Home » Eclipse Projects » Equinox » early start of log service
early start of log service [message #83208] Tue, 13 February 2007 07:39 Go to next message
Originally posted by: peter_ossipov.mail.ru
Hello everybody!
I am using log4j for logging. Quite nice. the problem is that I cannot
figure out where to initialize the logger.
I spoke to Tom Schindl on platform.rcp mail list and he recommended to
ask here. How do I initialize my plug-in as early as possible, so that
even if there are some errors during initliazing of the workbench, for
example, they are being logged anyway?
Thanks very much in advance.
Re: early start of log service [message #83234 is a reply to message #83208] Tue, 13 February 2007 11:01 Go to previous messageGo to next message
--------------050600080703030302020100
I tried to do like here:
http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg02208.html
My interpretation is explained by the attached files. What am I doing wrong?
My activator class is being activated, but the class ILogActivator is
not... Breakpoint does not work when I add it in a default constructor. :-(
Peter Osipov wrote:
> Hello everybody!
name="MANIFEST.MF"
Content-Disposition: inline;
filename="MANIFEST.MF"
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %pluginName
Bundle-SymbolicName: org.apache.log4j
Bundle-Version: 1.2.13
Bundle-ClassPath: log4j-1.2.13.jar
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Export-Package: org.apache.log4j,
org.apache.log4j.chainsaw,
org.apache.log4j.config,
org.apache.log4j.helpers,
org.apache.log4j.jdbc,
org.apache.log4j.jmx,
org.apache.log4j.lf5,
org.apache.log4j.lf5.config,
org.apache.log4j.lf5.util,
org.apache.log4j.lf5.viewer,
org.apache.log4j.lf5.viewer.categoryexplorer,
org.apache.log4j.lf5.viewer.configure,
org.apache.log4j.lf5.viewer.images,
org.apache.log4j.net,
org.apache.log4j.nt,
org.apache.log4j.or,
org.apache.log4j.or.jms,
org.apache.log4j.or.sax,
org.apache.log4j.spi,
org.apache.log4j.varia,
org.apache.log4j.xml
Import-Package: org.osgi.framework, org.osgi.service.component
Require-Bundle: org.eclipse.osgi, org.eclipse.osgi.services, org.eclipse.core.runtime
Bundle-Activator: com.astrac.as.client.logging.Activator
Service-Component: /activator.xml
Eclipse-LazyStart: true
name="Activator.java"
filename="Activator.java"
package com.astrac.as.client.logging;
import org.eclipse.core.runtime.Plugin;
import org.osgi.framework.BundleContext;
* The activator class controls the plug-in life cycle
public class Activator extends Plugin
// The plug-in ID
public static final String PLUGIN_ID = "org.apache.log4j";
// The shared instance
private static Activator plugin;
* The constructor
public Activator()
plugin = this;
* (non-Javadoc)
* @see org.eclipse.core.runtime.Plugins#start(org.osgi.framework.Bu ndleContext)
public void start(BundleContext context) throws Exception
super.start(context);
return;
* (non-Javadoc)
* @see org.eclipse.core.runtime.Plugin#stop(org.osgi.framework.Bund leContext)
public void stop(BundleContext context) throws Exception
plugin = null;
super.stop(context);
* Returns the shared instance
* @return the shared instance
public static Activator getDefault()
return plugin;
name="ILogActivator.java"
filename="ILogActivator.java"
public interface ILogActivator
void activate();
name="ILogActivatorImpl.java"
filename="ILogActivatorImpl.java"
public class ILogActivatorImpl implements ILogActivator
public ILogActivatorImpl()
return;
public void activate()
return;
--------------050600080703030302020100--
Re: early start of log service [message #83260 is a reply to message #83234] Tue, 13 February 2007 11:04 Go to previous messageGo to next message
<html>
<head>
</head>
Well the only difference I could see is in the Activator class line on
this line in that example:<br>
Import-Package: org.osgi.framework, <b>org.eclipse.equinox.ds</b>,
org.osgi.service.component<br>
I did not import the package in bold, because I could not find it in my
workspace and secondly I could not find the reason to inlclude it. It
is being imported in that example, but not being used, so to speak<br>
Peter Osipov wrote:
<blockquote cite="mideqsnd3$flm$1@utils.eclipse.org" type="cite">I
<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg02208.html"> http://dev.eclipse.org/newslists/news.eclipse.technology.equ inox/msg02208.html</a>
<br>
wrong?
<br>
<br>
Peter Osipov wrote:
<br>
<blockquote type="cite">Hello everybody!
<br>
<br>
<br>
<br>
</blockquote>
<br>
<pre wrap="">
<hr size="4" width="90%">
</pre>
<pre wrap="">
// The plug-in ID
* The constructor
public Activator()
plugin = this;
* (non-Javadoc)
return;
* (non-Javadoc)
plugin = null;
return plugin;
</pre>
<pre wrap="">
void activate();
</pre>
<pre wrap="">
return;
return;
</pre>
</blockquote>
<br>
</body>
</html>
Re: early start of log service [message #83272 is a reply to message #83260] Tue, 13 February 2007 11:06 Go to previous message
<html>
<head>
</head>
Not in the activator class, but in MANIFEST.MF file. Sorry.<br>
Peter Osipov wrote:
<blockquote cite="mideqsnj5$flm$2@utils.eclipse.org" type="cite">
Well the only difference I could see is<b> <font color="#ff0000">in
the Activator class</font></b> line on
tried to do like here: <br>
<br>
wrong? <br>
:-( <br>
Peter Osipov wrote: <br>
<blockquote type="cite">Hello everybody! <br>
figure out where to initialize the logger. <br>
example, they are being logged anyway? <br>
Thanks very much in advance. <br>
</blockquote>
<br>
<pre wrap=""><hr size="4" width="90%">
</pre>
// The plug-in ID
* The constructor
public Activator()
plugin = this;
* (non-Javadoc)
return;
* (non-Javadoc)
plugin = null;
return plugin;
</pre>
void activate();
</pre>
return;
return;
</pre>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Previous Topic:Behavor change from version 3.2.1 to 3.3M4. Regression?
Next Topic:Problems by JSF/JSTL Examples ServerSide
Current Time: Sat Jul 19 08:23:58 EDT 2025
Powered by FUDForum. Page generated in 0.04497 seconds
