BIRT and SQL 2008 R2 [message #836671] |
Wed, 04 April 2012 15:28  |
using BIRT 3.7.2 and Microsoft SQL Server JDBC Driver 4.0, data source connection tests for SQL 2005 and 2008 R2 both appear to be positive. But, when I open the editor for 2008 R2 data sets, in the Query section. I do not see all of the schemas I do when I am viewing the same for SQL 2005, only the main connection node. No data is returned. This message appears in details. What can I do to et BIRT working with 2008 R2?
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:135)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.runDataset(DatasetPreviewTask.java:97)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.execute(DatasetPreviewTask.java:49)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetPreviewer.preview(DataSetPreviewer.java:69)
at org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPreviewPage$5.run(ResultSetPreviewPage.java:337)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:The connection is closed.
com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:428)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:132)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.extractQuery(DatasetPreviewTask.java:169)
at org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:126)
... 5 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:464)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:371)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:313)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:412)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:379)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 16 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.checkClosed(SQLServerConnection.java:388)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.checkClosed(SQLServerStatement.java:978)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:284)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
... 22 more
FUDForum. Page generated in 1.04392 seconds
