Home » Modeling » TMF (Xtext) » strange completion(strange completion behaviour in specific case)
strange completion [message #844060] Fri, 13 April 2012 12:39 Go to next message
I have little problem, when completion is "too late"...
My grammar:
Model:
	elements += Elements*
Elements:
	EntityA|FinalEntity
EntityA:
	'A' name=ID  '{'
		entityCs+=EntityC+
EntityC:
	'C' name=ID  '{'
		entityDs+=EntityD+
EntityD:
	'D' name=ID
FinalEntity:
	'X' a=[EntityA] '{'
		assignments += Assignments+
Assignments:
	AssignmentA|AssignmentB
AssignmentA:
	c=[EntityC] refs=DRef? '=' v=INT
AssignmentB:
	c=[EntityC] refs=DRef? '==' v=INT
DRef:
	'.' d=[EntityD]
My scope functions:
IScope scope_Assignments_c(FinalEntity fe, EReference reference){
	return Scopes.scopeFor(fe.getA().getEntityCs());
IScope scope_Assignments_c(Assignments asgn, EReference reference){
	EntityA a = EcoreUtil2.getContainerOfType(asgn, FinalEntity.class).getA();
	return Scopes.scopeFor(a.getEntityCs());
IScope scope_DRef_d(DRef dref, EReference reference){
	EntityC c = EcoreUtil2.getContainerOfType(dref, Assignments.class).getC();
	return Scopes.scopeFor(c.getEntityDs());
IScope scope_DRef_d(Assignments asgn, EReference reference){
	DRef refs = asgn.getRefs();
	if(refs!=null){
		DRef dref = (DRef) refs;
	return IScope.NULLSCOPE;
My model:
A aa {
	C cc {
		D dd
X aa {
	cc.dd = 5
Everything works perfect, there is a problem only when I try to complete "dd" in DRef. If I write "." and Ctrl+Space, no completion is offered. If I write one more letter, it offers the completion very well.
What am I doing wrong?
Thank you,
Michal
[Updated on: Fri, 13 April 2012 12:41] by Moderator
Re: strange completion [message #844112 is a reply to message #844060] Fri, 13 April 2012 13:51 Go to previous messageGo to next message
the problem is that the model is invalid until there is at least one letter after the .
=> the context is an FinalEntity in this case since neither a AssignmentA nor a AssignmentB can be created
i do not know how to solve this besides chaning the grammar e.g.
Assignments:
	c=[EntityC] refs=DRef? (a?="="|b?="==") v=INT
DRef:
	'.' d=[EntityD]
	IScope scope_DRef_d(Assignments asn, EReference reference){
		if(asn.getC()!=null){
			return Scopes.scopeFor(asn.getC().getEntityDs());
~Christian
Re: strange completion [message #844406 is a reply to message #844112] Fri, 13 April 2012 21:00 Go to previous messageGo to next message
Hello Christian,
thank you for your answer.
I was afraid that you give me this solution... It forces me to make changes in the validator, generator, etc., but I will manage Wink
Additional question: I understand, why the context is an FinalEntity. But: Why does it not recognize '.' as it does with normal keyword? (Basically, when any entity is being defined, the model is invalid, isn't it? -> but completion works... There is no other alternative for '.' starting rule in the grammar available at this place.)
Thank you & Best regards,
Michal
Re: strange completion [message #844727 is a reply to message #844406] Sat, 14 April 2012 05:32 Go to previous messageGo to next message
I dont know this. you would have to debug the ui parser to see what actually happens. but as said before: you get only contexts that are actually instantiated - and at this point nothing can be instantiated or the already instantiated stuff has to be thrown away.
maybe you could try another solution that may keep a metamodel that is more like your old one:
Refable : EntityC|EntityD;
AssignmentA:
cordd=[Refable] '=' v=INT
AssignmentB:
cordd=[Refable] '==' v=INT
Re: strange completion [message #844733 is a reply to message #844727] Sat, 14 April 2012 05:38 Go to previous message
Thank you Christian, I will manage someway...
Michal
Previous Topic:Xtext 2.3.0M6 outline view extension point
Next Topic:C-Based Editor (Xtext or CDT)?
Current Time: Sun Jul 20 04:28:26 EDT 2025
Powered by FUDForum. Page generated in 0.04167 seconds
