Home » Modeling » TMF (Xtext) » Use xtend2 and xbase-based DSL in GWT application client
Use xtend2 and xbase-based DSL in GWT application client [message #839054] Sat, 07 April 2012 23:30 Go to next message
I want to use xtend2 in GWT application client. The first step is to compile xbase.lib with gwt compiler(I use org.eclipse.xtext.xbase.lib_2.2.0.v201112030424.jar). Fortunately Xbase.lib depends heavily on guava and most of guava classes are GWT compatible. But I found xbase.lib still references to some GWT incompatible classes/methods:
1. Iterables.filter(Iterable<?>, Class<?>) in guava is marked as @GwtIncompatible, so any methods call to this method should be removed. These methods are:
IterableExtensions::filter(Iterable<?> unfiltered, Class<T> type)
IteratorExtensions:: filter(Iterator<?> unfiltered, Class<T> type)
2. Conversions.java contains a lot of Gwt incompatible references, following is the compile errors by GWT compiler:
[INFO]  [ERROR] Errors in '... /src/main/java/org/eclipse/xtext/xbase/lib/Conversions.java'
[INFO]          [ERROR] Line 92: The method toArray(Iterable<?>) in the type Iterables is not applicable for the arguments (Iterable, Class<capture#9-of ?>)
[INFO]          [ERROR] Line 127: The method isAssignableFrom(Class<capture#18-of ?>) is undefined for the type Class<capture#17-of ?>
[INFO]          [ERROR] Line 130: The method getCanonicalName() is undefined for the type Class<capture#19-of ?>
[INFO]          [ERROR] Line 130: The method getCanonicalName() is undefined for the type Class<capture#20-of ?>
[INFO]          [ERROR] Line 201: modCount cannot be resolved
[INFO]          [ERROR] Line 218: Cannot invoke clone() on the array type T[]
[INFO]          [ERROR] Line 229: modCount cannot be resolved
[INFO]          [ERROR] Line 266: No source code is available for type java.lang.reflect.Array; did you forget to inherit a required module?
[INFO]          [ERROR] Line 304: modCount cannot be resolved
[INFO]          [ERROR] Line 329: modCount cannot be resolved
So Conversions should be entirely removed
After those methods/classes that can't be compiled are removed, I wrote a very simple test case, it seems xtend2 work well in GWT. But if I use Iterables.filter(Iterable,Class), xtends will pass but generated java source contains compile error, becase filter(Iterable,Class) is removed from local version of IterableExtensions but still exist in reference Xtend Library .
My questions:
1.Is it possible to show the errors in xtend2 editor? Perhaps need a different version of xbase.lib?
2.Conversions.java is removed, so what kind of xtend2 features is moved too?
Re: Use xtend2 and xbase-based DSL in GWT application client [message #840532 is a reply to message #839054] Tue, 10 April 2012 03:50 Go to previous messageGo to next message
this is not necessary. You could provide your own GWT compatible versions of the libraries. There is no hard dependency on the bundles, they are usually used with Import-Package. So copy the library as a new plugin, remove everything what you don't want, and make sure that you use your library.
~Karsten
Re: Use xtend2 and xbase-based DSL in GWT application client [message #840631 is a reply to message #839054] Tue, 10 April 2012 06:08 Go to previous messageGo to next message
We want to provide a gwt-compatible jar in the next release.
Please attach any related findings to this bugzilla :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375808
Am 4/8/12 5:30 AM, schrieb tiange zhang:
> These methods are: IterableExtensions::filter(Iterable<?> unfiltered,
> Class<T> type)
> type T[]
> Xtend Library .
> My questions:
> too?
> Thanks
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Use xtend2 and xbase-based DSL in GWT application client [message #898008 is a reply to message #839054] Wed, 25 July 2012 11:28 Go to previous message
Hi tiange zhang,
you can try the first draft of gwt compatible libraries here:
http://www.eclipse.org/modeling/tmf/downloads/?showAll=1&hlbuild=N201207251051&project=xtext#N201207251051
Please let me know if something is missing or just wrong.
Previous Topic:[Xtend] Shortcut for switching between xtend and java
Next Topic:JVMModelInferrer - suppressing java code generation
Current Time: Sat Jul 19 11:00:46 EDT 2025
Powered by FUDForum. Page generated in 0.03495 seconds
