Home » Eclipse Projects » Rich Client Platform (RCP) » java.lang.LinkageError: loader constraint violation
java.lang.LinkageError: loader constraint violation [message #832568] Fri, 30 March 2012 05:42 Go to next message
I have two pluins lets say A and B, B has added A in dependencies tab. Both A and B contains one external jar file in the class path.
But second plugin gives run time exception which is
Exception in thread "Thread-13" java.lang.LinkageError: loader constraint violation: loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) previously initiated loading for a different type with name
if i remove jar file from B(as A contains it and i have added A as dependency) then compiler give errors saying not able to recognize classes using that jar file..
Any idea?
Re: java.lang.LinkageError: loader constraint violation [message #832703 is a reply to message #832568] Fri, 30 March 2012 09:31 Go to previous message
Plugin A has to export the package contained in the jar file so that plugin B can see it.
Previous Topic:Spring XSD Schema Problems
Next Topic:Eclipse RCP Text Editor Do Undo Mechanisö
Current Time: Sun Jul 20 06:12:11 EDT 2025
Powered by FUDForum. Page generated in 0.03837 seconds
