Home » Eclipse Projects » WindowBuilder » Wrong class resolution during bind with elementName(Composite class is evaluated instead of class specified in x:Class parameter)
Wrong class resolution during bind with elementName [message #841004] Tue, 10 April 2012 15:42 Go to next message
Hi all,
I am trying to do some simple binding tests and even though I've been able to do what I wanted when I switched back to design view on WindowBuilder it can't parse the XWT file anymore complaining that the property I am binding was not found on Composite class instead of looking up on the class I specified on x:Class parameter.
Stacktrace is as follows:
org.eclipse.e4.xwt.XWTException:  Property "directories" is not found in the class org.eclipse.swt.widgets.Composite
	at org.eclipse.e4.xwt.dataproviders.ObjectDataProvider$1.toModelPropertyType(ObjectDataProvider.java:53)
	at org.eclipse.e4.xwt.internal.core.ScopeManager$ObservableValueBuilder.observe(ScopeManager.java:194)
	at org.eclipse.e4.xwt.internal.core.ScopeManager.observe(ScopeManager.java:434)
	at org.eclipse.e4.xwt.databinding.DataBinding.getObservableSource(DataBinding.java:155)
	at org.eclipse.e4.xwt.databinding.DataBinding.getObservableWidget(DataBinding.java:174)
	at org.eclipse.e4.xwt.databinding.DataBinding.getValue(DataBinding.java:56)
	at org.eclipse.e4.xwt.internal.core.Binding.getValue(Binding.java:241)
	at org.eclipse.e4.xwt.converters.BindingToObject.convert(BindingToObject.java:26)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initSegmentAttribute(ResourceLoader.java:1619)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.initAttribute(ResourceLoader.java:1414)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:676)
	at org.eclipse.wb.internal.xwt.parser.XwtRenderer$5$1.doCreate(XwtRenderer.java:240)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:670)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.doCreate(ResourceLoader.java:467)
	at org.eclipse.e4.xwt.javabean.ResourceLoader.createCLRElement(ResourceLoader.java:371)
	at org.eclipse.e4.xwt.internal.core.Core.createCLRElement(Core.java:617)
	at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:674)
	at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java:864)
	at org.eclipse.e4.xwt.XWT.loadWithOptions(XWT.java:486)
	at org.eclipse.wb.internal.xwt.parser.XwtRenderer.render(XwtRenderer.java:261)
	at org.eclipse.wb.internal.xwt.model.widgets.ControlInfo.refresh_create(ControlInfo.java:94)
	at org.eclipse.wb.core.model.ObjectInfo.refreshCreate0(ObjectInfo.java:550)
	at org.eclipse.wb.core.model.ObjectInfo.access$0(ObjectInfo.java:546)
	at org.eclipse.wb.core.model.ObjectInfo$5$1.run(ObjectInfo.java:486)
	at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:139)
	at org.eclipse.wb.core.model.ObjectInfo$5.run(ObjectInfo.java:484)
	at org.eclipse.wb.core.model.ObjectInfo.execRefreshOperation(ObjectInfo.java:514)
	at org.eclipse.wb.core.model.ObjectInfo.refresh(ObjectInfo.java:482)
	at org.eclipse.wb.internal.core.xml.editor.XmlDesignPage.internal_refreshGEF(XmlDesignPage.java:459)
	at org.eclipse.wb.internal.core.xml.editor.XmlDesignPage.internal_refreshGEF(XmlDesignPage.java:390)
	at org.eclipse.wb.internal.core.xml.editor.UndoManager.refreshDesignerEditor(UndoManager.java:252)
	at org.eclipse.wb.internal.core.xml.editor.XmlDesignPage.updateGEF(XmlDesignPage.java:361)
	at org.eclipse.wb.internal.core.xml.editor.XmlDesignPage.refreshGEF(XmlDesignPage.java:354)
	at org.eclipse.wb.internal.core.xml.editor.actions.RefreshAction.run(RefreshAction.java:47)
	at org.eclipse.wb.internal.core.xml.editor.actions.DesignPageAction.run(DesignPageAction.java:35)
	at org.eclipse.wb.internal.core.xml.editor.XmlExceptionComposite.doRefresh(XmlExceptionComposite.java:65)
	at org.eclipse.wb.internal.core.editor.errors.ExceptionComposite$3.widgetSelected(ExceptionComposite.java:129)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: Wrong class resolution during bind with elementName [message #841007 is a reply to message #841004] Tue, 10 April 2012 15:46 Go to previous messageGo to next message
I guess I forgot to provide the code in question:
<Composite xmlns="eclipse.org/xwt/presentation" name="root"
	xmlns:x="eclipse.org/xwt"
	x:Class="br.rar.dups.SetupAnalysisComposite"
	xmlns:f="clr-namespace:org.eclipse.e4.xwt.jface" xmlns:v="clr-namespace:org.eclipse.jface.viewers"
	loaded="onLoad">
	<Composite.layout>
		<GridLayout numColumns="3"/>
	</Composite.layout>
	<ListViewer x:Style="BORDER | V_SCROLL" x:name="listViewer" input="{Binding elementName=root, path=directories, updateSourceTrigger=PropertyChanged}">
		<ListViewer.list>
			<ListViewer.list.layoutData>
				<GridData grabExcessHorizontalSpace="true" grabExcessVerticalSpace="true" verticalAlignment="FILL" horizontalAlignment="FILL" horizontalSpan="3"/>
			</ListViewer.list.layoutData>
			<ListViewer.labelProvider>
				<v:LabelProvider/>
			</ListViewer.labelProvider>
			<ListViewer.contentProvider>
				<f:DefaultListContentProvider/>
			</ListViewer.contentProvider>
		</ListViewer.list>
	</ListViewer>
</Composite>
package br.rar.dups;
import java.net.URL;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.e4.xwt.IConstants;
import org.eclipse.e4.xwt.XWT;
import org.eclipse.jface.viewers.ListViewer;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
public class SetupAnalysisComposite extends Composite {
	private List<String> directories = new ArrayList<String>();
	private ListViewer listViewer;
	public SetupAnalysisComposite(Composite parent, int style) {
		super(parent, style);
		setLayout(new FillLayout());
	public List<String> getDirectories() {
		return directories;
	public void InitializeComponent() {
		listViewer = (ListViewer) XWT.findElementByName(this, "listViewer");
	public void onLoad(SetupAnalysisComposite composite, Event event) {
		System.out.println("AAA");
		System.out.println(composite);
		System.out.println(event);
	public void onSelection(Event event) {
		directories.add("teste");
		System.out.println(directories);
		listViewer.refresh();
	public void onSelection_1(Event event) {
		System.out.println("ok");
		URL url = SetupAnalysisComposite.class.getResource(SetupAnalysisComposite.class
				.getSimpleName()
				+ IConstants.XWT_EXTENSION_SUFFIX);
		try {
			XWT.open(url);
		} catch (Exception e) {
			e.printStackTrace();
Re: Wrong class resolution during bind with elementName [message #842901 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
I am trying to figure out where the problem might be and I suspect that the following code on DataBindingParser is the responsible:
    String path = attributes.get("path");
    String elementName = attributes.get("elementname");
    if (elementName != null) {
      WidgetBindableInfo model = m_widgetContainer.resolve(elementName);
since this resolves only widget elements... not bean classes...
but... I could not figure out how I could lookup the class defined on x:Class parameter...
I also tested the selfdecorated sample and it fails as well...
[Updated on: Thu, 12 April 2012 14:19] by Moderator
Re: Wrong class resolution during bind with elementName [message #842906 is a reply to message #842901] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842908 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842910 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842918 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842919 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842920 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842931 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842932 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842933 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842944 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842945 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842946 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842960 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842961 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842962 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842976 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842977 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842978 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842996 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #842997 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #842998 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843016 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #843017 is a reply to message #842910] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843018 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843040 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #843041 is a reply to message #843040] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843042 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843071 is a reply to message #841007] Thu, 12 April 2012 14:17 Go to previous messageGo to next message
No Message Body
Re: Wrong class resolution during bind with elementName [message #843072 is a reply to message #843071] Thu, 12 April 2012 14:20 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843073 is a reply to message #841004] Thu, 12 April 2012 14:21 Go to previous messageGo to next message
Re: Wrong class resolution during bind with elementName [message #843311 is a reply to message #842920] Thu, 12 April 2012 20:04 Go to previous message
ops... sorry for so much replies... forum edit function seems to be broken... :S
Previous Topic:Instance factory implementation for newly created custom component plugin
Next Topic:Loading the itens of a JComboBox from the database breaks windowbuilder
Current Time: Sun Jul 20 11:58:52 EDT 2025
Powered by FUDForum. Page generated in 0.07404 seconds
