Home » Archived » BIRT » Report loses rich text formatting when exported to PDF(Exporting does not retain formatting such as indentations and list indentations)
Report loses rich text formatting when exported to PDF [message #841832] Wed, 11 April 2012 15:25 Go to next message
I have a data row on a report that retrieves a description from a database. This description contains rich text formatting. When I view the report in the web viewer, the formatting is correct. However, when I export the report to PDF, it seems the formatting is lost for the PDF file. Any ideas? Or is this a known limitation?
Thanks.
Re: Report loses rich text formatting when exported to PDF [message #843029 is a reply to message #841832] Thu, 12 April 2012 14:57 Go to previous messageGo to next message
Are you using a dynamic text element? What does the Rich Text look like?
Jason
> Thanks.
Re: Report loses rich text formatting when exported to PDF [message #843053 is a reply to message #841832] Thu, 12 April 2012 14:57 Go to previous messageGo to next message
Jason
> Thanks.
Re: Report loses rich text formatting when exported to PDF [message #843086 is a reply to message #841832] Thu, 12 April 2012 14:57 Go to previous messageGo to next message
Jason
> Thanks.
Re: Report loses rich text formatting when exported to PDF [message #843979 is a reply to message #843086] Fri, 13 April 2012 11:06 Go to previous messageGo to next message
The element is a dynamic text element. I have attached an image of what the element looks like on the web viewer and what the element looks like when exported to a document.
In the image, I have also shown that the problem occurs when exporting to a Word document as well. Notice that the indentations and the lists are formatted incorrectly.
I am using BIRT 3.7.1.
Thanks.
  • Attachment: rtscreen.png
    (Size: 13.98KB, Downloaded 398 times)
Re: Report loses rich text formatting when exported to PDF [message #844040 is a reply to message #843979] Fri, 13 April 2012 12:14 Go to previous messageGo to next message
Can you log a bugzilla for this?
Jason
> Thanks.
Re: Report loses rich text formatting when exported to PDF [message #844145 is a reply to message #844040] Fri, 13 April 2012 14:43 Go to previous messageGo to next message
Sure, I have just logged a bug. It is listed as Bug 376769.
Thanks.
Re: Report loses rich text formatting when exported to PDF [message #846703 is a reply to message #844145] Mon, 16 April 2012 10:56 Go to previous message
Thanks for logging this.
Jason
> Thanks.
Previous Topic:Table inside a Grid (pagination problem)
Next Topic:Is there way to create accessible reports in BIRT?
Current Time: Sat Jul 19 23:14:13 EDT 2025
Powered by FUDForum. Page generated in 0.07046 seconds
