Home » Archived » BIRT » BIRT and SQL 2008 R2(Difference between SQL 2005 and 2008 R2)
BIRT and SQL 2008 R2 [message #836671] Wed, 04 April 2012 15:28 Go to next message
using BIRT 3.7.2 and Microsoft SQL Server JDBC Driver 4.0, data source connection tests for SQL 2005 and 2008 R2 both appear to be positive. But, when I open the editor for 2008 R2 data sets, in the Query section. I do not see all of the schemas I do when I am viewing the same for SQL 2005, only the main connection node. No data is returned. This message appears in details. What can I do to et BIRT working with 2008 R2?
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:135)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.runDataset(DatasetPreviewTask.java:97)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.execute(DatasetPreviewTask.java:49)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetPreviewer.preview(DataSetPreviewer.java:69)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPreviewPage$5.run(ResultSetPreviewPage.java:337)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:The connection is closed.
com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:428)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:132)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.extractQuery(DatasetPreviewTask.java:169)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:126)
... 5 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:464)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:371)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:313)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:412)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:379)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 16 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.checkClosed(SQLServerConnection.java:388)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.checkClosed(SQLServerStatement.java:978)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:284)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
... 22 more
Re: BIRT and SQL 2008 R2 [message #837442 is a reply to message #836671] Thu, 05 April 2012 13:07 Go to previous messageGo to next message
Can you try the JTDS driver as described in this bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298730
Jason
> running the report.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 5 more
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
> at
> at
> at
> at
> at
> ... 22 more
Re: BIRT and SQL 2008 R2 [message #838090 is a reply to message #837442] Fri, 06 April 2012 10:49 Go to previous messageGo to next message
When I test connection using net.sourceforge.jtds.jdbc.Driver (v1.1), this message appears;
"The selected driver cannot parse the given url."
org.eclipse.birt.report.data.oda.jdbc.JDBCException: The selected driver cannot parse the given url.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.testConnection(JDBCDriverManager.java:696)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:147)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:175)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:156)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.testConnection(JDBCSelectionPageHelper.java:715)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.access$7(JDBCSelectionPageHelper.java:683)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:606)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.actions.EditDataSourceAction.doAction(EditDataSourceAction.java:69)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: BIRT and SQL 2008 R2 [message #840040 is a reply to message #838090] Mon, 09 April 2012 11:38 Go to previous messageGo to next message
Did you change the url to look like:
jdbc:jtds:sqlserver://server:port/dbname?
Jason
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Re: BIRT and SQL 2008 R2 [message #840042 is a reply to message #838090] Mon, 09 April 2012 11:42 Go to previous messageGo to next message
Using this example from the link you provided as my guide, jdbc:jtds:sqlserver://shanghai:1433/test , I am able to connect to one form of Database URL but not another. The first successful connection test to a 2008 R2 DB looks like this jdbc:jtds:sqlserver://shanghai:1433;databaseName = Name
What does not work is my reference to a sub-instance; jdbc:jtds:sqlserver://shanghai\SQL1;databaseName=Name
I assume this is because I don't know what the syntax should be for jtds in this instance. The last 3 connections I need to establish are jdbc:jtds:sqlserver://shanghai\SQL1;databaseName=Name, jdbc:jtds:sqlserver://shanghai\SQL2:port;databaseName=Name, jdbc:jtds:sqlserver://shanghai\SQL3;databaseName=Name
Suggestions?
Re: BIRT and SQL 2008 R2 [message #840088 is a reply to message #840042] Mon, 09 April 2012 12:37 Go to previous messageGo to next message
Have you seen this:
http://confluence.atlassian.com/display/JIRA/Connecting+to+named+instances+in+SQL+Server
Jason
> Suggestions?
Re: BIRT and SQL 2008 R2 [message #840165 is a reply to message #840088] Mon, 09 April 2012 14:54 Go to previous message
Thank you!
That last link got me through it.
Previous Topic:Debugging BIRT query
Next Topic:Table inside a Grid (pagination problem)
Current Time: Sun Jul 20 18:20:43 EDT 2025
Powered by FUDForum. Page generated in 0.05093 seconds
