Home » Eclipse Projects » GEF » Relation between figure bounds and display pixels
Relation between figure bounds and display pixels [message #788013] Wed, 01 February 2012 03:44 Go to next message
I have two rectangles
RectangleFigure figure = new RectangleFigure();
parent.add(figure);
parent.setConstraint(figure, new Rectangle(10, 10, 20, 20));
parent.add(figure);
parent.setConstraint(figure, new Rectangle(30, 30, 20, 20));
Where the parent has set the XYLayout.
I would expect those rectangles touch each other with theirs corners, but there is one pixel gap between them. Why is that??
Re: Relation between figure bounds and display pixels [message #837975 is a reply to message #788013] Fri, 06 April 2012 07:25 Go to previous messageGo to next message
What do you mean by one pixel gap?
When you draw a rectangle with size (10,10) starting from point (10,10) the Graphics will fill the pixels [(10,10),(10,11), ... , (10,19) ], so the line will take exactly 10 pixels space. So if you want another rectangle to overlap with each other then you have to start painting from (10,19).
Maybe attached picture (it is exactly what I got from your code) will explain this better Smile
Re: Relation between figure bounds and display pixels [message #887301 is a reply to message #837975] Sat, 16 June 2012 07:07 Go to previous message
Yes, I got it. Thanks. Razz
Previous Topic:EditPartViewer setProperty(...) method
Next Topic:Dotted rectangle when selecting a shape.
Current Time: Sun Jul 20 07:18:44 EDT 2025
Powered by FUDForum. Page generated in 0.05598 seconds
