Home » Modeling » EMF » [EMF][Teneo][Transaction] what's the best way to combine them...
[EMF][Teneo][Transaction] what's the best way to combine them... [message #834489] Sun, 01 April 2012 22:21 Go to next message
I am Hoping to use EMF transaction to ensure data integrity, and help rollback in case certain operations violate my data model.
At the same time, I want to use Teneo to persist the my model data to a backend db.
Actually, when I save data via Teneo, it does some validation too. Should I simply rely on that?
Or should I have some kind of nested transaction?
Outer-trans:
Change model data;
Validate or roll back;
Inner trans:
Save to Teneo;
Roll back outer in case of inner (db) failure.
I am probably deeply confused about these concepts... What's the best solution here? How can I make sure my db and my model are in-sync, as well as model integrity?
Thanks.
-Simon
Re: [EMF][Teneo][Transaction] what's the best way to combine them... [message #834582 is a reply to message #834489] Mon, 02 April 2012 01:52 Go to previous messageGo to next message
Hi Simon,
I am sorry, I have no experience with EMF transaction, so I can't give a sensible reply. Teneo and EMF Transaction are
not used together afaik, most of the time people rely on Teneo to do the transaction and validation. If a save fails the
error is displayed and the user can edit the invalid data to bring it to a valid state.
But your nested transaction seems worth a try, have you tried it?
gr. Martin
> data model.
> Outer-trans:
> Change model data;
> Inner trans:
> Save to Teneo;
> Thanks.
> -Simon
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [EMF][Teneo][Transaction] what's the best way to combine them... [message #834858 is a reply to message #834582] Mon, 02 April 2012 09:40 Go to previous messageGo to next message
Thanks, Martin...
No, I haven't tried the nested transaction, but I plan to.
My feeling is that manual rollback isn't convenient enough, especially if a transaction touches many objects.
I was hoping there is a way to use Teneo to directly "reload" from the DB, thus discard the changes made to the model. This is more expensive than rollback locally using EMF transaction, but seems easier to do with Teneo... Not sure which method to use though, still experimenting...
-Simon
Re: [EMF][Teneo][Transaction] what's the best way to combine them... [message #834902 is a reply to message #834858] Mon, 02 April 2012 10:34 Go to previous message
Hi Simon,
The hibernate session has a refresh method which reloads from the db. But as you say it is quite expensive to do that
for many objects.
gr. Martin
On 04/02/2012 03:40 PM, Simon Chen wrote:
> Thanks, Martin...
> -Simon
The Netherlands
Previous Topic:CheckboxTreeViewer data binding with EMF
Next Topic:EMF Validation
Current Time: Sat Jul 19 19:41:13 EDT 2025
Powered by FUDForum. Page generated in 0.04881 seconds
