Home » Modeling » EMF » XSD generation from ecore
XSD generation from ecore [message #836637] Wed, 04 April 2012 14:26 Go to next message
Hi All,
I have been trying to generate XSD from ecore.
One confusion which i am coming across is generation of references.
The references in the ecore model are getting generated as attributes with ecore:reference having the type information. Then if it is a list it is coming as a xsd:list with anytype within the xsd:simpletype tags.
Whereas i would like to have the references generated as elements.
Am i missing something here ?
cheers,
Saurav
Re: XSD generation from ecore [message #836691 is a reply to message #836637] Wed, 04 April 2012 15:54 Go to previous messageGo to next message
Saurav,
Comments below.
On 04/04/2012 8:26 PM, saurav sarkar wrote:
> Hi All,
Yes, for non-containment references...
I would expect anyURI not anyType...
You can use extended meta data annotations to specify they be elements,
but they'll still be of type anyURI with ecore:reference for
non-containment reference.
It might just be an issue of expectations verses how non-containment
references must be specified in a schema.
> cheers,
> Saurav
Re: XSD generation from ecore [message #836715 is a reply to message #836691] Wed, 04 April 2012 16:38 Go to previous messageGo to next message
On 04/04/2012 20:54, Ed Merks wrote:
> Saurav,
> elements, but they'll still be of type anyURI with ecore:reference for
EMF's Ecore to XSD capabilities are powerful but need some skill to get
right.
You may find it easier to produce a simple test XSD that demonstrates
your required style and then load/convert that to Ecore to discover the
appropriate annotations to achieve that style.
Ed Willink
Re: XSD generation from ecore [message #837115 is a reply to message #836715] Thu, 05 April 2012 05:35 Go to previous messageGo to next message
Thanks a lot both the Eds for the help Smile.
Makes perfect sense to have non -containment reference generated like that.
I checked by adding the metadata annotations that helps me to generate them as elements, so that solve some of my problems.
I would just go back to my original problem i.e. the above mentioned ecore files were originally generated from the Ration Rose (.mdl) files.
There i found some relationships which i thought should have had come as containment as true are instead coming as false.
I tried to decipher the .mdl files in the notepad++ but could not gather much Smile.
Any hints on this would be hugely appreciated?
cheers,
Saurav
Re: XSD generation from ecore [message #837164 is a reply to message #837115] Thu, 05 April 2012 06:44 Go to previous messageGo to next message
Saurav,
The rose files are really not so human readable. In the diagrams it
would be clear whether you have a black diamond or not. Of course you
can edit the *.ecore to change anything to whatever you want.
On 05/04/2012 11:35 AM, saurav sarkar wrote:
> Thanks a lot both the Eds for the help :).
> that.
> gather much :).
> cheers,
> Saurav
Re: XSD generation from ecore [message #837200 is a reply to message #837164] Thu, 05 April 2012 07:40 Go to previous message
Hi Ed,
Yes the problem now is that we don't own the rational rose license now.
So its a foregone story now Smile.
Yes now i would have to modify the ecore.
Thanks for the reply.
cheers,
Saurav
Previous Topic:efficient strategy to avoid too many transaction.commit()
Next Topic:Generating proper TestSuites, at least one operation needed
Current Time: Sat Jul 19 09:23:30 EDT 2025
Powered by FUDForum. Page generated in 0.04079 seconds
