Home » Modeling » OCL » Problem when using ereference to another registered package(H)
Problem when using ereference to another registered package [message #840204] Mon, 09 April 2012 16:02 Go to next message
I have an ecore metamodel that has a class with an EReference to the Activity class from the bpmn metamodel (which came from the bpmn modeler editor). To do that, I simply right clicked->load resource->browse registered packages->choose http://stp.eclipse.org/bpmn. It gives no error and validates sucessfully when opening the file on Sample Ecore model editor, but when I open on OclInEcore Editor, this line:
import bpmn : '/plugin/org.eclipse.stp.bpmn/model/bpmn.ecore#/';
has an error, stating that this import is unresolved and null.
When I restart eclipse, it evens change that eReference to an Eobject. If I do not open the file on OCLinEcoreEditor, when I restart eclipse it stays with the correct EReference.
Any help is appreciated.
Thank you.
Re: Problem when using ereference to another registered package [message #840444 is a reply to message #840204] Tue, 10 April 2012 00:56 Go to previous messageGo to next message
What version are you using?
http://wiki.eclipse.org/MDT/OCL/New_and_Noteworthy/Indigo shows a
related fix in SR1 and in SR2.
does not seem at all likely, but without the *.ecore file to look at
it's difficult to comment.
Ed Willink
On 09/04/2012 21:02, Rômulo rpini wrote:
> Thank you.
Re: Problem when using ereference to another registered package [message #840466 is a reply to message #840444] Tue, 10 April 2012 01:52 Go to previous messageGo to next message
Hi Ed,
I am using the latest version of the Eclipse Modelling Tools (I just downloaded it today again) and my installed software is shown in the pic below:
http://i39.tinypic.com/206j56p.jpg
And I just attached an ecore with a simple class with only one Ereference, reproducing the problem.
And yes, that is happening with any loaded resource in the registered packages.
Thanks for your help.
[Updated on: Tue, 10 April 2012 01:54] by Moderator
Re: Problem when using ereference to another registered package [message #840735 is a reply to message #840204] Tue, 10 April 2012 08:58 Go to previous messageGo to next message
This is my 'favourite' EMF feature: meta-model schizophrenia, which the
Sample Ecore Editor makes very easy.
In bpmn.ecore you will find
<eClassifiers xsi:type="ecore:EClass" name="MessageVertex"
eSuperTypes="#//NamedBpmnObject #//Identifiable">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="orderedMessages"
unique="false"
upperBound="-1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EFeatureMapEntry">
and
<eClassifiers xsi:type="ecore:EClass" name="Association"
eSuperTypes="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//EModelElement">
demonstrating that bpmn.ecore is using schizophrenic Ecores
EFeatureMapEntry from http://www.eclipse.org/emf/2002/Ecore (registered
Java classes)
EModelElement from
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore (a file)
If you load bpmn.ecore into the Sample Ecore Editor and validate you
will find two copies of Ecore in use; not a problem for the Sample Ecore
Editor that does not do much model execution, but generally the source
of nightmares in model transformation tools that at best get confusing
answers from type hierarchy comparisons.
The OCLinEcore editor is a little more proactive in diagnosing
schizophrenia detecting a conflict on load, but the message is far from
obvious. There is a conflict message in the error log but that is also
far from clear.
So for Indigo, you need to repair the broken bpmn.ecore, so that it uses
only one flavour of Ecore.
For Juno, this problem goes away, because Ecores are loaded as Pivot
models where package nsURI rather external URI is significant. Duplicate
nsURIs are merged.
Ed Willink
> Thank you.
Re: Problem when using ereference to another registered package [message #840972 is a reply to message #840735] Tue, 10 April 2012 14:45 Go to previous messageGo to next message
Hi Ed, thank you for pointing out the problem.
I downloaded and tried in Juno like you suggested, but got this error when opening the ecore in OCLinEcore editor:
Editor could not be initialized.
java.lang.IllegalArgumentException: Ambiguous package name 'bpmn'
at org.eclipse.ocl.examples.pivot.manager.PackageManager.getPackageByName(PackageManager.java:163)
at org.eclipse.ocl.examples.pivot.manager.PackageManager.addPackage(PackageManager.java:75)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.addPackage(MetaModelManager.java:613)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.installPackage(MetaModelManager.java:2066)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.installResource(MetaModelManager.java:2131)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getPivotRoot(Ecore2Pivot.java:429)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getPivotType(Ecore2Pivot.java:348)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveSimpleType(Ecore2Pivot.java:612)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.resolveType(Ecore2Pivot.java:665)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.importObjects(Ecore2Pivot.java:466)
at org.eclipse.ocl.examples.pivot.ecore.Ecore2Pivot.getPivotRoot(Ecore2Pivot.java:417)
at org.eclipse.ocl.examples.xtext.oclinecore.ui.model.OCLinEcoreDocumentProvider.setDocumentContent(OCLinEcoreDocumentProvider.java:243)
at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:424)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:115)
at org.eclipse.ocl.examples.xtext.oclinecore.ui.model.OCLinEcoreDocumentProvider.setDocumentContent(OCLinEcoreDocumentProvider.java:203)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:229)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(XtextDocumentProvider.java:88)
at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:735)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:153)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:400)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4222)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:237)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1481)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:169)
at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:219)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3209)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.ui.internal.WorkbenchWindow$13.run(WorkbenchWindow.java:1662)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:1659)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3227)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3254)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:240)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:324)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:254)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:853)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:833)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:882)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:616)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:718)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:689)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:683)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:668)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:90)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4683)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:184)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:578)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:314)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:962)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2812)
at org.eclipse.ui.internal.WorkbenchPage.access$20(WorkbenchPage.java:2737)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2719)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2715)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2674)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:338)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMenu.java:180)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1015)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:909)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:85)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:580)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:535)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Any workaround on this?
[Updated on: Tue, 10 April 2012 14:46] by Moderator
Re: Problem when using ereference to another registered package [message #841509 is a reply to message #840972] Wed, 11 April 2012 08:03 Go to previous messageGo to next message
HI
Thanks; the residual problem is a spelling problem.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=376488 raised.
The root package of http://www.eclipse.org/emf/2002/Ecore is ecore
allowing the last segment to be used to name the invisible root package.
The root package of http://stp.eclipse.org/bpmn is bpmn causing an
ambiguity between the invisible root package and the true package.
For now you can choose between take a local copy of bpmn.ecore and
rename the package to Bpmn or the URI to http://mybpmn.
Ed Willink
> when opening in OCLinEcore:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Best regards,
Re: Problem when using ereference to another registered package [message #842103 is a reply to message #841509] Wed, 11 April 2012 22:01 Go to previous message
Hi Ed,
Thank you for answering.
Previous Topic:allInstances, unrecognized variable
Next Topic:Access parent children relationship from a base class
Current Time: Sun Jul 20 17:01:40 EDT 2025
Powered by FUDForum. Page generated in 0.05914 seconds
