Home » Eclipse Projects » Rich Client Platform (RCP) » Using show view within the perspective creation
Using show view within the perspective creation [message #842722] Thu, 12 April 2012 11:10 Go to next message
I keep getting a null return value when trying to get the active workbench page inside my perspective's createInitialLayout function.
Doesn't matter if I use getPages or getActivePage. Is there a way to get the active page during the perspective setup? I need to have the active page because I need to create views with a secondary ID on startup, which seemingly can only be done with the page.showView() function.
Here's my code
	public void createInitialLayout(IPageLayout layout) {
		layout.setEditorAreaVisible(false);
		layout.setFixed(true);
		String editorArea = layout.getEditorArea();
		IFolderLayout mainFolder = layout.createFolder(MAIN_FOLDER_ID, IPageLayout.LEFT,
				1.0f, editorArea);
		mainFolder.addView(View2.ID);
		IFolderLayout networkFolder = layout.createFolder(NETWORK_FOLDER_ID,
				IPageLayout.LEFT, 0.15F, MAIN_FOLDER_ID);
		networkFolder.addPlaceholder(View.ID + ":*");
		IWorkbench wb = PlatformUI.getWorkbench();
		IWorkbenchWindow win = wb.getActiveWorkbenchWindow();
		IWorkbenchPage page = win.getPages()[0];
		try {
			page.showView(View.ID, "1", IWorkbenchPage.VIEW_VISIBLE);
			page.showView(View.ID, "2", IWorkbenchPage.VIEW_VISIBLE);
		} catch (PartInitException e) {
			e.printStackTrace();
EDIT
So I've been able to retrieve the active workbench window if I put my code int a syncExec command. However, I still can't get it to return any pages.
		//networkFolder.addView(View.ID);
		final Display disp = PlatformUI.getWorkbench().getDisplay();
		disp.syncExec(new Runnable(){
			public void run(){
				if(!disp.isDisposed()){
					System.out.println(wb.getWorkbenchWindowCount());
					IWorkbenchWindow win = wb.getWorkbenchWindows()[0];
					IWorkbenchPage[] pages = win.getPages();
					System.out.println("pages:" + pages.length);
					/*try {
[Updated on: Thu, 12 April 2012 15:04] by Moderator
Re: Using show view within the perspective creation [message #842958 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
The forums went down when I posted my reply. Now there are like 20 of the same message. weird.
[Updated on: Thu, 12 April 2012 15:19] by Moderator
Re: Using show view within the perspective creation [message #842959 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
			public void run(){
					/*try {
Re: Using show view within the perspective creation [message #842965 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
			public void run(){
					/*try {
Re: Using show view within the perspective creation [message #842990 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #842991 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #842992 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843011 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843012 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843013 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843036 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843037 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843038 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843062 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843063 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843064 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843096 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843097 is a reply to message #842722] Thu, 12 April 2012 14:43 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #843098 is a reply to message #842722] Thu, 12 April 2012 14:44 Go to previous messageGo to next message
public void run(){
/*try {
Re: Using show view within the perspective creation [message #845899 is a reply to message #842722] Sun, 15 April 2012 10:24 Go to previous message
Hi Crypt,
You are obvioulsy too early. Try to add a listener to the workbenchwindow.
Try a page listener.
Wim
> Here's my code
IPageLayout.LEFT,
> 1.0f, editorArea);
> try {
Previous Topic:How to have several views which are not resizable?
Next Topic:rcp standalone view--how to show hidden titles at runtime
Current Time: Sat Jul 19 06:50:52 EDT 2025
Powered by FUDForum. Page generated in 0.10952 seconds
