Home » Eclipse Projects » BPMN 2.0 Modeler » Issues when creating a BPMN2 diagram(I am not able to create any BPMN2 diagram via the project creation wizzard)
Issues when creating a BPMN2 diagram [message #840584] Tue, 10 April 2012 05:12 Go to next message
Dear all,
I was trying to create a BPMN2 diagram by executing the following steps:
(1) Open Menu: File -> New -> Other
(2) Selection of: Other -> BPMN2 Diagram
After these steps a diagram creation wizard opens giving me three options:
a) Process
b) Collaboration
c) Choreography
By default the process selection is selected, but unfortunately the Next button is not enabled. I was hoping to get the diagram types enabled by selecting a different diagram type but I am getting the following exception as log output:
ENTRY org.eclipse.ui 4 0 2012-04-10 10:53:30.159
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramWizardPage2.isPageComplete(BPMN2DiagramWizardPage2.java:263)
at org.eclipse.jface.wizard.Wizard.canFinish(Wizard.java:155)
at org.eclipse.jface.wizard.WizardDialog.updateButtons(WizardDialog.java:1345)
at org.eclipse.jface.wizard.WizardPage.setPageComplete(WizardPage.java:299)
at org.eclipse.bpmn2.modeler.ui.wizards.BPMN2DiagramWizardPage1$1.widgetSelected(BPMN2DiagramWizardPage1.java:135)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Afterwards I started a little debugging to see what might be the reason for the issue and figured that the method "isPageComplete()" of class BPMN2DiagramWizardPage2 has an IContainer which is null (line 260 ff). Therefore the IResource can't be filled by any file.
Has anyone a similar experience or a clue how to get rid of this issue?
Many thanks and kind regards,
Christoph
Re: Issues when creating a BPMN2 diagram [message #840712 is a reply to message #840584] Tue, 10 April 2012 08:30 Go to previous messageGo to next message
Hi Christoph,
Looks like this is a bug. The IContainer is null because there is no active project. Please file a bugzilla here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=BPMN2Modeler
Thanks for finding this bug Smile
Bob
Re: Issues when creating a BPMN2 diagram [message #840725 is a reply to message #840712] Tue, 10 April 2012 08:52 Go to previous messageGo to next message
Hi Bob,
thanks for the quick response.
I already placed a bug id=376391 and it seems you were really quick in resolving it.
I'll check out the lates sources later and try it again.
Christoph
Re: Issues when creating a BPMN2 diagram [message #840986 is a reply to message #840725] Tue, 10 April 2012 15:12 Go to previous message
Hi Bob,
thank you. It seems that I was missing the point of creating first a project before starting a BPMN diagram.
Nevertheless I'd prefer one of the two options as an enhancement for the future
a) Not offering the option of creating a diagram before having a proper project in place or
b) offering to create a new, empty project, in case of no project has been set already.
Christoph
Previous Topic:Couldn't get BPMN2.0-modeler to install
Next Topic:Custom Lanes
Current Time: Sat Jul 19 05:33:33 EDT 2025
Powered by FUDForum. Page generated in 0.03764 seconds
