Home » Eclipse Projects » EclipseLink » Problems with cascade delete doing update instead
Problems with cascade delete doing update instead [message #835105] Mon, 02 April 2012 16:10 Go to next message
I have a one to many relationship between a parent (workflow) and children (stage). In the database i have a delete constraint such that deletes on workflow delete stage. This works fine from sqlplus.
class Workflow {
@OneToMany(fetch = FetchType.LAZY, cascade = CascadeType.ALL, mappedBy = "workflow", targetEntity = Stage.class)
@JoinColumn(name = "WORKFLOW_ID")
public Set<Stage> getStages() {
return m_stages;
class Stage {
@ManyToOne(fetch = FetchType.LAZY, cascade = CascadeType.ALL, optional = false, targetEntity = Workflow.class)
@JoinColumn(name = "WORKFLOW_ID", nullable = false)
public Workflow getWorkflow() {
return m_workflow;
when i load the workflow by name inside a @Transactional(propagation = Propagation.REQUIRED) method and then em.remove(workflow) that object,
I get exceptions, such as
Error Code: 1407
Call: UPDATE STAGES SET WORKFLOW_ID = ?, FAILURE_STAGE_ID = ?, SUCCESS_STAGE_ID = ? WHERE (STAGE_ID = ?)
bind => [4 parameters bound]
Caused by: java.sql.SQLException: ORA-01407: cannot update ("AVONDALE"."STAGES"."WORKFLOW_ID") to NULL
because I have defined the stages.workflow_id column to be not nullable.
Why is eclipselink trying to update the stages table with null workflow ids, rather than just deleting the stage row itself? How do i fix that?
Re: Problems with cascade delete doing update instead [message #836526 is a reply to message #835105] Wed, 04 April 2012 11:39 Go to previous messageGo to next message
Are you nulling out the Stage->Workflow relationship and if so, why? Options are to not null out this relationship, remove the not-null constraint or defer database constraint processing until the end of the transaction.
If you are using a database level cascade delete (instead of letting JPA cascade its delete), you will need to use the EclipseLink @CascadeOnDelete described here:
http://wiki.eclipse.org/EclipseLink/Examples/JPA/DeleteCascade
Best Regards,
Chris
Re: Problems with cascade delete doing update instead [message #836551 is a reply to message #836526] Wed, 04 April 2012 12:10 Go to previous messageGo to next message
no i am not
ok i added @CascadeOnDelete as
@CascadeOnDelete
return m_stages;
this does nothing different.
[Updated on: Wed, 04 April 2012 12:18] by Moderator
Re: Problems with cascade delete doing update instead [message #836601 is a reply to message #836551] Wed, 04 April 2012 13:33 Go to previous messageGo to next message
Why do you have the @JoinColumn on that mapping when you are also marking it as mappedby "workflow"? The @JoinColumn on a OneToMany is only used for unidirectional relationships and maybe causing your issue. If this is the case, EclipseLink should be throwing an exception because the Stage.WORKFLOW_ID field has multiple writable mappings - EclipseLink is controlling the field from both sides of the relationship. Please set logging to finest and file a bug if there are no validation errors/warnings occuring.
Best Regards,
Chris
Re: Problems with cascade delete doing update instead [message #836653 is a reply to message #836601] Wed, 04 April 2012 14:52 Go to previous messageGo to next message
Same problem
org.springframework.transaction.TransactionSystemException: Could not commit JPA transaction; nested exception is javax.persistence.RollbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: ORA-01407: cannot update ("ACME"."STAGES"."WORKFLOW_ID") to NULL
Error Code: 1407
Query: DeleteObjectQuery(StageEO[Can't implement toString or else eclipselink with stack overflow])
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:476)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:754)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:723)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:393)
at org.springframework.transaction.aspectj.AbstractTransactionAspect.ajc$afterReturning$org_springframework_transaction_aspectj_AbstractTransactionAspect$3$2a73e96c(AbstractTransactionAspect.aj:78)
at com.acme.dao.iwf.IWFSerializer.deleteWorkflow(IWFSerializer.java:152)
at com.acme.iwf.impl.IWFRepository.removeWorkflow(IWFRepository.java:64)
at com.acme.servlets.LoginController.test(LoginController.java:178)
at com.acme.servlets.LoginController.login(LoginController.java:47)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.springframework.web.bind.annotation.support.HandlerMethodInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:176)
at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:426)
at org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:414)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:560)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:242)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:216)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:132)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:352)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:74)
at com.acme.filters.AuthFilter.doFilter(AuthFilter.java:50)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at weblogic.servlet.internal.RequestEventsFilter.doFilter(RequestEventsFilter.java:27)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3288)
at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3254)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2163)
at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2089)
at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2074)
at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1512)
at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Caused by: javax.persistence.RollbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1407
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:102)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:63)
at org.springframework.orm.jpa.JpaTransactionManager.doCommit(JpaTransactionManager.java:467)
... 45 more
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1407
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:840)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:906)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:592)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:535)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1717)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:253)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.updateObject(DatasourceCallQueryMechanism.java:749)
at org.eclipse.persistence.internal.queries.StatementQueryMechanism.updateObject(StatementQueryMechanism.java:432)
at org.eclipse.persistence.internal.queries.CallQueryMechanism.updateForeignKeyFieldBeforeDelete(CallQueryMechanism.java:436)
at org.eclipse.persistence.queries.DeleteObjectQuery.executeDatabaseQuery(DeleteObjectQuery.java:147)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:844)
at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:743)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:108)
at org.eclipse.persistence.queries.DeleteObjectQuery.executeInUnitOfWorkObjectLevelModifyQuery(DeleteObjectQuery.java:115)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:85)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2871)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1516)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1498)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1449)
at org.eclipse.persistence.queries.DeleteObjectQuery.executeDatabaseQuery(DeleteObjectQuery.java:190)
at org.eclipse.persistence.internal.sessions.CommitManager.deleteAllObjects(CommitManager.java:334)
at org.eclipse.persistence.internal.sessions.CommitManager.deleteAllObjects(CommitManager.java:288)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1418)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:636)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1505)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:267)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1143)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84)
... 47 more
Caused by: java.sql.SQLException: ORA-01407: cannot update ("ACME"."STAGES"."WORKFLOW_ID") to NULL
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:879)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:207)
at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:1044)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1329)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3593)
at oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(OraclePreparedStatement.java:3674)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeUpdate(OraclePreparedStatementWrapper.java:1354)
at weblogic.jdbc.wrapper.PreparedStatement.executeUpdate(PreparedStatement.java:167)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:831)
... 95 more
Re: Problems with cascade delete doing update instead [message #836668 is a reply to message #836653] Wed, 04 April 2012 15:20 Go to previous message
I would suggest you set EclipseLink logging to Finest and enable parameter logging as described here:
http://wiki.eclipse.org/EclipseLink/Examples/JPA/Logging
to see what is going on so you can narrow down the object that is responsible for the exception and follow how it is being corrupted. Please verify that you do not have any preremove events that might be attempting to clean up relationships. You might also want to call em.flush() before the remove call to verify that there are no changes to the relationship that would account for the null that you are unaware of. Do you have any other mappings that touch on the WORKFLOW_ID field in Stages?
Best Regards,
Chris
Previous Topic:"cannot be cast" error in Weblogic server 10.3.5
Next Topic:JPA ManyToMany in case of users and groups?
Current Time: Sat Jul 19 20:43:37 EDT 2025
Powered by FUDForum. Page generated in 0.06731 seconds
