Home » Archived » BIRT » Postscript Level and Tray selection Problem(Unable to change ps level and select tray)
Postscript Level and Tray selection Problem [message #840855] Tue, 10 April 2012 11:36 Go to next message
I have tried and searched over the internet as how to change the postscript level and add tray selection postscript directives to the generated postscript report.
Sample code:
PostscriptRenderOption optionss = new PostscriptRenderOption();
optionss.setOutputFileName("C:\\Chetan\\" + c.getPlanNumber()
+".ps");
optionss.setOutputFormat("postscript");
optionss.setPostscriptLevel(2);
optionss.setPaperTray("TRAY1 595.2 841.8 0");
This doesnt seem to work and gives output like
%!PS-Adobe-3.0
% (C)2006 Actuate Inc.
%%Creator: Chetan Kakkar
%%Pages: (atend)
%%DocumentProcessColors: Black
%%BeginSetup
%%BeginFeature: *Duplex null
<</Duplex true /Tumble false>> setpagedevice
%%EndFeature
%%BeginResource: procset BIRTProcs
%%Title: Utility procedures
while I want something like this
%!PS-Adobe-2.1
%%LanguageLevel: 2
%%Requirements:
%%DocumentMedia: TRAY1 595.2 841.8 0 white PINK
%%+ TRAY2 595.2 841.8 0 white LETTERHEAD
%%+ TRAY3 595.2 841.8 0 white PLAIN
%%+ TRAY4 595.2 841.8 0 white PREPRINTED
%%Pages: 8
%%EndComments
%%BeginProlog
Kindly suggest where I'm going wrong, it'svery urgent as it is part of a Proof-of Concept stage for using BIRT for our purposes.
Chetan Kakkar
Re: Postscript Level and Tray selection Problem [message #840887 is a reply to message #840855] Tue, 10 April 2012 12:12 Go to previous messageGo to next message
I have not done much work with the ps emitter but from the code it looks
like tray settings are set like:
out.println( "%%BeginFeature: *InputSlot tray1" );
out.println( trayString );
out.println( "%%EndFeature" );
Where trayString is what you set in the options
PostscriptRenderOption options = new PostscriptRenderOption();
options.setOutputFormat("postscript");
options.setPaperTray("Tray1");
options.setOutputFileName("output/resample/tst.ps");
task.setRenderOption(options);
Jason
On 4/10/2012 11:36 AM, CHETAN KAKKAR wrote:
> Sample code:
> +".ps");
> %!PS-Adobe-3.0
> %%Pages: (atend)
> %%BeginSetup
> %%EndFeature
> %!PS-Adobe-2.1
> %%LanguageLevel: 2
> %%Requirements:
> %%Pages: 8
> %%EndComments
> %%BeginProlog
> Regards,
> Chetan Kakkar
Re: Postscript Level and Tray selection Problem [message #840898 is a reply to message #840887] Tue, 10 April 2012 12:35 Go to previous messageGo to next message
HI Jason, thanks for the quick reply. Yeah I went through the api as well...but that block of statements
is not found in the postscript generated. I'm unable to guess how to achieve it.
Chetan
Re: Postscript Level and Tray selection Problem [message #840995 is a reply to message #840898] Tue, 10 April 2012 15:24 Go to previous messageGo to next message
What version of BIRT are you using? This is what my output looked like:
%!PS-Adobe-3.0
%%Pages: (atend)
%%BeginSetup
Tray1
%%EndFeature
I put "Tray1" in.
Jason
> achieve it. Thanks,
> Chetan
Re: Postscript Level and Tray selection Problem [message #841295 is a reply to message #840995] Wed, 11 April 2012 02:08 Go to previous messageGo to next message
Hi Jason,
I'm using BIRT runtime API jars to integrate it with my standalone java application(org.eclipse.birt.runtime_3.7.2.v20120214-1408 - name of jar) and the Eclipse IDE for Report Designing. The version of the BIRT runtime is '3.7.2'.
I tried changing the Papersize and it works. But not for the Postscript Language Level and Tray.
ADded this
optionss.setPaperSize("LETTERHEAD");
optionss.setPaperTray("TRAY2");
Output:
%%BeginFeature: *PageSize LETTERHEAD
<</PageSize [595 842] /ImagingBBox null>> setpagedevice
%%EndFeature
%%EndFeature
Chetan
Re: Postscript Level and Tray selection Problem [message #841350 is a reply to message #840855] Wed, 11 April 2012 03:30 Go to previous messageGo to next message
Hi Jason,
ADded this
Output:
%%EndFeature
%%EndFeature
Chetan
Re: Postscript Level and Tray selection Problem [message #841664 is a reply to message #841350] Wed, 11 April 2012 11:55 Go to previous messageGo to next message
For some reason there was a change on the tray setting from BIRT 3.7.1
to 3.7.2. The setting is now an integer instead of a string and the
setter does not appear to be updated. Can you log a bugzilla entry for
this?
I was able to get a tray entry like:
options.setOption(PostscriptRenderOption.OPTION_PAPER_TRAY, new
Integer(258));
This generated:
<</ManualFeed false /MediaPosition 1 /TraySwitch false>>setpagedevice
%%EndFeature
Here is the source that determines the string for 3.7.2
private void setPaperTray( int paperTray )
String trayString = getPaperTrayCode( paperTray );
if ( trayString != null )
private String getPaperTrayCode( int paperTray )
if ( paperTray == TRAYCODE_MANUAL )
return "<</ManualFeed true /TraySwitch false>>setpagedevice";
// tray code should be positive number
// bigger than
// 257. For some printers use 257 and /MediaPosition
// 0 for first printer, whiles some others printers
// use code 258 and /MediaPosition 1 for first paper
// tray.
paperTray = paperTray - 257;
if ( paperTray < 0 )
return null;
return "<</ManualFeed false /MediaPosition " + paperTray
+ " /TraySwitch false>>setpagedevice";
It looks like from the emitter source:
out.println( "%!PS-Adobe-3.0" );
is hard coded.
Jason
On 4/11/2012 3:30 AM, CHETAN KAKKAR wrote:
> Hi Jason,
> runtime is '3.7.2'.
> ADded this
> Output:
> %%EndFeature
> %%EndFeature
> Regards,
> Chetan
Re: Postscript Level and Tray selection Problem [message #841679 is a reply to message #841664] Wed, 11 April 2012 12:11 Go to previous messageGo to next message
Hi Jason,
Again many thanks for the quick response. I'll try the way you have implemented the tray setting and update you. Yes, I'll raise a bugzilla request for the same and post the id here as well.
Thanks again for the help.
Chetan
Re: Postscript Level and Tray selection Problem [message #1060068 is a reply to message #841679] Wed, 22 May 2013 16:28 Go to previous message
The postscript level option appears to have never been implemented. See: https://bugs.eclipse.org/bugs/show_bug.cgi?id=169053#c2
Previous Topic:Postscript Level BIRT 2.2RC2
Next Topic:first report totals, then select parameter and filter
Current Time: Sun Jul 20 09:45:41 EDT 2025
Powered by FUDForum. Page generated in 0.05120 seconds
