Home » Modeling » EMF » Reconnecting from clone to master after CDO master server failure
Reconnecting from clone to master after CDO master server failure [message #834972] |
Mon, 02 April 2012 12:19  |
I'm writing a sports timing application that needs to be resilient and
high-available when deployed at the race course site --- even with
unreliable network connections. CDO's offline clone and failover
capability look like an excellent fit.
I've regenerated this RCP-based application's EMF model to use native
CDO, got it working with a direct connection to the CDO server. This CDO
stuff is very cool! Getting the application's editors to work with
Delete and deal with the InvalidObject's and StaleReferences has been a
challenge, but I think I've found workarounds.
Now I'm testing the use of CDO's offline clone capability. The cloned
respository seems to work well with the master. A snippet from my
application's log:
10:21:32 DEBUG (CDORepositoriesManager.java:199) - Cloned repository
changed to state SYNCING
changed to state ONLINE
[INFO] Synchronized with master.
10:21:32 DEBUG (CDOClient.java:93) - Successfully connected
10:21:32 DEBUG (CDOClient.java:56) - You are now connected to the server !
For the first of my resiliency tests, I shutdown the CDO master server
and can see the clone begin to periodically retry creating its
connection to the master server.
After I bring the CDO server back up, I expected the clone repository to
automatically reconnect and return to ONLINE status. However, even after
I bring the CDO server back up, the retries continue, and the clone's
synchronizer is never able to reconnect. Here's the log containing a
stack trace during one of the retries:
[INFO] Disconnected from master.
10:23:11 DEBUG (CDORepositoriesManager.java:199) - Cloned repository
changed to state OFFLINE
[WARN] Connection attempt failed. Retrying in 10 seconds...
org.eclipse.net4j.connector.ConnectorException: Connection timeout after
10000 milliseconds
at org.eclipse.spi.net4j.Connector.waitForConnection(Connector.java:245)
at org.eclipse.spi.net4j.Connector.doBeforeOpenChannel(Connector.java:360)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:139)
at
org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
at org.eclipse.net4j.signal.SignalProtocol.open(SignalProtocol.java:139)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:191)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:216)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:123)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
at
org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:250)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openSession(CDONet4jSessionConfigurationImpl.java:98)
at
org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionConfigurationImpl.openSession(CDONet4jSessionConfigurationImpl.java:1)
at
org.eclipse.emf.cdo.internal.server.syncing.RepositorySynchronizer$ConnectRunnable.run(RepositorySynchronizer.java:350)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:26)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunner.java:1)
at
org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:81)
at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWorker.java:72)
at
org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:206)
10000 milliseconds
at
at
Is this a supported outage scenario that should work? If so, maybe you
could point me in the right direction for debugging this one.
$cott
Re: Reconnecting from clone to master after CDO master server failure [message #836396 is a reply to message #834972] |
Wed, 04 April 2012 08:41   |
Hi Scott,
I've just tested with our (simple) offline clone examples:
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline/OfflineExampleMaster.java
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline/OfflineExampleClone.java
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/server/offline/OfflineExampleClient.java
All seems to work fine. Have youtried that? Maybe you find a problem in your code by comparing to these examples?
More comments below...
Am 02.04.2012 18:19, schrieb scott@xxxxxxxx:
> I'm writing a sports timing application that needs to be resilient and high-available when deployed at the race course
> site --- even with unreliable network connections. CDO's offline clone and failover capability look like an excellent
> fit.
> I've regenerated this RCP-based application's EMF model to use native CDO, got it working with a direct connection to
> the CDO server. This CDO stuff is very cool!
Thanks ;-)
> Getting the application's editors to work with Delete and deal with the InvalidObject's and StaleReferences has been a
Remote deletes (detachments) are generally not easy to deal with in applications that are not written for multi user
access from scratch. You should play with CDO's InvalidationPolicies and StaleReferencePolicies, e.g.,
CDOView.Options options = view.options();
options.setStaleReferencePolicy(CDOStaleReferencePolicy.PROXY);
options.setInvalidationPolicy(CDOInvalidationPolicy.RELAXED);
Please note that I recently (CDO 4.1!) applied some smaller fixes that can have a big positive impact:
374962: Make CDOStaleReferencePolicy.PROXY robust for eAdapters() calls
https://bugs.eclipse.org/bugs/show_bug.cgi?id=374962
374965: Make detachment notifications configurable
https://bugs.eclipse.org/bugs/show_bug.cgi?id=374965
375033: Remote notifications must be ignored in CDOPostEventTransactionHandler
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375033
375034: Consolidate server-side exceptions for commit conflicts
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375034
> Now I'm testing the use of CDO's offline clone capability. The cloned respository seems to work well with the master.
> A snippet from my application's log:
> 10:21:32 DEBUG (CDORepositoriesManager.java:199) - Cloned repository changed to state SYNCING
> 10:21:32 DEBUG (CDORepositoriesManager.java:199) - Cloned repository changed to state ONLINE
> For the first of my resiliency tests, I shutdown the CDO master server and can see the clone begin to periodically
> retry creating its connection to the master server.
> After I bring the CDO server back up, I expected the clone repository to automatically reconnect and return to ONLINE
> status. However, even after I bring the CDO server back up, the retries continue, and the clone's synchronizer is
> never able to reconnect. Here's the log containing a stack trace during one of the retries:
> 10:23:11 DEBUG (CDORepositoriesManager.java:199) - Cloned repository changed to state OFFLINE
> org.eclipse.net4j.connector.ConnectorException: Connection timeout after 10000 milliseconds
> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:139)
> at org.eclipse.spi.net4j.ChannelMultiplexer.openChannel(ChannelMultiplexer.java:1)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.createProtocol(CDONet4jSessionImpl.java:191)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.openSession(CDONet4jSessionImpl.java:216)
> at org.eclipse.emf.cdo.internal.net4j.CDONet4jSessionImpl.doActivate(CDONet4jSessionImpl.java:123)
> at org.eclipse.emf.internal.cdo.session.CDOSessionConfigurationImpl.openSession(CDOSessionConfigurationImpl.java:250)
> at
> at
> at
> at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWorker.java:81)
> at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Worker.java:206)
Note that these log events have severity [WARN]. They not necessarily indicate a bug somewhere, except if you're really
sure that the master should be reachable. Can you connect a normal client to the master?
Yes.
> If so, maybe you could point me in the right direction for debugging this one.
I would start on the networking layer by setting breakpoints in
org.eclipse.net4j.internal.tcp.TCPAcceptor.handleRegistration(ITCPSelector, ServerSocketChannel)
org.eclipse.net4j.internal.tcp.TCPAcceptor.handleAccept(ITCPSelector, ServerSocketChannel)
Also make sure that your nodes have enabled as many tracing options as possible. Maybe that shows some more exceptions...
Cheers
/Eike
http://www.esc-net.de
Re: Reconnecting from clone to master after CDO master server failure [message #837311 is a reply to message #836396] |
Thu, 05 April 2012 10:04   |
Thanks, Eike. I tried some scenarios using the Offline examples you
suggested to see where I might have gone wrong.
My test scenario is this:
0. Erase all master and clone DB files
1. Start the master server
2. Start the clone server
3. Start the offline client
4. Add an instance of my model to the CDO repository through the clone
and wait for the trans to commit.
4. Exit (Option 0) the master server
5. Restart the master server
This scenario works fine with the one node Company model instance
provided with the examples, but when I use my own large model instance
(2MB graph with 17K+ EObjects), step 5 causes the clone to go into a loop.
Here's how it looks on the clone server console with tracing turned off.
With tracing on, there are stack traces:
Enter a command:
0 - exit
1 - connect repository to network
2 - disconnect repository from network
3 - dump repository infos
Opened Session9 [master]
State changed to SYNCING
State changed to OFFLINE
Opened Session10 [master]
Opened Session11 [master]
Opened Session12 [master]
Opened Session13 [master]
Opened Session14 [master]
The debugger shows these session threads accumulating in both the master
and clone servers.
I tried creating a larger the Company instance, but that didn't
replicate the problem.
Here are the changes I made to the example code to use my model:
1. AbstractOfflineServer: I changed only the EPackage registration line
CompanyPackage.eINSTANCE.getClass(); changed to
RegattaPackage.eINSTANCE.getRegatta();
2. OfflineExampleMaster: no changes
3. OfflineExampleClone: no changes
4. OfflineExampleClient: replaced the Company model with my model. I
attached this file in case you want to see it.
Here's a snippet from one of the loop iterations captured from the
master server console with tracing turned on:
Thread-12 [org.eclipse.spi.net4j.Channel] Handling buffer:
Buffer@636[PUTTING] --> Channel[1, SERVER, cdo]
Thread-12 [org.eclipse.internal.net4j.buffer.BufferPool] Obtained
Buffer@637[INITIAL]
Buffer@637[PUTTING] --> Channel[1, SERVER, cdo]
[ERROR] org.h2.jdbc.JdbcSQLException: Column L_T.CDO_SOURCE not found;
SQL statement:
SELECT l_t.cdo_id, l_t.cdo_branch, l_t.cdo_version, l_t.cdo_idx,
l_t.cdo_tag, l_t.cdo_value_DATE, l_t.cdo_value_VARCHAR,
l_t.cdo_value_BOOLEAN, l_t.cdo_value_BIGINT, l_t.cdo_value_SMALLINT,
l_t.cdo_value_TIMESTAMP, l_t.cdo_value_DOUBLE, l_t.cdo_value_TIME,
l_t.cdo_value_FLOAT, l_t.cdo_value_BLOB, l_t.cdo_value_CHAR,
l_t.cdo_value_INTEGER, l_t.cdo_value_LONGVARCHAR, l_t.cdo_value_CLOB
FROM XMLTypeDocumentRoot_mixed_list l_t, XMLTypeDocumentRoot a_t WHERE
a_t.cdo_created BETWEEN 1 AND 1333579470612 AND
a_t.cdo_id=l_t.cdo_source AND a_t.cdo_version=l_t.cdo_version AND
a_t.cdo_branch=l_t.cdo_branch [42122-117]
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Column
L_T.CDO_SOURCE not found; SQL statement:
at org.eclipse.net4j.db.DBUtil.serializeTable(DBUtil.java:808)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.rawExportList(AbstractHorizontalMappingStrategy.java:198)
at
org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.rawExport(AbstractHorizontalMappingStrategy.java:179)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawExport(DBStoreAccessor.java:1107)
at
org.eclipse.emf.cdo.internal.server.Repository.replicateRaw(Repository.java:1113)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.ReplicateRepositoryRawIndication.responding(ReplicateRepositoryRawIndication.java:62)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.responding(CDOServerIndicationWithMonitoring.java:170)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:90)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:296)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at
org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndicationWithMonitoring.execute(CDOServerReadIndicationWithMonitoring.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: org.h2.jdbc.JdbcSQLException: Column L_T.CDO_SOURCE not
at org.h2.message.Message.getSQLException(Message.java:105)
at org.h2.message.Message.getSQLException(Message.java:116)
at org.h2.message.Message.getSQLException(Message.java:75)
at org.h2.expression.ExpressionColumn.optimize(ExpressionColumn.java:128)
at org.h2.expression.Comparison.optimize(Comparison.java:137)
at org.h2.expression.ConditionAndOr.optimize(ConditionAndOr.java:132)
at org.h2.expression.ConditionAndOr.optimize(ConditionAndOr.java:131)
at org.h2.command.dml.Select.prepare(Select.java:723)
at org.h2.command.Parser.prepareCommand(Parser.java:235)
at org.h2.engine.Session.prepareLocal(Session.java:415)
at org.h2.engine.Session.prepareCommand(Session.java:376)
at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1049)
at org.h2.jdbc.JdbcStatement.executeQuery(JdbcStatement.java:70)
at org.eclipse.net4j.db.DBUtil.serializeTable(DBUtil.java:785)
... 17 more
With tracing turned on, the clone's log shows the same 'Column
L_T.CDO_SOURCE not found' message.
What could cause the 'Column L_T.CDO_SOURCE not found' problem?
$cott
On 4/4/2012 8:41 AM, Eike Stepper wrote:
> Hi Scott,
> Thanks ;-)
>> the InvalidObject's and StaleReferences has been a challenge, but I
> applications that are not written for multi user access from scratch.
>> application's log:
>> server !
>> to automatically reconnect and return to ONLINE status. However, even
>> clone's synchronizer is never able to reconnect. Here's the log
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> indicate a bug somewhere, except if you're really sure that the master
> Yes.
>> this one.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
* Copyright (c) 2004 - 2011 Eike Stepper (Berlin, Germany) and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Eike Stepper - initial API and implementation
package org.eclipse.emf.cdo.examples.server.offline;
import java.io.BufferedReader;
import java.io.File;
import java.io.IOException;
import java.io.InputStreamReader;
import java.util.Properties;
import org.apache.log4j.LogManager;
import org.apache.log4j.Logger;
import org.apache.log4j.PropertyConfigurator;
import org.eclipse.emf.cdo.CDOObject;
import org.eclipse.emf.cdo.common.CDOCommonRepository;
import org.eclipse.emf.cdo.common.CDOCommonRepository.State;
import org.eclipse.emf.cdo.common.branch.CDOBranch;
import org.eclipse.emf.cdo.common.commit.CDOCommitInfo;
import org.eclipse.emf.cdo.net4j.CDONet4jUtil;
import org.eclipse.emf.cdo.net4j.CDOSession;
import org.eclipse.emf.cdo.net4j.CDOSessionConfiguration;
import org.eclipse.emf.cdo.session.CDORepositoryInfo;
import org.eclipse.emf.cdo.transaction.CDOTransaction;
import org.eclipse.emf.cdo.util.CDOUtil;
import org.eclipse.emf.cdo.util.CommitException;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.spi.cdo.DefaultCDOMerger;
import org.eclipse.net4j.Net4jUtil;
import org.eclipse.net4j.connector.IConnector;
import org.eclipse.net4j.util.container.IManagedContainer;
import org.eclipse.net4j.util.event.IEvent;
import org.eclipse.net4j.util.event.IListener;
import org.eclipse.net4j.util.lifecycle.LifecycleUtil;
import com.humanfactor.rw.model.ecore.regatta.Regatta;
import com.humanfactor.rw.model.ecore.regatta.RegattaFactory;
import com.humanfactor.rw.model.ecore.regatta.util.RegattaResourceFactoryImpl;
import com.humanfactor.utils.exception.ExceptionUtil;
* Following console parameters are allowed: <br>
* -automerge provides an automatic merging of the offline changes to the master repository
* @author Eike Stepper
* @author Martin Fluegge
* @since 4.0
public class OfflineClient {
private static Logger logger = LogManager.getLogger(OfflineClient.class);
public static final int PORT = 2037;
private static CDOTransaction cloneTx;
private static CDOTransaction masterTx;
private static int versionCount = 1;
private static boolean autoMerging;
private static IManagedContainer cloneContainer = OfflineUtil.createContainer();
private static IManagedContainer masterContainer = OfflineUtil.createContainer();
private static void addObject(CDOTransaction tx) {
try {
Regatta regatta = RegattaFactory.eINSTANCE.createRegatta();
tx.getOrCreateResource("/r1").getContents().add(regatta);
logger.debug("Committing an object to " + tx.getBranch().getPathName());
CDOCommitInfo commitInfo = tx.commit();
CDOBranch branch = commitInfo.getBranch();
System.out.println("Committed an object to " + branch.getPathName());
tx.setBranch(branch);
} catch (CommitException x) {
throw new RuntimeException(x);
private static void addRegatta(CDOTransaction tx) {
try {
String fileName = "regattas/Stotesbury-Cup-Regatta-2010-05-14.rml";
Regatta regatta = loadRegatta(fileName);
tx.getOrCreateResource("/regattas/Stotesbury-Cup-Regatta-2010-05-14-v" + versionCount++ + ".rml")
System.out.println("Committing an regatta to " + tx.getBranch().getPathName());
System.out.println("Committed a regatta to " + branch.getPathName());
private static void lockObject(CDOTransaction tx) {
EList<EObject> contents = tx.getOrCreateResource("/r1").getContents();
int size = contents.size();
if (size < 1) {
System.out.println("There are no objects; can't lock anything.");
System.out.println("Locking last object");
CDOObject firstObject = CDOUtil.getCDOObject(contents.get(size - 1));
firstObject.cdoWriteLock().lock();
System.out.println("Locked last object");
private static void unlockObject(CDOTransaction tx) {
if (size < 1) {
System.out.println("Unlocking last object");
firstObject.cdoWriteLock().unlock();
System.out.println("Unlocked last object");
private static void createBranch(CDOTransaction tx) {
CDOBranch subBranch = tx.getBranch().createBranch("sub.1");
tx.setBranch(subBranch);
private static boolean isAutoMerge(String[] args) {
for (int i = 0; i < args.length; i++) {
if (args[i].equals("-automerge")) {
return true;
return false;
private static void createSessionListener(final CDOSession session, final boolean autoMerging) {
session.addListener(new IListener() {
private boolean wasOffline;
public void notifyEvent(IEvent event) {
if (event instanceof CDOCommonRepository.StateChangedEvent) {
CDOCommonRepository.StateChangedEvent e = (CDOCommonRepository.StateChangedEvent) event;
State newState = e.getNewState();
System.out.println("State changed to " + newState);
if (autoMerging) {
merge(session, newState);
private void merge(final CDOSession session, State newState) {
if (newState == State.ONLINE && wasOffline) {
try {
CDOTransaction newTransaction = session.openTransaction(session.getBranchManager()
.getMainBranch());
// CDOBranch mainBranch = session.getBranchManager().getMainBranch();
newTransaction.merge(getCloneTransaction().getBranch().getHead(),
new DefaultCDOMerger.PerFeature.ManyValued());
newTransaction.commit();
getCloneTransaction().close();
cloneTx = newTransaction;
} catch (CommitException ex) {
ex.printStackTrace();
} finally {
wasOffline = false;
} else if (newState == State.OFFLINE) {
wasOffline = true;
private static CDOTransaction createCloneTransaction() {
System.out.println("Connecting to clone...");
IConnector connector = Net4jUtil.getConnector(cloneContainer, AbstractOfflineServer.TRANSPORT_TYPE,
"localhost:" + PORT);
CDOSessionConfiguration configuration = CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName(OfflineCloneServer.NAME);
CDOSession session = configuration.openSession();
CDORepositoryInfo repositoryInfo = session.getRepositoryInfo();
System.out.println("Connected to " + repositoryInfo.getName());
CDOTransaction tx = session.openTransaction();
tx.enableDurableLocking(true);
createSessionListener(session, autoMerging);
return tx;
private static CDOTransaction createMasterTransaction() {
System.out.println("Connecting directly to master...");
IConnector connector = Net4jUtil.getConnector(masterContainer, AbstractOfflineServer.TRANSPORT_TYPE,
"localhost:" + OfflineMasterServer.PORT);
configuration.setRepositoryName(OfflineMasterServer.NAME);
return tx;
public static CDOTransaction getMasterTransaction() {
if (masterTx == null) {
masterTx = createMasterTransaction();
return masterTx;
public static CDOTransaction getCloneTransaction() {
if (cloneTx == null) {
cloneTx = createCloneTransaction();
return cloneTx;
public static void main(String[] args) throws Exception {
Properties props = new Properties();
props.setProperty("log4j.rootLogger", "DEBUG, stdout");
props.setProperty("log4j.appender.stdout", "org.apache.log4j.ConsoleAppender");
props.setProperty("log4j.appender.stdout.layout", "org.apache.log4j.PatternLayout");
props.setProperty("log4j.appender.stdout.layout.ConversionPattern", "%-4r [%t] %-5p %c %x - %m%n");
props.setProperty("log4j.logger.com.humanfactor.rw", "DEBUG");
props.setProperty("log4j.logger.org.apache", "ERROR");
PropertyConfigurator.configure(props);
autoMerging = isAutoMerge(args);
for (;;) {
System.out.println();
System.out.println("Enter a command:");
System.out.println("0 - exit");
System.out.println("1 - add an object to the repository");
System.out.println("2 - lock the last object in the repository");
System.out.println("3 - unlock the last object in the repository");
System.out.println("4 - create a branch");
System.out.println("5 - add a large regatta directly to the master repository");
System.out.println("6 - add a large regatta directly to the clone repository");
String command = new BufferedReader(new InputStreamReader(System.in)).readLine();
if ("0".equals(command)) {
break;
if ("1".equals(command)) {
addObject(getCloneTransaction());
} else if ("2".equals(command)) {
lockObject(getCloneTransaction());
} else if ("3".equals(command)) {
unlockObject(getCloneTransaction());
} else if ("4".equals(command)) {
createBranch(getCloneTransaction());
} else if ("5".equals(command)) {
addRegatta(getMasterTransaction());
} else if ("6".equals(command)) {
addRegatta(getCloneTransaction());
if (cloneTx != null) {
cloneTx.getSession().close();
LifecycleUtil.deactivate(cloneContainer);
if (masterTx != null) {
masterTx.getSession().close();
LifecycleUtil.deactivate(masterContainer);
public static Regatta loadRegatta(String regattaFileName) {
Regatta regatta;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("rml", new RegattaResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("rmz", new RegattaResourceFactoryImpl());
URI fileURI = URI.createFileURI(new File(regattaFileName).getAbsolutePath());
RegattaResourceFactoryImpl regattaResourceFactory = new RegattaResourceFactoryImpl();
Resource regattaResource = regattaResourceFactory.createResource(fileURI);
try {
regattaResource.load(null);
if (regattaResource.getContents().size() == 1) {
regatta = (Regatta) regattaResource.getContents().get(0);
} else if (regattaResource.getContents().size() == 0) {
logger.error("No regattas in file '" + regattaFileName + "'");
regatta = null;
} else {
logger.error("File '" + regattaFileName + "' contains multiple ("
+ regattaResource.getContents().size() + ") resources");
} catch (IOException e) {
logger.error(ExceptionUtil.getStackTrace(e), e);
regatta = null;
return regatta;
Re: Reconnecting from clone to master after CDO master server failure [message #837421 is a reply to message #837311] |
Thu, 05 April 2012 12:37   |
Hi Scott,
Looking at the failing SQL statement it seems that you're using feature maps in your model. They belong to the functions
with the most complex implementation and we know of some problems that we just don't have the resources to
investigate/fix adequately. I'm sure nobody has used them so far together with offline replication. Nevertheless I'd
like to discuss the issue with Stefan Winkler, our DBStore expert. Perhaps the solution is as easy as replacing the
respective String constants in CDODBSchema.java as follows:
* Field names of featuremap tables
public static final String FEATUREMAP_REVISION_ID = LIST_REVISION_ID;
public static final String FEATUREMAP_VERSION = LIST_REVISION_VERSION;
public static final String FEATUREMAP_VERSION_ADDED = LIST_REVISION_VERSION_ADDED;
public static final String FEATUREMAP_VERSION_REMOVED = LIST_REVISION_VERSION_REMOVED;
public static final String FEATUREMAP_BRANCH = LIST_REVISION_BRANCH;
public static final String FEATUREMAP_IDX = LIST_IDX;
public static final String FEATUREMAP_TAG = LIST_FEATURE;
public static final String FEATUREMAP_VALUE = LIST_VALUE;
Can you please test this with your model and report here?
And please submit a bugzilla with your problem description and this formatted SQL:
SELECT
l_t.cdo_id,
l_t.cdo_branch,
l_t.cdo_version,
l_t.cdo_idx,
l_t.cdo_tag,
l_t.cdo_value_DATE,
l_t.cdo_value_TIME,
l_t.cdo_value_BLOB,
l_t.cdo_value_CHAR,
l_t.cdo_value_CLOB
FROM
WHERE
Sorry for the inconvenience!
Cheers
/Eike
Am 05.04.2012 16:04, schrieb scott@xxxxxxxx:
> Thanks, Eike. I tried some scenarios using the Offline examples you suggested to see where I might have gone wrong.
> 4. Add an instance of my model to the CDO repository through the clone and wait for the trans to commit.
> This scenario works fine with the one node Company model instance provided with the examples, but when I use my own
> large model instance (2MB graph with 17K+ EObjects), step 5 causes the clone to go into a loop.
> Here's how it looks on the clone server console with tracing turned off. With tracing on, there are stack traces:
> Enter a command:
> 0 - exit
> The debugger shows these session threads accumulating in both the master and clone servers.
> I tried creating a larger the Company instance, but that didn't replicate the problem.
> 1. AbstractOfflineServer: I changed only the EPackage registration line CompanyPackage.eINSTANCE.getClass(); changed
> to RegattaPackage.eINSTANCE.getRegatta();
> 4. OfflineExampleClient: replaced the Company model with my model. I attached this file in case you want to see it.
> Here's a snippet from one of the loop iterations captured from the master server console with tracing turned on:
> Thread-12 [org.eclipse.spi.net4j.Channel] Handling buffer: Buffer@636[PUTTING] --> Channel[1, SERVER, cdo]
> Thread-12 [org.eclipse.internal.net4j.buffer.BufferPool] Obtained Buffer@637[INITIAL]
> Thread-12 [org.eclipse.spi.net4j.Channel] Handling buffer: Buffer@637[PUTTING] --> Channel[1, SERVER, cdo]
> [ERROR] org.h2.jdbc.JdbcSQLException: Column L_T.CDO_SOURCE not found; SQL statement:
> SELECT l_t.cdo_id, l_t.cdo_branch, l_t.cdo_version, l_t.cdo_idx, l_t.cdo_tag, l_t.cdo_value_DATE,
> l_t.cdo_value_VARCHAR, l_t.cdo_value_BOOLEAN, l_t.cdo_value_BIGINT, l_t.cdo_value_SMALLINT, l_t.cdo_value_TIMESTAMP,
> l_t.cdo_value_DOUBLE, l_t.cdo_value_TIME, l_t.cdo_value_FLOAT, l_t.cdo_value_BLOB, l_t.cdo_value_CHAR,
> l_t.cdo_value_INTEGER, l_t.cdo_value_LONGVARCHAR, l_t.cdo_value_CLOB FROM XMLTypeDocumentRoot_mixed_list l_t,
> XMLTypeDocumentRoot a_t WHERE a_t.cdo_created BETWEEN 1 AND 1333579470612 AND a_t.cdo_id=l_t.cdo_source AND
> a_t.cdo_version=l_t.cdo_version AND a_t.cdo_branch=l_t.cdo_branch [42122-117]
> org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: Column L_T.CDO_SOURCE not found; SQL statement:
> at
> at
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.rawExport(DBStoreAccessor.java:1107)
> at org.eclipse.emf.cdo.internal.server.Repository.replicateRaw(Repository.java:1113)
> at
> at
> at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:90)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:96)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
> at
> Caused by: org.h2.jdbc.JdbcSQLException: Column L_T.CDO_SOURCE not found; SQL statement:
> ... 17 more
> With tracing turned on, the clone's log shows the same 'Column L_T.CDO_SOURCE not found' message.
> $cott
>> Hi Scott,
>> Thanks ;-)
>>> application's log:
>>> server !
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> Yes.
>>> this one.
>> Cheers
>> /Eike
Re: Reconnecting from clone to master after CDO master server failure [message #838051 is a reply to message #837421] |
Fri, 06 April 2012 09:48  |
Bugzilla is opened. The patch you provided below worked to solve the
problem. Details in the bug record:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=376252
$cott
On 4/5/2012 12:37 PM, Eike Stepper wrote:
> Hi Scott,
> maps in your model. They belong to the functions with the most complex
> resources to investigate/fix adequately. I'm sure nobody has used them
> so far together with offline replication. Nevertheless I'd like to
> solution is as easy as replacing the respective String constants in
> formatted SQL:
> SELECT
> l_t.cdo_id,
> l_t.cdo_branch,
> l_t.cdo_version,
> l_t.cdo_idx,
> l_t.cdo_tag,
> l_t.cdo_value_DATE,
> l_t.cdo_value_TIME,
> l_t.cdo_value_BLOB,
> l_t.cdo_value_CHAR,
> l_t.cdo_value_CLOB
> FROM
> WHERE
> Cheers
> /Eike
>> loop.
>> Enter a command:
>> 0 - exit
>> line CompanyPackage.eINSTANCE.getClass(); changed to
>> Buffer@637[INITIAL]
>> SQL statement:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 17 more
>> $cott
>>> Hi Scott,
>>> Thanks ;-)
>>>> application's log:
>>>> server !
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>> Yes.
>>>> this one.
>>> Cheers
>>> /Eike
Current Time: Sun Jul 20 11:45:12 EDT 2025
Powered by FUDForum. Page generated in 0.05781 seconds
