Re: Creating common interface [message #844028] |
Fri, 13 April 2012 12:01 |
Andrew,
no, there is no other way to do that in your grammar. You should
consider to import the ePackage and maintain it manually.
Sebastian
Am 12.04.12 20:57, schrieb Andrew Gacek:
> I have an expression language that has both field and array access:
> Index returns Expr:
> Atom ({FieldIndex.base=current} '.' field=ID |
> {ArrayIndex.base=current} '[' index=INT ']')*
> This generates interfaces FieldIndex and ArrayIndex, both extending
> Expr, which have their own versions of set/getBase(). I am trying to
> find a way to get Xtext to generate an intermediate interface Index
> which extends Expr and contains set/getBase() and such that FieldIndex
> and ArrayIndex both extend Index. So far the best solution I've found is
> the following two fake productions:
> Fake1 returns Expr: {Index} base=Expr;
> Fake2 returns Index: {FieldIndex} | {ArrayIndex};
> Is there a better way to do this?
> Andrew
FUDForum. Page generated in 0.03054 seconds
