Home » Modeling » TMF (Xtext) » Validating JvmType imports
Validating JvmType imports [message #836406] Wed, 04 April 2012 08:56 Go to next message
Karsten Thoms posted some code to validate Java imports in a DSL: https://kthoms.wordpress.com/2012/04/03/jvmtype-import-check/
But the code has one problem: org.eclipse.xtext.common.types.access.IJvmTypeProvider is not a public API (access is "discouraged" (?) in the access rules of the plug-in org.eclipse.xtext.common.types 2.2.1)
Since this is an extremely useful example: Is the code in the blog post wrong or should I file enhancement request to make this API public?
Re: Validating JvmType imports [message #836410 is a reply to message #836406] Wed, 04 April 2012 09:00 Go to previous messageGo to next message
it is "not public api" cause the Xtext guys want to be able to change it. changing public api is hard in eclipse => it is not public api.
=> if you can live with having to change your stuff with a new Xtext version.
don't care about the warning.
~Christian
Re: Validating JvmType imports [message #838021 is a reply to message #836410] Fri, 06 April 2012 08:55 Go to previous messageGo to next message
You can add
@SuppressWarnings("restriction")
to your class.
Re: Validating JvmType imports [message #840798 is a reply to message #838021] Tue, 10 April 2012 10:21 Go to previous messageGo to next message
Karsten Thoms wrote on Fri, 06 April 2012 14:55
You can add
to your class.
Well, yes but I was rised to pay heed to warnings Wink
My main complaint is that I must add the annotation to the class (because I also get warnings for the imports), so the scope of the annotation to too broad for my liking.
Okay, I can work around this by not using imports but FQ names but, well, it would be better if Xtext would offer an official API for this.
I think that many DSLs need to interface Java code and the API to check imports and type names should be pretty stable.
Re: Validating JvmType imports [message #841552 is a reply to message #840798] Wed, 11 April 2012 09:03 Go to previous messageGo to next message
Hi Aaron,
it will become public API as soon as we have the feeling that it's
mature enough. We don't have the resources to maintain poorly designed
APIs and apply deprecation strategies thus we warn clients that the
referenced code may change.
What you consider pretty stable is not necessarily stable from our
perspective, e.g. the resource set may be a to broad context for the
lookup environment of a type (which indeed it is).
Sebastian
Am 10.04.12 16:21, schrieb Aaron Digulla:
>> You can add @SuppressWarnings("restriction")
>> to your class.
> Well, yes but I was rised to pay heed to warnings ;)
Re: Validating JvmType imports [message #843660 is a reply to message #841552] Fri, 13 April 2012 04:46 Go to previous message
I understand. Here is the recipe for a workaround:
- Create another class which contains *only* restricted API calls (i.e. methods that simply delegate, no logic).
- Add @SuppressWarnings("restriction") to that class
- Inject this class into your code
This way, there is no risk to suppress too many warnings (or the wrong ones) and all the "risky" code is in one place.
Previous Topic:Launching rename operation in fix provider
Next Topic:dangling references on reparse of a resource
Current Time: Sun Jul 20 12:26:57 EDT 2025
Powered by FUDForum. Page generated in 0.04213 seconds
