Home » Archived » Jubula » Jubula 1.1 extensions in 1.2
Jubula 1.1 extensions in 1.2 [message #831170] Wed, 28 March 2012 11:05 Go to next message
I have made some Extensions for Jubula 1.1. Now have updated Jubula to the neweset version 1.2 and pasted the extension in the jubula plugins folder again.
But now, Jubula does not recognize my extension.
So my question is:
Has something changed in 1.2 that might cause this behavior? Has something changed in the source code which influences the extension handling?
Tommy
Re: Jubula 1.1 extensions in 1.2 [message #831174 is a reply to message #831170] Wed, 28 March 2012 11:10 Go to previous messageGo to next message
There is a bug entry for this in the GUIdancer Bugzilla. Unfortunately, some changes were introduced that did not get documented. More information is in the bug report.
Alex
Re: Jubula 1.1 extensions in 1.2 [message #831176 is a reply to message #831170] Wed, 28 March 2012 11:11 Go to previous messageGo to next message
Please see / comment h ttp://bugzilla.bredex.de/337 for further information. This behavior is a known issue.
MarkusT
Re: Jubula 1.1 extensions in 1.2 [message #834816 is a reply to message #831176] Mon, 02 April 2012 08:40 Go to previous messageGo to next message
thanks for the answers. I tried the workaround of h ttp://bugzilla.bredex.de/337. But now I get errors, when I try to start Jubula. The line I added was com.subshell.jubula.extension.client,1.2.0.201204021413,plugins/com.subshell.jubula.extension.client_1.2.0.201204021413.jar,4,false, which is an extension for a rcp application.
Here is the log:
!SESSION 2012-04-02 14:33:02.158 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.osgi 4 0 2012-04-02 14:33:06.317
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (135).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.jubula.client.ui.rcp.Plugin.start() of bundle org.eclipse.jubula.client.ui.rcp.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
	at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClassCond(Unknown Source)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:626)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:608)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:562)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:486)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:459)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
	at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:105)
	at org.eclipse.ui.internal.Workbench$61.run(Workbench.java:2400)
	at org.eclipse.ui.internal.Workbench.startSourceProviders(Workbench.java:2397)
	at org.eclipse.ui.internal.Workbench.access$18(Workbench.java:2382)
	at org.eclipse.ui.internal.Workbench$30.runWithException(Workbench.java:1567)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.jubula.app.Launcher.start(Launcher.java:347)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.eclipse.jubula.tools.exception.GDConfigXmlException: null : null
---- Debugging information ----
cause-exception     : java.lang.reflect.UndeclaredThrowableException
cause-message       : null
class               : org.eclipse.jubula.tools.xml.businessmodell.CompSystem
required-type       : org.eclipse.jubula.tools.xml.businessprocess.ConfigVersion
path                : /compSystem/configVersion/majorCustomVersion
line number         : 16
	at org.eclipse.jubula.toolkit.common.xml.businessprocess.ComponentBuilder.getCompSystem(ComponentBuilder.java:197)
	at org.eclipse.jubula.client.core.ClientTest.<init>(ClientTest.java:204)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at java.lang.Class.newInstance0(Unknown Source)
	at java.lang.Class.newInstance(Unknown Source)
	at org.eclipse.jubula.client.core.ClientTestFactory.getClientTest(ClientTestFactory.java:44)
	at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.<init>(TestExecutionContributor.java:98)
	at org.eclipse.jubula.client.ui.rcp.controllers.TestExecutionContributor.getInstance(TestExecutionContributor.java:783)
	at org.eclipse.jubula.client.ui.rcp.Plugin.registerPermanentServices(Plugin.java:1036)
	at org.eclipse.jubula.client.ui.rcp.Plugin.start(Plugin.java:1022)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	... 70 more
Root exception:
line number         : 16
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.323
!MESSAGE Plug-in org.eclipse.jubula.client.inspector.ui was unable to load class org.eclipse.jubula.client.inspector.ui.provider.sourceprovider.InspectableAutSourceProvider.
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jubula/client/ui/rcp/sourceprovider/AbstractJBSourceProvider
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (135).
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
	... 55 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jubula.client.ui.rcp.Plugin.start() of bundle org.eclipse.jubula.client.ui.rcp.
	... 64 more
line number         : 16
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.325
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AutStateSourceProvider.
!STACK 0
	... 64 more
line number         : 16
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.326
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AvailableAutSourceProvider.
!STACK 0
	... 64 more
line number         : 16
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.328
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.AutAgentStateSourceProvider.
!STACK 0
	... 64 more
line number         : 16
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.329
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.ActiveProjectSourceProvider.
!STACK 0
	... 64 more
line number         : 16
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2012-04-02 14:33:06.331
!MESSAGE Plug-in org.eclipse.jubula.client.ui.rcp was unable to load class org.eclipse.jubula.client.ui.rcp.sourceprovider.TestExecutionSourceProvider.
!STACK 0
	at
Re: Jubula 1.1 extensions in 1.2 [message #834855 is a reply to message #834816] Mon, 02 April 2012 09:36 Go to previous messageGo to next message
From the stack trace it looks like something is wrong with the extension provided (majorCustomVersion attribute), but this is just guesswork.
If possible please attach the extension bundle to the 337 bug.
Re: Jubula 1.1 extensions in 1.2 [message #834869 is a reply to message #834855] Mon, 02 April 2012 09:56 Go to previous messageGo to next message
Well...the problem was, that the editor with which I edited the boundle.info has changed the encoding of the file, now Jubula is starting again. But it still does not recognize the Extension.
I'll report my progression, if something changes.
Re: Jubula 1.1 extensions in 1.2 [message #834945 is a reply to message #834869] Mon, 02 April 2012 11:36 Go to previous messageGo to next message
Somehow the encoding was not the problem as I thought. I guess it was just a typo which caused the line to be ignored. That's why Jubula could start. If I try the same steps again, the erros occur again.
I added the extension-jar to the 337 bug.
After some time of trying different settings, I'm clueless for now.
Greetings
Tommy
Re: Jubula 1.1 extensions in 1.2 [message #835483 is a reply to message #834945] Tue, 03 April 2012 05:28 Go to previous messageGo to next message
Finally!
It's working now. You have been right Achim, with your guess. There was something wrong with the attribute majorCustomVersion, we have added (for an unknown reason) into the ComponentConfiguration.xml in the toolkit plugin. I have now removed it and Jubula is starting again with recognization of the extension.
Thanks to all Wink
Re: Jubula 1.1 extensions in 1.2 [message #835643 is a reply to message #835483] Tue, 03 April 2012 09:51 Go to previous messageGo to next message
We also updated our Blog article for extending Jubula 1.1 to fit the new steps needed in version 1.2:
h ttp://www.subshell.com/en/subshell/blog/Extending-Jubula-For-Custom-SWT-Controls-In-RCP-Applications100.html
Tommy
Re: Jubula 1.1 extensions in 1.2 [message #998975 is a reply to message #835643] Thu, 10 January 2013 23:23 Go to previous message
i have this error when i added the extended plugin, do anyone knows the reason
!SESSION 2013-01-11 12:19:12.629 -----------------------------------------------
java.version=1.6.0_33
!ENTRY org.eclipse.osgi 4 0 2013-01-11 12:19:18.947
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (145).
!STACK 0
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
	at org.eclipse.jubula.app.Launcher.start(Launcher.java:242)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.jubula.toolkit.common.xml.businessprocess.ComponentBuilder.getCompSystem(ComponentBuilder.java:195)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
	at java.lang.Class.newInstance0(Class.java:355)
	at java.lang.Class.newInstance(Class.java:308)
	at org.eclipse.jubula.client.ui.rcp.Plugin.registerPermanentServices(Plugin.java:1039)
	at org.eclipse.jubula.client.ui.rcp.Plugin.start(Plugin.java:1025)
	... 70 more
Root exception:
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.955
!STACK 0
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jubula.client.ui.rcp (145).
	... 55 more
	... 64 more
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.957
!STACK 0
	... 64 more
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.958
!STACK 0
	... 64 more
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.959
!STACK 0
	... 64 more
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.960
!STACK 0
	... 64 more
	... 70 more
!ENTRY org.eclipse.equinox.registry 4 1 2013-01-11 12:19:18.961
!STACK 0
	... 64 more
Previous Topic:Control didn't display in component type of new Test Step
Next Topic:Testexec hangs if unable to connect to AUT
Current Time: Sun Jul 20 19:40:14 EDT 2025
Powered by FUDForum. Page generated in 0.05106 seconds
