Home » Archived » M2M (model-to-model transformation) » [ATL] Saving Model Programmatically
[ATL] Saving Model Programmatically [message #83990] Mon, 09 June 2008 08:23
Hi all,
I am using code from a post in Jan, by Wong who outlined code to use to do
a transformation programmatically. The problem is when I go to save the
model created from the transformation, I get an exception suggestion that
the workspace is closed.
Below is the error and then the code (commented where exception occours)
Anybody have any ideas?
Mark
Trans MM: Author >>> Person
Trans Instance: IN >>> OUT
ASM: /home/mmelia/workspace3/AntworksDennies1/bin/Author2Person.a sm
09-Jun-2008 12:39:30 org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel save
SEVERE: ERROR: save not implemented !
java.lang.IllegalStateException: Workspace is closed.
at
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:326)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:144)
at
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:65)
at JavaATL.ATLTransformations.runATLTransformation(JavaATL.java :111)
at JavaATL.ATLTransformations.main(JavaATL.java:43)
import java.io.File;
import java.io.FileOutputStream;
import java.io.OutputStream;
import java.net.URL;
import java.util.Collections;
import java.util.HashMap;
import java.util.Map;
import org.atl.eclipse.engine.AtlLauncher;
import org.atl.eclipse.engine.AtlModelHandler;
import org.atl.engine.vm.nativelib.ASMModel;
class ATLTransformations {
runATLTransformation();
public static void runATLTransformation() {
try {
AtlModelHandler emfamh =
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
URL asmurl = ATLTransformations.class.getResource("../DM2CG.asm");
ASMModel inputMetaModel = emfamh.loadModel("DOMAIN", emfamh.getMof(),
ATLTransformations.class.getResource("../Metamodels/skos2.ecore ").openStream());
ASMModel outputMetaModel = emfamh.loadModel("COURSE", emfamh.getMof(),
ATLTransformations.class.getResource("../Metamodels/Course.ecore ").openStream());
ASMModel inputInstance = emfamh.loadModel("inputInstance",
emfamh.getMof(),
ATLTransformations.class.getResource("../caviar.ecore").openStream());
ASMModel outputInstance;
Map<String, ASMModel> models = new HashMap<String, ASMModel>();
models.put(inputMetaModel.getName(), inputMetaModel);
models.put(outputMetaModel.getName(), outputMetaModel);
System.out.println("Trans MM: "+inputMetaModel.getName()+" >>>
"+outputMetaModel.getName());
models.put("IN", inputInstance); // input model
outputInstance = emfamh.newModel("coursexmi", outputMetaModel); // output
model
models.put("OUT", outputInstance);
System.out.println("Trans Instance: "+inputInstance.getName()+" >>>
"+outputInstance.getName());
Map params = Collections.EMPTY_MAP;
Map libs = Collections.EMPTY_MAP;
System.out.println("ASM: "+asmurl.getPath());
AtlLauncher.getDefault().launch(asmurl, libs, models, params);
OutputStream out = new FileOutputStream(new
File("C:/workspaceEclipse/Antworks/bin/zzzz.xmi"));
AtlModelHandler.getHandler(outputMetaModel).saveModel(output Instance,out);
//*************EXCEPTION THROWN**********************/
System.out.println(outputInstance);
out.flush();
out.close();
} catch (Exception e) {
e.printStackTrace();
Previous Topic:[ATL, UML] How to structure output model elements
Next Topic:UML Model generation from Other models
Current Time: Sat Jul 19 21:10:13 EDT 2025
Powered by FUDForum. Page generated in 0.23719 seconds
