply, I need to parse the OCL to obtain the Constraints through API and then use a visitor to walk in the AST and make a transformation to another language.
My first solution was to transform my "MyModelInstance.abcduml" into a UML model instance.
So now I'm able to get the constraints and to make the transformation. Is there a better solution?
In this solution to UML i use the org.eclipse.ocl.uml and org.eclipse.ocl libraries.
Is there a way to do this without a binding to a UML/Ecore/AbcdProfile ?
In this case, how the the classifiers context and properties of OCL expressions will be recognized ?
Which library i have to use? And how to do this?
John
Re: Parse OCL Constraints - Model Instance of an UML Profile [message #845501 is a reply to message #845236] |
Sun, 15 April 2012 01:30   |
If you open MyConstraints.ocl in the Complete OCL editor, the editor
will parse the constraints for you.
MyModelInstance.abcduml already is a 'UML model instance' which is no
different to an 'Ecore model instance', so if you open it with the
reflective Ecore Model editor, you can invoke the Load Complete OCL
Resource menu action to add MyConstraints.ocl. (This long overdue
integration was added in JunoM6).
At the API level you may find the CompleteOCLEObjectValidator helpful.
You may find the Royal and Loyal example project helpful.
Ed Willink
On 14/04/2012 23:21, John G. wrote:
> i.e. AbcdUML.ecore (metamodel) i.e. myModelInstance.abcduml (model
> instance)
> language.
> UML model instance. So now I'm able to get the constraints and to make
> ? In this case, how the the classifiers context and properties of OCL
> Regards,
> John
Re: Parse OCL Constraints - Model Instance of an UML Profile [message #845506 is a reply to message #845236] |
Ed Willink
> instance)
> language.
> Regards,
> John
Re: Parse OCL Constraints - Model Instance of an UML Profile [message #845511 is a reply to message #845236] |
Ed Willink
> instance)
> language.
> Regards,
> John
Re: Parse OCL Constraints - Model Instance of an UML Profile [message #845517 is a reply to message #845236] |
Ed Willink
> instance)
> language.
> Regards,
> John
Re: Parse OCL Constraints - Model Instance of an UML Profile [message #848389 is a reply to message #848139] |
Wed, 18 April 2012 03:12  |
HI
You're trying to do something I've not done and so don't understand; I
don't use profiles.
Please provide a ZIP of your files with simple instructions on what you
cannot do.
Ed Willink
On 18/04/2012 02:05, John G. wrote:
> Hi Edward,
> I'm sorry but I still do not understand.
> I'm opening MyConstraints.ocl with CompleteOCL Editor :
> Right Click-> Open With
> and importing the UML model :
> import 'platform:/resource/ProjectName/model/myModel.uml`
> But the ideal solution would be importing the UML profile:
> import `platform:/resource/ProjectName/model/myModel.abcduml` I tried
> to import this UML profile with the Complete OCL Editor and do not work.
> Can you explain this more detailed?
> Quote:
> I could open the "Reflective Ecore Model Editor" MyConstraints.ocl and
> with this editor that you mentioned import the model *.abcduml ?
> I'll check the examples that you mentioned.
> really appreciate your help
> Thanks
> John
FUDForum. Page generated in 0.04495 seconds
