Home » Language IDEs » C / C++ IDE (CDT) » __BASE_FILE__(semantic errors)
__BASE_FILE__ [message #840948] Tue, 10 April 2012 14:09 Go to next message
Hi everybody!
I have installed Eclipse Indigo for C/C++ Linux developers on Ubuntu 10.04 x86.
When I use common predefined macro '__BASE_FILE__' Eclipse says
Symbol '__BASE_FILE__' could not be resolved
but compilation is OK. I have to use it so often in my code and Eclipse fills my screen with red lines and bug icons Smile
It is simple to reproduce:
#include <stdio.h>
int main()
	printf("%s\n", __BASE_FILE__);
	return 0;
How can I fix this?
Probably the screenshot may explain it better Smile
index.php/fa/7852/0/
[Updated on: Tue, 10 April 2012 14:11] by Moderator
Re: __BASE_FILE__ [message #841315 is a reply to message #840948] Wed, 11 April 2012 02:39 Go to previous messageGo to next message
That is an error message from the static code analyzer CODAN. It cannot find the symbol __BASE_FILE__ in its index. That's a gcc internal define (therefore compilation works) but I think it is not defined in any header. So you must add this symbol manually to Project Properties->C/C++ General->Paths and Symbols: Symbols (C in your case).
Re: __BASE_FILE__ [message #841508 is a reply to message #841315] Wed, 11 April 2012 08:05 Go to previous messageGo to next message
Axel Mueller wrote on Wed, 11 April 2012 02:39
Yes, captain. But.. other predefined macros such as __FILE__ or __LINE__ are not marked as errors. If I'll add this macro manually then I don't get expected result (file's name).
I can only do one to reduce the Eclipse to silence.
#ifndef __BASE_FILE__
#define __BASE_FILE__ ""
#endif
Looks like it is bug of the analyzer.
Re: __BASE_FILE__ [message #841833 is a reply to message #841508] Wed, 11 April 2012 15:27 Go to previous messageGo to next message
Yes, these macros are known to the CDT indexer. You could open a bugzilla request (or submit a patch Smile ) so the indexer does recognize __BASE_FILE__ , too.
In the mean time you can use this workaround
#ifdef __CDT_PARSER__   // symbol is internally defined by the Eclipse CDT parser)
#endif
Re: __BASE_FILE__ [message #842061 is a reply to message #841833] Wed, 11 April 2012 21:01 Go to previous messageGo to next message
On 04/11/2012 02:27 PM, Axel Mueller wrote:
> Quote:
> bugzilla request (or submit a patch :) ) so the indexer does recognize
> parser)
> #endif
One other thing you can try is to duplicate your debug build
configuration and name it indexer. You can then add the __BASE_FILE__
symbol definition to the indexer configuration. Then select this as the
configuration to use as the fixed build configuration in the Indexer
properties. When the indexer runs, the symbol will be defined but when
you run the debug configuration it won't be and the compiler will use
the built in value.
Re: __BASE_FILE__ [message #842286 is a reply to message #842061] Thu, 12 April 2012 02:42 Go to previous messageGo to next message
David Wegener wrote on Wed, 11 April 2012 21:01
the built in value.
This is problem of the static analyzer, not the indexer.
Thanks for your efforts guys Smile
Re: __BASE_FILE__ [message #842552 is a reply to message #842286] Thu, 12 April 2012 07:59 Go to previous messageGo to next message
That is definitely a problem of the indexer! The code analyzer depends on the indexer!
The analyzer finds a symbol and then checks if it is part of the index. If not then it will raise a warning. If the index is complete you will only get a analyzer warning when you indeed use an undefined symbol.
Re: __BASE_FILE__ [message #842587 is a reply to message #842552] Thu, 12 April 2012 08:40 Go to previous messageGo to next message
Axel Mueller wrote on Thu, 12 April 2012 07:59
the built in value.
So why it isn't working?
I've added to "Path and Symbols" definition of __BASE_FILE__.
Build log says it is:
gcc -D__BASE_FILE__=__FILE__
warning: "__BASE_FILE__" redefined [-Wbuiltin-macro-redefined]
I've also done "Index -> Rebuild" and "Run C/C++ Code Analysis" commands.
But "__BASE_FILE__" is marked as the same problem.
So strange Sad
Re: __BASE_FILE__ [message #842675 is a reply to message #842587] Thu, 12 April 2012 10:17 Go to previous messageGo to next message
No problem on my side.
1) File->New_> Project: C Project
2) Project name: hello
3) Project type: Executable, Hello World ANSI C
4) open hello.c and replace code with the code from your initial comment
5) Symbol '__BASE_FILE__' could not be resolved
6) Open Project Properties->C/C++ General->Paths and Symbols: Symbols
Click Add and enter __BASE_FILE__ for the name and __FILE__ for the value
OK
=> CODAN warning is gone
Re: __BASE_FILE__ [message #842676 is a reply to message #842587] Thu, 12 April 2012 10:18 Go to previous messageGo to next message
OK
Re: __BASE_FILE__ [message #842677 is a reply to message #842587] Thu, 12 April 2012 10:18 Go to previous messageGo to next message
OK
Re: __BASE_FILE__ [message #842681 is a reply to message #842587] Thu, 12 April 2012 10:19 Go to previous messageGo to next message
OK
Re: __BASE_FILE__ [message #842703 is a reply to message #842677] Thu, 12 April 2012 10:48 Go to previous message
After the Eclipse was restarted, it is gone for me too Smile
Thank you very much indeed!
Previous Topic:Installation help
Next Topic:installed CDT successfully,but no C++project in new
Current Time: Sat Jul 19 11:44:09 EDT 2025
Powered by FUDForum. Page generated in 0.10133 seconds
